08 MAXI RIP
#41
the technical terms used is called skid correction
heres a little video for maxima king
*note* when he says, "DON'T TOUCH THE BRAKE, DONT TOUCH THE GAS"
http://www.youtube.com/watch?v=-MT5N9GLkys
here is a good one: http://www.youtube.com/watch?v=DJWng...eature=related
now what did i hear??? "DON'T APPLY YOUR BRAKES"
For the second example, it was covering rear wheel drive cars, not applicable to the Max, at least not mine.
#42
If in the first example, you are on an exit ramp, there isn't enough room for you to just turn into the skid before waiting for the 'pause' because you will have missed the turn and now be either into the wall or the ditch. Yes turn into the skid while applying the brakes and recover control and steer to the right.
this is not a difficult thing to understand. if your in a skid you don't touch your brakes, ever, at all.
when you lose traction and slide on your tires, the road acts like sand paper and tiny little ***** of rubber form under your tires that act like ball bearing. this is the key principal behind why when people lock their brakes up they slide farther. this is why you have antilock brakes. The problem is antilock brakes are not magical multiple directional pieces of machinery. they do their job in a straight line, if you skid in any direction other than straight they are worthless, you must release your brakes, regain traction and straight line trajectory and THEN and ONLY THEN do you use your brakes.
your mission is to stop your tires from forming these little ***** when your sliding over the road as fast as possible, lightly added your brakes slows this process limiting your chance for recovery if not preventing it all together. the goal in any out of control situation is to regain traction and then use your brakes accordingly.
this is basic basic stuff, its even in the dmv written exam for crying out loud.
#43
California Driver Handbook - Important Driving Tips
Driving Hazards
Water on the Road
Slow down when there is a lot of water on the road. In a heavy rain at speeds of 50 mph or more, your tires can lose all contact with the road and then your vehicle will be riding on water or "hydroplaning." A slight change of direction or a gust of wind could throw your vehicle into a skid. If your vehicle starts to hydroplane, slow down gradually–do not apply the brakes.
Slippery Roads
Slow down at the first sign of rain. This is when many roads are the most slippery, because oil and dust have not washed away. A slippery road will not give your tires the grip they need. Drive more slowly than you would on a dry road. Adjust your speed as follows:
A road that is normally safe can become dangerous when it is slippery. Ice and packed snow on the road can cause your vehicle to skid, especially if you are driving too fast or going downhill. If you start to skid:
To prevent skidding on slippery surfaces:
Mechanical Tips
Acceleration Skids
An acceleration skid usually happens when the drive wheels lose traction on the road surface. To maintain control of a skidding vehicle, do not apply the brakes. Ease off the gas pedal and straighten the front wheels as the vehicle begins to straighten itself out.
Locked Wheel Skids
This type of skid is usually caused by braking too hard at a high rate of speed and locking the wheels. The vehicle will skid no matter which way the steering wheel is turned. Take your foot off the brake to unlock the wheels. Then straighten the front wheels as the vehicle begins to straighten out. Slow the vehicle gradually until you are at a safe speed to continue driving.
this is exactly what happened to RSprince, and this is exactly the procedure i stated in my first post about regaining control of your car.
in every application the DMV says to get off the brakes. I am amazed at how many of you don't know what to do in a situation like this. braking in a skid is not the proper way to control your car. if you don't believe me, the dmv or any of my sources take your car to an empty parking lot on a rainy day and do it for yourself. it could mean the difference between life and death for you in an actual emergency.
There were nearly 6,420,000 auto accidents in the United States in 2005.
The financial cost of these crashes is more than 230 Billion dollars. 2.9 million people were injured and 42,636 people killed.
About 115 people die every day in vehicle crashes in the United States -- one death every 13 minutes.
i really think this is an important issue here. knowing how to correctly control your car in a situation like RSprinces could save your lives or your cars, applying your brakes in anything other than a straight line skid is making the situation worse and more dangerous.
none of you wanna join those stats up there, get prepared, get smart, drive safe
*this has been a public service announcement unpaid for by twentyeggs*
Driving Hazards
Water on the Road
Slippery Roads
- Wet road–go five–ten miles slower.
- Packed snow–reduce your speed by half.
- Ice–slow to a crawl.
- On cold, wet days, shade from trees or buildings can hide spots of ice. These areas freeze first and dry out last.
- Bridges and overpasses tend to freeze before the rest of the road does. They can hide spots of ice.
- If it starts to rain on a hot day, the pavement can be very slippery for the first several minutes. Heat causes oil in the asphalt to come to the surface. The oil makes the road slippery until the rain washes the oil off the surface of the road.
- Ease off the gas pedal,
- Stop braking, and
- Turn the steering wheel in the direction of the skid.
- Drive slowly and stay farther behind the vehicle ahead of you.
- Slow down, as you approach curves and intersections.
- Avoid fast turns.
- Avoid quick stops. "Pump" the brakes to slow or stop. (Do not pump antilock brakes.)
- Shift to low gear before going down a steep hill.
- Avoid especially slippery areas, such as ice patches, wet leaves, oil, or deep puddles.
Mechanical Tips
Acceleration Skids
Locked Wheel Skids
#45
Taking my Maxima to the Max!
Sorry to hear about the accident! I hope you are better now. I am a massage therapist and we see a lot of people with auto accident injuries. Make sure you are getting the right treatment. Massage really helps, especially for whiplash and making sure your hips and shoulders and spine are back in alignment.
As for the car, it is totaled then? I assume the insurance company has it now. By chance is the front end still ok, meaning the bumper, grill...? I am looking at getting a 6th gen and want to convert the front end to the 6.5gen look. Let me know. Thanks.
As for the Hindu comment, not to get into religion, but just to clarify. I was born and raised a Western (American) "Hindu", some of you may know us as the Hare Krishnas. The common understanding of Hinduism is quite misunderstood when it comes to trying to boil it down to one philosophy and theology. (Having been a religion major in College I can say that -) Hinduism is actually a family of philosophies and theologies based on the practices of Dharma coming from the ancient scriptures written in Sanskrit called the Vedas (which literally means Knowledge). These practices were understood and performed differently in the Indian Subcontinent and later beyond for many centuries before the time of the Muslim invasions of the early second millennium CE (common era). It was the invading Muslims that coined the term "Hindu" to make sense of all the multifarious practices that they found themselves faced with upon entering that area, which was beyond the Sindu river (in Persian the "S" is pronounced more like "H"). The actual word "Hindu" is found nowhere in the original Vedic texts.
Later on, under Muslim and then British rule, the various sects and groups having lost their autonomy began to vie for position, whereas previous to such subjugation they all coexisted and cooperated respectfully for the most part. The "sect" that has only recently (within the past few hundred years) become associated with greater "Hinduism" is the Mayavadis or followers of the impersonal Monistic philosophy of Shankara Acharya, which does pretty much follow the line of nihilism, or becoming void or "merged" with the Impersonal Supreme, after liberation. This philosophy though has many times been refuted, and many would say defeated, especially by the Monotheistic Devotional Schools of thought namely the Vaishnava Sampradayas, or lineages of gurus and disciples who pursue perfection through Bhakti Yoga, or devotional service to the One Supreme Personality of Godhead, Whom they primarily worship as Vishnu, Krishna, Rama, etc. He is the same "God the Father" as in the other Monotheistic traditions of Israel and Palestine such as Judaism, Christianity, and Islam but is known by these other Names.
So, actually, the ultimate goal of true (original) "Hinduism", also know as Sanatana Dharma, or the eternal occupation of the Soul, is to simply re-awaken pure love of God within one's own heart and give up false identification with the material body, mind, and it's products and attachments, and thus go back eternally to enjoy blissful life in service to the Supreme Personality of Godhead in His own place, the Spiritual World, even after one life of fully surrendered service. Reincarnation is there, but only to give us the chance to pass through the lower modes of ignorance, passion, and material goodness, so that eventually we graduate to the post-graduate level and earn the purity through love and grace that allows us to go back to our eternal spiritual home.
Anyway, sorry about the religion class. I'm just glad it wasn't your time to go yet. My prayers and best wishes with all of you this new year.
Hare Krsna and may God bless you all:-)
Mrkanda "Mark" Fitch
#47
I defended your ban when I was told by DanNY that he banned you because I felt neither of us should have been banned for our argument, but of course he felt otherwise and stated you were banned for attacking another member. Can't beat the law
I completely disagree with Petit, right after he stated that you are "mannering" up, you respond with your typical BS. What a slap in the face
Anyway carry on with your charade, peace
#50
PS. He said they can order my Ezconcepts led tail lights for me as long as there safe and meet some type of safety standard? Dose anyone know if those tail lights by Ezconcepts meet those standards he's talking to me about? I'm going for the ruby red ones this time instead of the black Bermuda .
#52
#54
#56
#59
Sorry you are getting rid of the Max. Was it finally ruled as a total loss? I thought you said an adjuster said they woudl fix it? I might be wrong. Correct me if I am.
So, you are not willing to share picturs of the totalled car with us here on the org? Would be nice if you post some pics. Can you do that?
#62
I don't know how it is in the States exactly, but here in CA it's about 10-15% more on the $$ for a coupe over a sedan. I'd stick with a 4 door if you are looking at the G35 as the sedan is actually shorter in length than the coupe and looks better and is more functional IMO....
#63
#64
good bro... i didn't wanna see your grandpops cornering you into the Avalon.. lol what a terrible looking car.. the G i think is better than the maxima. It may not be as fast but the differences in speed are very low and with some modification you can really haul. here is what i would do, call your insurance company and say you want a quote on a 4 door G35 and a coupe G35, they will basically be able to put in writing how much more the 4 door and the 2 door will be. the coup just looks awesome...
#65
It's done and decided. I'm going for a 2006 G35X premium package with navigation tan leather with 40-60k on the engine. ANYHOW, Im trying to figure out if anyone on here knows there G35s. I've done alot alot alot of research on them, someone help me on this.. so for 2006 i know that was the only year G35 had a projector xeon headlights on the COUPE. I did not find anything else on that for a SEDAN. Dose anyone know if the 2006 SEDAN G35 got a projector xeon headlights? Thanks in advance
#69
just wanted to check in and see how everyone has been and there maxis? I just bought a 07 Black G35 coupe with tan leather and nav. I love it so much. bought it this past Friday. 55k on the engine got it for 19,800. It's beautifull
#70
#76
Yes once I get to my laptop I will load them in the next day, I will also show you guys my new car. The 07 G35 coupe with all the goodies. SlvrPtrn thanks all hit him up. I'm on G35driver.com as STLG35Guy
03-12-2020 12:06 AM
magiconthetire
10-26-2015 09:03 PM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
09-24-2015 06:56 PM
