2007 maxima Hard to accelerate
Old 12-19-2011, 07:29 AM
MaxSE-R's Avatar
Hey guys, I've been searching for awhile now, but i haven't found any answers yet.
I got a 2007 Maxima with the CVT trans, recently the car has been having issues where the car doesnt want to accelerate., I have to floor the gas pedal just to get the car over 30mph.
Anyone having this issue or know what the cause and fix is?
MaxSE-R is offline
Old 12-19-2011, 12:58 PM
Rsprince89's Avatar
T
How many miles you got on your car? From the time you bought it till now about when did it start to do this? What's your personal opinion? As a quick geuss I would say maybe the transmission is going out possibly!?
Rsprince89 is offline
Old 12-19-2011, 01:22 PM
seanhuang's Avatar
try to reset the ecu see whether it works, the car is in limp mode. been driving CVT with supercharger since 06 havent had any problems yet, they not as fragile as people think. i had the same problem couple years ago from loose bat. connection, intake leakage. hopefully nothing wrong with the box though.
seanhuang is offline
Old 12-19-2011, 01:36 PM
Rsprince89's Avatar
Really?! I heard cvts weren't all cut out to be what they are made out to be . Loose bolts falling down into the engine and all. I hope that dosent happen to me all be mad!
Old 12-19-2011, 06:02 PM
MaxSE-R's Avatar
car has 55k miles, it just recently started happening, maybe 2 weeks ago. i tried unplugging the battery over night to reset it, still no good, i even hooked up a snap-on scanner and no codes could be pulled.
MaxSE-R is offline
Old 12-19-2011, 08:18 PM
twentyeggs's Avatar
i want to see pictures, or it didn't happen.
twentyeggs is offline
Old 12-28-2011, 05:41 PM
RobMaxima04's Avatar
^ Agree
RobMaxima04 is offline
Old 12-28-2011, 05:47 PM
Rods03Max619's Avatar
Its in the limp mode or safe mode, take it to a mechanic or Nissan, since it aint throwing no codes...GL...
Rods03Max619 is offline
Old 12-28-2011, 09:28 PM
n2deepnc's Avatar
I hear some type of liquid sloshing!!
Whats up 6th generation Maxima owners. I've noticed that when I turn radio down & the windows are up, i hear some type of liquid moving/sloshing around near or up under the gear shift area. Can somebody help me out with this. I know i'm not hearing things!!
n2deepnc is offline
Old 12-28-2011, 10:05 PM
DAlastDON's Avatar
Off topic but i bet your heat isn't as good as it used to be when sitting at idle. Check out this thread. http://forums.maxima.org/6th-generat...nger-side.html
DAlastDON is offline
Old 12-30-2011, 09:53 AM
j.beeza's Avatar
Any updates on this problem? I'm having the same issue with my 07 SE with 70k miles. Between 20-30 mph the car hesitates for a few seconds and the and snaps back into gear. It's damn near undriveable. I also hooked a scanner up and I am not getting any codes. Checked the amp draw from the fuel pump and I am getting 4 amps consistently.
j.beeza is offline
Old 12-31-2011, 11:25 AM
naijaboy's Avatar
Hmm...no idea why you guys arent getting any codes but the fix for your limp mode you are experiencing is one of the below listed.
Camshaft sensors
Line pressure solenoid
Vehicle speed sensor
naijaboy is offline
Old 12-31-2011, 01:24 PM
j.beeza's Avatar
Camshaft sensors
I replaced the camshaft sensors on a whim and that didn't change a thing. I'll look into the other two. I just seems odd that the car's not throwing a CEL for as bad as it runs. I made an appointment at the dealership monday if I cant figure the problem out by then.
j.beeza is offline
Old 12-31-2011, 04:02 PM
naijaboy's Avatar
I hope the camshaft sensors were Nissan branded?
naijaboy is offline
Lakersallday24
03-20-2024 11:22 AM
Finkle
09-27-2015 09:53 PM
Greenmaxspeed
08-31-2015 09:06 PM
Wolvee
08-11-2015 12:24 PM
Bruceharrison
08-09-2015 07:56 AM
Quick Reply: 2007 maxima Hard to accelerate
