Noise!?
Noise!?
So i get this noise at like 1k rpm's. I ve been researching and this has to do something with motor mounts? I just changed them and i got w/ sensors. Supposedly they stiffen up at 1k+ rpms but that not logical?
Yeah SoCal and the noise is more like a 1 sec squeak at first i thought it was when i changed gears but now it does it once it hits 1krpms then it stops and once you go lower than 1k rpms it does it again. Its like this squeal it sounds kind of low but is still noticeable if you pay attention. Car is an AUTO. Ill try to get a vid tomm
if its a split second squeek noise once in a while, then it more likely IS a structural noise (like motor mounts) rather than mechanical problem.
i wouldn't limit this noise to motormounts tho. there are many more things that could cause this.
First i would isolate the causative factors. can you replicate this noise in neutral around the same RPM speeds? can you replicate this noise by easing on the throttle to the specified RPM minimizing the engine rock? does the tone or frequency change the harder you accelerate to the specified RPM. if it is your motormounts, you should be able to slightly alter the quality of nose based on how hard you accelerate and cause the engine to rock... i got more to say but i have coursework to finish and i've procrastinated long enough lol, ill wait till you post the video.
hm.. so you are positive that it is in relation to your rpm speeds, and not the weight shifting around when you accelerate/decelerate with the throttle?
It comes from the right side...hmm that actually sounds like a good guess im missing a splash guard so water may have gone up there but another thing is i just got the serpentine belts changed too.
I'm still bothered from this noise and my car doesn't have any problems, it only does it at 1k rpms. Its starting to get annoying, and it just bothers me doesn't sound like a bad noise but doesn't sound normal either?
