MAGNAFLOW 14805 MUFFLERS- MAGNAFLOW 12640 RESONATOR=FAILLLLL
so i decided to do what one of the member did, and to be honest not happy with the setup. i mena it sounds good but drone is crazy. idk what to do now. i cant stand cabin noise, so now im really pissed.
i have vid that ill upload, (DRONE DRONE DRONE )
http://www.youtube.com/watch?v=Uc7NqiEQAMA
http://www.youtube.com/watch?v=-MwEUrMG4Po
http://www.youtube.com/watch?v=To8IzY-vq4k
http://www.youtube.com/watch?v=mM2Tri3hryc
http://www.cardomain.com/ride/393856...edan-4d/page-2
FINAL exhaust wit extra resonator
http://www.youtube.com/watch?v=QWdD_jtIIKk
keeping a stock resonator keeps the car too quiet. just changes the tone. so you have to choose.
or you can instal a cutoff valve and choose when you want your car loud or quiet.
lastly, you have a cvt. people with gears can play around to avoid those droning rpms.
unfortunatly you can't do anything to stop it. other than getting a new resonator and trying again.
you can't have that volume exhaust without drone. not unless you tear out all the carpet and dynomat the entire shell of your car. and insulate the piping with a turbo diaper.
WOW OMG, that sounds NOTHING like my setup. If you are running the same parts then something is clearly wrong. And twentyeggs is not all correct again either as I know what I am running. My car sounds much deeper than stock and do not notice a difference inside the car. Even when I am driving "Normal" my intake produces more sound than my exhaust. Again, something is CLEARLY wrong, installed wrong, or even defective!
its been my experience that with every car there is a certain resonant frequency. it doesn't take much volume to hit that pitch and the whole car resonates (drones). the maxima is very insulated. but if any section of your exhaust is touching a solid part of your car it could be the reason. if not, then i don't know what to say other than you need a better resonator.
what diameter piping did you go with. and is that the same diameter as the other set ups your mimicking?
OP maybe you should look at the setup up the member your trying to "copy" and your setup What you thought just because you threw on the same resonator and muffler as someone else that your car will sound the same???
If its not some kind of exact catback system thats made by the same company (like cattman, nismo, etc) its not going to sound the same on different cars just because you threw on the same mufflers and resonator.
if your set up is the exact same and doesn't do that, meaning the aftermarket resonator is enough to muffle the sound, then my only guess is whoever put your system together didn't do it right. meaning he welded the pipes so that they are touching your car and transferring the vibrations into the cabin making the drone.
its exaxctly like yours i didnt do anything different, and i also have the same intake too (r2c). how could i tell if its defective???
Well you have the same car as me and same exhaust. I would definetly just check for leaks first or if exhaust is touching anything when under all RPMS's. Sooo weird!!!
and ill def make sure if its touch or not, but for some reason when i had factory exhaust like the tone use to change like it would make different sound when it was 2-3 and after that normal. idk if thats normal.
haha......People getting defensive. I say the louder the pipes, the more cabin noise, right? my auto cvt sounds fine. yes, it is a little louder in the cabin from my ebay knock-offs, but it is pretty un-noticable. I don't hear it too often, because i usually have the stereo cranked anyhow....
that is freaking crazy loud, i would kick a baby if i had to keep hearing that, LMAO. something is not right, if someone else has that set up and theirs dont do it, and all the parts are the same then something is not installed correctly. You know there two ways to install a res. I am not familiar with which res you have but some of them can actually be installed backwards and thus making it louder. Now I am no expert but i have seen thread about it on other forums
good luck
good luck
good luck
good luck
an exhaust leak wouldn't make a drone noise. an exhaust leak sounds like someone buzzing and blowing air through a soda straw. they are very quiet. your problem is the the sound is too loud, or your pipes are resting up against a solid part of the car. also, cheap exhaust systems like magna flow are NOT all going to sound the same. they should should similar, and shouldn't be so different that someone gets horrible cabin noise while the other doesn't.. my guess is they boxed the wrong model resonator and you have something different than what you ordered. mistakes do happen...
take it back to the muffler shop and ask them to check for any leaks. i had a leak when i had my 3rd gen that caused it to drone a bit. it was quieter after the muffler shop re-welded the resonator to the rest of the system.
also keep in mind that some people can tolerate a bit more drone than others, sooooo an exhaust note may seem ok for some, but loud to others.
yeah one of the member has the same set up and he said its like stock. which is what i wanted. he also has a vid and he has done lot of research and ended up wit mags set up, and it sounds perfect. i just think that the shop messed up the res part. thanks man
tell me about it lol, i mean its sounds good from outside inside i feel like im in dodge viper lol. but now im gonna try some stuff probably block my trunk so i dont get any cabin noise. idk what to do at this point. and my resonator is straight thru i mean it cant be wrong sice both sides are same.
Still crazy, when i say the resanator is installed backwards, its the inside you have to look at, its the chambers and they direction they face. You cant tell from the outside you have to look inside. I hope you understand what i mean.
Keep us posted on what the shop says
exhaust
so after all the running i added another resonator, and its perfect now. not that much drone. i wonder if just switching mufflers would give the deep tone.??????? ill post the vid of the final exhaust.
Where did you add an another res.? Can you put any pics up im going with the same setup
I have already created a thread showing pictures, installation, and a quick video. I have the same 2007, as well as the same model numbers of all 3 Magnaflow mufflers.
im from ct as well. i seen in one of your videos while you were on I95 you slowed down right were the troopers are speed checking at lol. maybe we could meet so i can check out your setup. it does drone alot from the videos
not gonna lie bro but i think it still alot for two res. I have my ebay catback with an 22" magnaflow res. and on highway i dont hear that much of sound (hmmmmmmmm'n sound). Im 100% sure when i put the magnaflow muffers its not gonna be loud as catback. Idk it might be your camera too. I do hear alot of wind noise too
exhaust
i don't think you can install the stock mufflers on the ebay catback. it was gonna create back pressure. i have the ebay catback with magnaflow res. and also magnaflow res. but not sure what to do now. lol
