vibration at hum at 50mph?
Hey Everyone, I just bought my 2004 Maxima, and I have noticed something very strange. at exactly 50mph, you will all of a sudden here a hum similar to when you drive off the edge of the highway and you hit those bumps made to let you know you are going over the edge, and I also feel a light vibration in the gas pedal whenever I hear this hum. And then once I hit 55-57mph it goes away. It only does it in that small 5-7 mph gap from 50-57. very strange, any ideas?
Had my wheel bearings checked by a guy at Discount Tire today and he said both are nice and tight, no play at all. I had them rebalance my tires and fill them to the proper pressure and the ride is as smooth as it was when I put the new tires on before I replaced the struts... the vibration is hardly noticeable at all now. Must've threw something off when I replaced the struts.
had both of my rear hub bearings removed about 50k... humming noise was so unbearable - even when i had my Greddy's on .. they were louder than my exhaust. Replaced it and now the exhaust just got louder!!! can't win either way... but same exact scenario turn to the right loud.. left not as loud... if you going to replace one might as well replace both. chances are the other one is about to go anyway.. in my case it was about there.. goodluck bud!
similar issues with humming rumble in front end
I've had a similar noise growing worse for several months. Just had the car in for front end alignment, wheel balancing, and new brake pads/turned rotors. Noise is significantly better at all speeds EXCEPT 50 mph! Shop said the source of the noise was cupped tires- but they are not cupped, at least not that I can tell. (I think they wanted to sell me new tires- go figure!) I'll ride it for a while and see if there is any change. I'm suspecting the wheel bearings if it does not get better.
Mine vibrates or shakes at around 100 KM/hr... and if I pull up the e brake, I feel a vibration coming from the rear... wonder if it's my rear disks that are warped... and causing the steering vibration... and yes it does it weather i press the brakes or not.
I've had the same problem, humming sound beginning around 40mph or so. Had my 60K service done, so I am assuming it is not bearings as that is a checkpoint in the service. However, it occurs startin around 40mph and gets more noticeable up until around 75mph or so.
I have a similar issue. I have a 2007 SE and it sounds like I am driving a large truck with huge monster tires. Only hear the noise when the car is moving and the faster the louder. If I am going 2 MPH I hear it and the faster the louder it is--much like big truck tires. Everything else seems fine. I just got the car but did not notice this before buying. Any thoughts?
I just recently got my max out of the shop for that "hum" mine sounded almost like road noise from tires, but they got over 20000 miles on them so figured that couldnt be it, anyway the dealership found the right rear wheel bearing going out. R&R wheel bearing and no more noise.
Not sure if this helps, but I had a similar issue. My steering wheel would have a subtle vibration when stopping and at speeds over 35mph. I took it into Meineke today and they showed me worn and cut tie rod ends on my front passenger side. After replacing the two rod ends, labor and an alignment to the tune of $216, the vibration is gone. Good luck...
