Need to replace motor..suggstions
Old 06-11-2010, 07:46 AM
floppynuts3333's Avatar
Well My dumbass finally did it...blew a damn hole right through the engine. Anyways, I have found many vq35de engines all listed for the 5sp mt and 4sp at...I was wondering if there are any differences in the engine that would prevent me from hooking up my 6sp in a direct swap? Also do you guys have any recommendations for a better version vq that will be a direct swap? Looked it up a little in the forums but didn't really answer my question. After I get the motor I will keep a pretty thorough post on it. Thanks
floppynuts3333 is offline
Old 06-11-2010, 09:27 AM
JD05's Avatar
I believe that the 04 to 08 motors are pretty much(give or take a few minor changes) the same except for horsepower mine is a 05 with 265 and i think the 06 to 08 are a little less. BTW how did you blow your engine???? These engines are pretty bulit proof unless you revved the hell out of it or lack of maintenance?!?!? To replace if I blew my motor I would buy other car unless you still own money on it? If you put another engine in it and that engine goes it will be nothing but a money pit. Unless you buy a new engine.$$$$$$
JD05 is offline
Old 06-12-2010, 10:01 AM
Havnt got any real answers from anybody including Nissan..they basically backtrack the vins and see if it is the same part numbers...they said certain engines my very well fit but they cannot tell me which ones actually will. I was basically asking if anyone has done a swap and could provide any fitment issues or insight on if AT engines are not compatible. Thanks
Old 06-13-2010, 08:28 AM
dpresidents's Avatar
Call some junk yards to see if they have one, or call your local auto zone.
I believe they have crate motors for a few grand.
dpresidents is offline
Old 06-14-2010, 10:04 PM
HatersLOVEme : )'s Avatar
I think he was really more looking for the compatibility between the years of 04-08 and auto and six and five speed manual engines found in 02 and above Alitima SE's before he just bought a motor ???
HatersLOVEme : ) is offline
Old 06-14-2010, 10:09 PM
ABlackSER's Avatar
Lol damn dude how did you blow the mostly industuctible VQ?
ABlackSER is offline
Old 06-15-2010, 11:06 PM
Yeah basically looking to see what engines would fit (ie. 4sp at, 5sp at etc.) Basically what I have found from the tech manual and talking to a few yards and shops through parts referencing...I think I can use a motor from the a/t..but from what I found it looks like I will need to swap the flywheel and take off the pilot converter from the crank and replace with a pilot bushing for the 6sp mt. I feel like a straight a#$hole...but I made a damn big mistake by not putting my nozzles back into the lines for my nitrous/fuel(it was a loooooooong day). A retest in 4th gear....maybe 700hp later..holes in block. Yeah. Well upside I will have an extra intake to port match and finally get around to installing y and headers(already ordered). The reason for my original question was I found many a/t engines and one is actually 1.5hrs away with 51k miles on it and only$750....Ive been getting quotes for the last few days around $1100-1300 all day...Nissan quoted $4k..haha they got jokes. And I was trying to get any input on any other mods I should do while I have my baby stripped down. I have everything stripped. 2 Mounts still on and 2 tran bolts still in. Gotta assemble my engine hoist, and unbolt the engine mounted shaft bearing, and that should be that. Let me know if you guys have any good input....I hear removing the pilot converter is a *****. I guess I'll find out soon enough.
Old 06-17-2010, 06:26 AM
randman05's Avatar
Salvage yard is your friend...
randman05 is offline
Old 06-17-2010, 11:15 AM
Good luck brother.
Old 06-17-2010, 08:57 PM
LongIslandMax's Avatar
I'm not sure how far upstate you are, but there is a NYCMaximas.org member selling vq35's <90K for $650. According to this thread, he has 14 motors ready to sell, all of which come with a 30 day warranty.
Check this thread out. If you haven't already registered on this site, go ahead and do so.... Goodluck
http://forums.nycmaximas.org/showthr...highlight=vq35
LongIslandMax is offline
Old 06-24-2010, 08:23 PM
Engine is removed. Everything is coming along well. Got my UDP, headers and y (need to get the bung welded for egr), stage 2 exedy clutch has been ordered and awaiting arrival and started port matching my intake....I will probably do slight work on the head ports as they are slightly smaller than the gasket holes. I might possibly get a fidanza flywheel...but I havnt convinced myself enough yet. I will post pics the next couple of days..If you guys have any questions, feel free to ask.
Old 06-28-2010, 11:58 PM
damn you crank pulley!!!!!!!!!!!!!!!!!!
Old 06-30-2010, 06:30 PM
this was day one....
Old 06-30-2010, 06:32 PM
the blown motor..
Old 06-30-2010, 06:37 PM
my baby today...
finally got the damn pulley off the new engine and got the cosmo on...
the a/t flywheel from the new engine..and the damn pilot converter that i had to drill the **** out of.
installed the stage 2 exedy today all I need is to get a damn bung welded on the header...might have to get it straight welded cuz nobody can really help
port matched intake
Old 07-01-2010, 12:09 PM
SHIFT_my stick
lblackonblackl's Avatar
drive slower
lblackonblackl is offline
Old 07-01-2010, 01:44 PM
nevaaaaaaaaaaa
Old 07-03-2010, 07:12 PM
almost done....forgot to port the upper intake manifold..got that done today and engine is in...couldnt find a bung for the egr so I got it straight welded...I think it will work great..Ill take pics if anybody is interested in what I did with the egr..gotta connect all the connectors..fill the fluids and tie up some ends and outs. Wish me luck
Old 07-03-2010, 08:30 PM
4DRZ's Avatar
Wow that just looks like a nightmare. GL with the install.
the blown motor..
4DRZ is offline
Old 07-04-2010, 04:31 PM
thanks for the support guys....she is almost done..still waiting for my o2 sims and help with the wire diagram for one connector that came apart
Old 07-07-2010, 05:08 PM
once I fixed that connector car started right up...car is in limp mode right now from the blow I believe..fixed a coolant leak from a blown o-ring, exhaust with headers and y sounds amazing. I still have to install the o2 sim and install drive shafts and tires...vent clutch..top off fluids, squeeky new belt from the udp, then clear the cel..Ill post pics when fully done.
Old 07-09-2010, 03:13 PM
pktaske's Avatar
next time forget the new engine and go with som JB Weld.
pktaske is offline
Old 07-10-2010, 08:05 PM
believe me I would have it it wasnt the rod snapped in half
Old 07-12-2010, 08:48 PM
She is up and running good. Thanks for the support everyone! See ya out there.
Old 07-14-2010, 12:52 AM
So where did you end up sourcing the motor from ???
Old 07-14-2010, 06:38 PM
this place called indoor auto parts. was about an hour from me and picked it up for $703...last recorded was 55k. they had one with 45k ...but it actually looked like it was in worse shape and missing a valve cover and the crank pulley was completely rusted off. SO far so good.
captchaos
03-15-2016 12:18 PM
PH98I30
26
10-12-2015 05:01 AM
dvcamp
09-18-2015 10:17 AM
dcam0326
09-08-2015 11:02 PM
Maxima30
09-07-2015 06:13 PM
Quick Reply: Need to replace motor..suggstions
