shift know loose
shift **** loose
Hey guys, my shift **** is a bit loose.. how can i tighten it? service manual only shows a locking pin?! should i just get a new lock pin?
this is an 07 Max, CVT
This is the way to remove the shift know. You can check the pin if its seated properly or if it its stretched out. When removing the aluminum cone, make sure you are turning it and pulling it down at the same time for removal. If you need an aftermarket know, I have a MoMo shift know that I'm selling
noob, as in **** i assume
So I took it apart. the bottom chrome piece has a broken tab inside, so its not on completely on the ****, so its loose a bit.. other than that, the **** itself, when pressed firmly on the arm, its solid, but i can't get the pin on b/c the little slots where the pins locks into isnt visible.. I have to raise the **** a bit to be able to click the pin in-place.. therefore, its loose.. so im thinking of packing something inside the **** so it sits firmly on the arm..
Unclejunebug
04-02-2016 05:42 AM
hayne
10-05-2015 11:53 AM
DC_Juggernaut
09-28-2015 04:07 PM
