Clearing a CEL
Clearing a CEL
I had some issues with a mass air flow sensor, which since then have been fixed. I dont however have a OBD reader. Is there any way I can clear out that code without the use of a OBD reader?
Thanks,
Vik
Thanks,
Vik
I used this a couple of days ago, and it worked on my '05:
http://www.nicoclub.com/archives/maxima-reset-ecu.html
However i think its better to go to a autozone if you have one near you. it's free. If not then you have to wait (60 or more-Start) for the Ecu to get over with it and reset it self. ( only If ur car is not throwing any code) <---- well that is what Nissan tech told me... hmmmmm
This thing doesn't work on 6th gen. Nor Taking the the battery cable off reset the ecu. But i am surprise if it did for you. .
It works just fine. I'm not sure what happened when you tried it. You probably weren't pressing and releasing the gas pedal fast enough for the 5x in 5 seconds (steps 2a and 2b). I had that problem the first time I tried it.
VIK:
No problem man. Let us know how it works for you.
VIK:
VIK:
Autozone around me I cannot trust, those guys are all douchebags and there have been instances with them messing with cars so I cannot trust them or go there
Ok update, I tried another few times after seeing that some needed to try this a few times before it worked and yes, it does work you have to be a bit precise with the time. Timing is key.
Thank you Crime, Kc and Shabnyc all help is appreciated.
jmlee44
10-02-2022 02:13 PM
04-16-2020 05:15 AM
06-06-2017 02:01 PM
Kyle Lee Cleveland
09-28-2015 09:01 PM
