Need help with my 2005 SE Maxima ( No Sound )
Old 01-21-2010, 08:32 AM
JoE'sMaX01's Avatar
Wats up guys...
I just got my new 2005 Maxima SE.. Love the car drives great but for some reason I get no sound out of the speakers... I checked all fuses but they are all good.. Is there any place I should be looking or something I can do to fix this problem? The radio turns on everything works on screen I can put a CD in and Tape no problem but no sound from the speakers at all... Any suggestions???? Please help Thanks
JoE'sMaX01 is offline
Old 01-21-2010, 11:46 AM
Smoken'04's Avatar
is it a BOSE system? make sure you check all your fuses. Could be the amp
Smoken'04 is offline
Old 01-21-2010, 01:59 PM
JoE'sMaX01's Avatar
All fuses checked out good... but any1 know how to check to see if its the amp?? or if it could be a fuse under the hood??anything would help rite now please thanks...
Old 01-21-2010, 03:08 PM
po8pimp's Avatar
99% chance if it was working and it just stopped then it's the fuse in the amp. The amp is in the trunk at the top, in otherwards under the rear window shelf. You have to pull back the lining and it is there. should be the passengers side next to the trunk light bulb. If that fuse is good I believe there is one on the driver's side next to the hood release in the cabin and one in the fuse box under the hood. Remember there are two fuse boxes under the hood so check both. I would start with the amp fuse first. If all of the fuses are good take it to nissan and have them check it out. could be wires or even head unit.
po8pimp is offline
Old 01-22-2010, 08:09 AM
JoE'sMaX01's Avatar
Thanks for the heads up on where the amp was.. I was trying to look for it but it's not like my 01 max where its exposed everything is covered in the back there and I didnt wana start pull stuff out for no reason.. I'll check the amp fuses and I'll take a look at the fuses under the hood.. Can one tell me where or which fuse box I'm looking for? Is it next to the battery? under the plastic covers??? Thanks!!
Old 01-22-2010, 08:23 AM
thealliance43's Avatar
You have 3 fuse boxes in the 2005 maxima....
one inside by the drivers steering wheel
by the passenger side under the hood
and by the battery under the hood
now to get to the amp, you have to take off the carpeting directly up "the ceiling" to the trunk. It's just clips. once you have that off you'll be able to check the amp fuse.
keep us updated and good luck
thealliance43 is offline
Old 01-22-2010, 02:05 PM
JoE'sMaX01's Avatar
Thanks for the help and advice boys... So far all fuses under and in the hood are good.. no problems with relays or nething like that everything got juice and the fuses are not blown next stop is the Amp under the carpet... Oh and btw it is a BOSE system i dunno if thats going to make a difference with the amp or something...
Thanks... keep you updated on what I find out...
Old 01-23-2010, 02:27 AM
JoE'sMaX01's Avatar
Can anyone tell me where I'm supposed to look on the Bose Amp in the truck for the fuse? I'm looking at it but everything with the connections look fine I dont see any fuses ??
Old 01-23-2010, 11:50 AM
1hawaii50's Avatar
If you have a DMM, you can start probing wires on the amps outputs when you have a CD playing. That will at least tell you if you are getting power OUT of the amp.
1hawaii50 is offline
Old 01-23-2010, 12:27 PM
JoE'sMaX01's Avatar
I just took apart the bose amp nothin seemed loose or broken.... i tried gettin a ground to check the wiring no luck yet.... anyone know how to remove the radio or this bezel so i can check the wiring behind the radio?
Old 01-23-2010, 01:13 PM
JoE'sMaX01's Avatar
I checked the wire harness from the amp and im getting. Juice out from the wires and the speakers made a popping sound when i. Touched the amp wires with my fuse checker... i also check the back two speakers for power and they are gettin. power from the. Wires.. sry for the errors im typim from my android
MAXSE5SPD
08-23-2015 12:06 PM
wingnut2006
08-15-2015 04:16 PM
cmpowell86
08-10-2015 12:35 AM
follyburr
08-07-2015 09:50 PM
Jcof88
08-03-2015 10:43 PM
Quick Reply: Need help with my 2005 SE Maxima ( No Sound )
