Fuel Gauge Needle Problem
Old 01-03-2010, 08:32 PM
dodonik's Avatar
I have a problem with a Fuel Gauge Needle. It is underneath the pin that it is supposted to rest on. It happened today when I was starting my car. I never had this issue before, nor I have any issues with the car. So far so good and my car does not have to visit a dealership or any mechanics at all. The car is working perfectly fine except this issue which is pretty annoying since I have no idea on how much gasoline I have in. The computer is no that accurate so I do not rely on it. Did anyone have had an issue like mine? Any ideas what could have caused that? What could I have problem(s) with? Any ideas how this could be fixed? Two pictures below demonstrate exactly the problem I have. Any comments, suggestions and opinions are greatly appreciated. Thanks guys!
http://i985.photobucket.com/albums/a...k/DSC03953.jpg
dodonik is offline
Old 01-04-2010, 09:33 AM
DAlastDON's Avatar
I dunno how it got over there unless the needle was removed and not put back on right. Only way i can think of to fix it would be to take the instrument cluster apart and move the needle. Fill the gas tank up first and with the ignition on put it on "F".
DAlastDON is offline
Old 01-05-2010, 07:44 AM
I Donate! Why Don't You?
xoomer.com's Avatar
Just go to the dealer, they'll probably replace the whole cluster for ya
xoomer.com is offline
Old 01-05-2010, 12:17 PM
Former Sponsor
CXJ Performance's Avatar
hey dodonik. i preform the full led mod that involves changing the nasty orange our car came with to a color combo of your choice. when doing the mod i have to get down to the circuit board of the guage cluster and remove the needles is a step in the process. to fix your problem take apart your cluster. just down to where you have to remove the cover face plates reinstall, then go to the gas station with the cover plates still off. fill your car up and place the needle back on " F " WITH THE CAR ON AND RUNNING. dont press the needle on tight just enough that its up there. go home disconnect and assemble the guage back together and plug into the car. you should be all set after that
CXJ Performance is offline
Old 01-05-2010, 02:50 PM
Lovemycar's Avatar
I really don't understand why would you change your cluster from amber to blue what happends when you get sick of blue? I just don't get that MOD
Lovemycar is offline
Old 01-10-2010, 11:23 AM
dodonik's Avatar
Thanks guys, just went to the dealer and they replaced the entire cluster. Luckilly for me it was covered under the warranty so no expense on my part, otherwise it would cost me about $600.
dodonik is offline
Old 12-08-2010, 04:14 PM
chalet79's Avatar
Today i have exacly the same problem as Dodonik on my Max04.All my warranty are over,so please anny can help me.
chalet79 is offline
Old 02-20-2011, 05:02 PM
tanksfold's Avatar
I have same problem. Did you ever get a fix? mine happened after I jump started a car with cables
tanksfold is offline
Old 02-20-2011, 05:04 PM
tanksfold's Avatar
[quote=dodonik;7362855]I have a problem with a Fuel Gauge Needle. It is underneath the pin that it is supposted to rest on. It happened today when I was starting my car. I never had this issue before, nor I have any issues with the car. So far so good and my car does not have to visit a dealership or any mechanics at all. The car is working perfectly fine except this issue which is pretty annoying since I have no idea on how much gasoline I have in. The computer is no that accurate so I do not rely on it. Did anyone have had an issue like mine? Any ideas what could have caused that? What could I have problem(s) with? Any ideas how this could be fixed? Two pictures below demonstrate exactly the problem I have. Any comments, suggestions and opinions are greatly appreciated. Thanks guys!
I have same problem. Did you ever get a fix? Mine happened after I jump started a car with cables. Thanks
Old 02-21-2011, 08:10 AM
dgoodwin39's Avatar
I had the same problem when my batt got low. I did as suggested on another post a got two ceramic brick magnets from Lowes, stuck them together end to end, put them near the gauge with the key off and woo-lala the needle moved around counter clock wise to the stop peg. Turned the key on and everythings fine. Cheap $2.50 fix.
dgoodwin39 is offline
Old 03-19-2011, 09:41 AM
tanksfold's Avatar
also fixed mine with magnet. better than taking dash out!
Old 08-12-2011, 06:21 AM
themaddog68's Avatar
The Magnet really works!!!!
Thanks dgoodwin39!!!! My gas gauge did the same thing earlier this week on my 2005 Maxima SL. Cranked it up and for some reason the needle on the gauge had gone 360 degrees clockwise and was stuck under the stop pin. I went to Lowes and bought 2 ceramic brick magnets, as you suggested, for a total of $2.92 with tax and fixed my gauge in the store parking lot in about 20 seconds! Just stuck the magnets together and used them to move the gauge back to the correct position while the car was turned off and the key was out of the ignition. Once I got the needle back to the right place I cranked up the car and it was working as it should. Man, that was awesome!!!! Thanks for posting that fix. Really worked and only cost me $3.00! I felt like Magneto on the X-MEN!!!!
themaddog68 is offline
Old 11-02-2012, 05:31 AM
Chednut's Avatar
Happy Maxima Spouse
My bride of 29 years is a very detail oriented lady. My sincere thanks to gentleman who directed me to Lowes for the ceramic magnets. Worked like a charm!! (made me look pretty good too.)
Chednut is offline
Old 11-30-2012, 07:19 AM
4 Maximas and counting
philpoe's Avatar
I have the same problem, caused when I got a jump for my bad battery.
Does anyone know the part number for the Lowe's magnet? Are we talking about the small disc magnets, stacked on top of each other?
I'm (much) closer to Home Depot than Lowe's, so I'm hoping to save myself a trip, but I'll make it to solve this issue. Real PITA.
Thanks for any links/pics to help me identify the magnet.
philpoe is offline
Old 02-10-2013, 08:48 AM
06owner's Avatar
Bought 4 magnets and can't get the needle past the 4 o'clock position. I get it that far and then nothing, not even a twitch in the proper direction. Any suggestions?
06owner is offline
Old 02-10-2013, 06:02 PM
Kryogen's Avatar
(do the magnet trick) see below
Kryogen is offline
Old 02-12-2013, 08:42 PM
TDKDF's Avatar
Same thing happened to me. bought two packages of this magnet set. One set wasn't strong enought, two will get it done and it takes about 30 seconds once you figure out what your doing.
http://www.lowes.com/pd_181666-37672...net&facetInfo=
TDKDF is offline
Old 02-13-2013, 04:12 AM
Kryogen's Avatar
Just got 2 packs of magnets at home depot. cost me 7$ or so.
At first it wasnt working, I was trying to do it through the "glass" window where you look at the needle, it doesnt work.
You have to stack the magnets together and place them on the top of the console, approx centered with where the needle is, then it grabs the needle, then you move from right to left, following the top of the plastic.
Takes 5 seconds to do when you place the magnets right.
Problem fixed. I'm glad about that.
Kryogen is offline
Old 04-06-2014, 11:11 AM
Tsmith22's Avatar
Worked
Had to get two packs myself. The trick for me was finding the sweet spot on the left side (as opposed to tracing from right to left). Needle shot around and I look like a hero to the Mrs. Thanks
Tsmith22 is offline
Old 04-07-2014, 04:10 AM
Kryogen's Avatar
I would like to add that when my car started doing that, my grounds were bad.
Remove your battery and check your battery to frame/transmission ground wire. Mine was broken between the frame and transmission, and allowed too much current to go through the gauge cluster and other components.
Replaced the cable with a nissan oem, and added a grounding kit. car starts much better now, and never had this issue again.
Kryogen is offline
Old 06-30-2014, 01:58 PM
Bob A's Avatar
Magnet Works
For the last year and a half the fuel gauge needle on our 05 Max SE was stuck on the right, or wrong, side of the pin at the bottom of the gauge. Had two dealer estimates to repair and both were $600+change - said they had to remove the dash in order to repair the gauge.
After reading this thread I bought 6 little coin magnets plus one magnet with 50lb holding strength about 2" X 1" with a handle. After some trial and error got the needle back to where it belongs. This was accomplished by holding the coin magnets on the left side of the gauge housing and holding the 50lb magnet on the right side of the housing and sliding it over the top from right to left toward the coin magnets. It took several tries at sliding the magnet to get the needle to the top from the lower right and then once it got to the top it flopped over into the proper position. Note: ignition must be turned off. Total cost: $6 for magnets.
Bob A is offline
Old 06-30-2014, 05:23 PM
Kryogen's Avatar
and check your ground cable.
Kryogen is offline
Old 09-21-2014, 03:09 PM
brettLINDA's Avatar
Fuel gauge needle problem
Hi all
I tried the magnet fix with no luck at all. Perhaps the type of magnet? I used a magnet from an old sub woofer.
Any ideas of how to fix this would be really appreciated.
brettLINDA is offline
Old 05-04-2015, 10:25 PM
dlad09's Avatar
Fuel Needle Problem
The same thing happened to my 08 Maxima SE that you guys are talking about. It happened after my battery died and I had to use jumper cables. I am going to go buy the magnets from Lowes, but I need help to where I should place the magnets to fix it. Do I place the magnets on top of the dash or somewhere else? Also if someone could post which magnets they bought that would be awesome as well!
dlad09 is offline
captchaos
03-15-2016 12:18 PM
aminus21
09-12-2015 04:53 PM
NissanNismoZ
09-12-2015 07:30 AM
conansriver
09-11-2015 10:26 AM
Quick Reply: Fuel Gauge Needle Problem
