HVAC Blower on highest setting constantly?!?! Can not adjust!!
Great...so I have another problem with the Maxima. After finishing up my shopping for the day I started the car and noticed the fan for the HVAC is blowing at its highest setting. I tried to adjust the speed with no luck. The LCD display is showing the lowest setting but the fan keeps on blowing on high. I can't even turn it off!!! The LCD shows off but the fan keeps blowing.
It does turn off when I turn off the car. I checked both fuses and they look fine. The blower does turn off when I remove both fuses.
Looks like I'll be heading to the dealer again...
When one or more fan speeds go out then it is usually the blower resistor(aka Fan Control Amplifier). If it is not that then it is the Unified Meter/AC Amp.
Here is how the fan speed is controlled in our cars. The Unified Meter/AC Amp sends a voltage to the Fan Control Amplifier(which is a high power transistor) in turn it controls the current flow out of the fan blower to ground. More ground=more current flow and faster fan speed.
I pulled apart the glovebox area. The fan amp control isn't on the fan itself, rather its back to the left and just about on the firewall. I pulled it out and took a peek inside. There are black marks on the 5 pins out from the transistor. I suspect its shot. I'll order one and in a couple days I'll know whether it fixes the fan stuck on high issue. Keeping my fingers crossed.
CM
CM
Turns out that was the culprit. Popped the blower motor resistor in there and it worked like a charm. I ordered from www.autopartsway.ca and expected an aftermarket part, but an Nissan box showed up with an OEM part.
CM
CM
t6378tp
09-29-2018 04:27 PM
Turbonut
46
10-21-2015 08:28 PM
lrb6805
09-17-2015 04:49 PM
