Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-24-2009, 04:33 PM   #1
Free 100 Point Inspection by Dealer
Local Nissan dealer was doing 100 point inspections on all Nissans....no charge.
So I brought the 2007 Maxima in. Car is 2.5 years old and has 48,000 all highway miles, completely stock used as a daily driver/commuter car.
They found these problems:
Belts need to be replaced
Low side AC hose needs to be replaced
Rear motor mount needs to be replaced
Battery "service" required ($29.95 to take a little corrision off the positive terminal)
They suggested replacing the struts even tho they had replaced them under warranty a year ago.
Total pricing for all these parts and labor is over $1600.00 with about $1,000.00 for labor. I told them their pricing was out of line and I intend to have the suggested work reviewed by a local Nissan independent shop and have the work done there.
Is this kind of wear usual to these cars at the 48K mark?
Thanks for any advice or comments.
__________________
2007 Maxima SE
Other cars:
2008 Corvette Silver Coupe LS3 (430HP stock)
2005 Mercedes SL500 Convertible-Black over Tan
Torchcorvette is offline   Reply With Quote
Old 10-24-2009, 04:46 PM   #2
Probably not, however this is what you can expect from the 100 point inspection. Now fix everthing youself and save a grand.
__________________
WTB 97-99 Stillen Rear skirts
maxboy325 is offline   Reply With Quote
Old 10-24-2009, 06:19 PM   #3
Send a message via AIM to Hamchan
Thats why they call it the stealership, lmao. Upsell, they hope you are a retarded enough to pay them. 1000 in labor is crazy. dont ever go back to that place.
Hamchan is offline   Reply With Quote
Old 10-24-2009, 08:16 PM   #4
I would say maybe the belts, I've always replaced mine every 2 years or so...but the motor mount and AC hose? at 48k? not very likely.
__________________
89K (when I got it) and counting
SHIFT_Thrash Metal
96WhiteMaxima is offline   Reply With Quote
Old 10-25-2009, 08:47 AM   #5
The free inspection is a gimmick to get money?
chipmunkaj is offline   Reply With Quote
Old 10-25-2009, 09:04 AM   #6
Send a message via Yahoo to po8pimp
there is no rear motor mount there is a front mount, a side mount, and a transmission mount. the transmission mount is the rear mount which is impossible for them to see even with an inspection mirror. They must have given you a quote from someone elses car. I have 76k miles with the same belts on it. they seem to be fine. take some vinigar and put it on the battery to clean it off, there are also terminal cleaner sprays you can buy. then rinse it off with distilled water. cost about 1/4 the cost of their service. The a/c hose I would buy and replace myself. but then you have to refill the a/c. I would just have nissan fix that one and recharge my a/c system.
__________________
po8pimp is offline   Reply With Quote
Old 10-25-2009, 12:27 PM   #7
DeusExMaxima's Avatar
Do belts urself - Its easy and cheap - Keep the old belts in your trunk as spares in case your new ones fail.
AC hose - I doubt it needs replcing unless something kicked up from the road and nicked it which I doubt since there are trays underneath. Inspect it yourself for nicks.
Rear motor mount - I doubt it since there would obvious signs (rattles or other noises)
Battery service - Get some baking soda and take your terminals off and clean them with the soda and water and re install and tighten.
Struts - Get aftermarket as Nissan struts suck.
Its pretty much what everyone else here said. And its true - thats why they are called "stealership" since they steal money from people with false recommendations to do stuff that isnt necessary.
__________________
6 speed manual Lots of mods
Check out my ride here: http://www.cardomain.com/ride/760206
Watch the fraud our government is perpetrating on the people - www.zeitgeistmovie.com
...get out of the way you old hag, you're messing up my cornering
DeusExMaxima is offline   Reply With Quote
Old 10-25-2009, 01:58 PM   #8
Thanks for all the comments. I would NEVER give the dealer (or even the independent shop) the go ahead on any major repairs without seeing the problem first hand........that is, typically with the car on a lift.......I'll see what the independent guy has to say this week. Safe to say I will not be going back to the stealership for anything.
BTW, what is easiest way to access the two belts???
Thanks.
PS. If you want to see real stealerships, try a Mercedes dealer......the coffee, big TV, loaner cars, etc. are all fine....until they hand you the bill.
__________________
2007 Maxima SE
Other cars:
Old 10-25-2009, 06:10 PM   #9
MAXIN' ON
Send a message via AIM to redls1
Thanks.
If you do a search for people that did the UDP (under drive pulley) there are several right ups that have pics and give you and idea of what to do.
__________________
2007 Maxima 3.5 SE
! 20" CHROME Katana Desire ! MTX MONO AMP !
! MTX 10" SUB ! BILLET GRILL !
redls1 is offline   Reply With Quote
Old 10-28-2009, 05:05 PM   #10
Took it to local indep Nissan guy today. He found no motor mount problems at all. I had him flush the radiator, flush the black brake fluid, change the belts, and replace the AC line (it was leaking..you could see it with naked eye....
Belts were a little worn so I'll keep in trunk as emergency spares.
I cleaned the battery terminal with baking soda and a terminal cleaner.
Should be good to 80-100K which is all I want out of this car.
I would bet they come up with $1,000. minimum worth of work on every car the look at under their "free" inspection. I'll never go back there for anything and, if I ever buy another Nissan product, it will not be there.
Thanks for all the advice and comments.
__________________
2007 Maxima SE
Other cars:
Old 10-29-2009, 01:58 PM   #11
I Donate! Why Don't You?
xoomer.com's Avatar
never ever fall for their 100 point inspection. When you bring your car for one of these this is what you're saying to them...
Here is my car; I need you to see what can be replaced (even if not needed) so that you can make some money. Thank you, you can rape me now!
__________________
I'm also into reefing @ ReefersCafe.com
xoomer.com is offline   Reply With Quote
Old 10-29-2009, 06:41 PM   #12
[quote=xoomer.com;7272569]never ever fall for their 100 point inspection. When you bring your car for one of these this is what you're saying to them...
"Here is my car; I need you to see what can be replaced (even if not needed) so that you can make some money. Thank you, you can rape me now!"
Funny! And true!
__________________
04 SL Majestic Blue/Black
lobewiper is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
