Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-19-2009, 11:10 PM   #1
is there any way?
to buff/polish the headlights? what products and materials would i need?
it looks like the clear coat may be coming off or something like that. any thoughts?
maxima365 is offline   Reply With Quote
Old 09-20-2009, 12:43 AM   #2
I dont' think there is any product to take out scratches, etc. I have the same thing on my 2005 SL with scratches I think happened when I scraped off the ice in the winter I think. I looked into using Meguier's PlastX, but after reading the label I found it was more of a polisher/detailing product for plastic. I don't want to go off and try other products similar to what is used in repairing cd's/dvd's as those actually "melt" the plastic a little. Maybe someone else has an answer to this problem but unfortunately I can't even post the questions I have yet...
2o4Max is offline   Reply With Quote
Old 09-20-2009, 01:27 AM   #3
Send a message via AIM to importcf
i know 3m makes a kit and the plastx is good stuff
__________________
2003 Maxima SE TE Super Black 6spd ||| HAI (hopefully fujita soon) ||| color matched grille ||| Premier 940 ||| JL 500/1 ||| JL 10w3
importcf is offline   Reply With Quote
Old 09-20-2009, 01:32 AM   #4
USMC
Stormzusmc's Avatar
Quote:
see below there is
Quote:
stuff works great....
if the headlight is cracked through the lens then, no you need a new lens...but just scratches....this will work
did you ever crack your headlights open or put a hid kit in? have you ever seen condensation in there? feel the outside around the cloudyness to make sure its on the outside....
__________________
Stay motivated.
Performance - Injen intake//Custom exhaust//09 Cattman Ypipe//Thermal Spacers//FSTB//Vias Removed//Megan Springs//Timing advance
Exterior/Interior - Clear front&rear//CF eyelids and b-pillars//Military license plate//Custom LEDS and Halos//Int Led swap
To install/do this spring - Powdercoat 18" G35s//RSTB//Stillen Lip
Click the link below to hear the exhaust setup.
Stormzusmc is offline   Reply With Quote
Old 09-20-2009, 01:51 AM   #5
im pretty sure its on the outside cuz i can feel the difference between the two areas
Old 09-20-2009, 05:54 AM   #6
This is what you want: http://meguiarsdirect.com/detail/MEG+G12310. It worked wonders on my old Mazda MX6.
Terrentius is offline   Reply With Quote
Old 09-20-2009, 07:49 AM   #7
Send a message via AIM to Propa Teknique Send a message via MSN to Propa Teknique Send a message via Yahoo to Propa Teknique
This is exactly what I was looking for. I dont have the problem like the other guy but my lights are dull and foggy as ever. It's funny because I take good care of the car and ensure the lights are clean but they still are dull. Can you use this by hand or do you need a buffer of some sort??
__________________
__________________________________________________ ____
.::Everything Good & Accomplished In the World Takes Work... Everything Else is JIVE::.
Propa Teknique is offline   Reply With Quote
Old 09-20-2009, 08:49 AM   #8
3MTA3
jsmithsole's Avatar
My lights looked just like yours, I tired a few different kits and they never turned out like I wanted. I finally called a headlight restoration company, paid $20 per light and they look like new!
__________________
More pics here...and click sig for Car Domain site!
~~~LED GROUP DEAL CLICK HERE~~~
jsmithsole is offline   Reply With Quote
Old 09-20-2009, 11:08 AM   #9
DeusExMaxima's Avatar
I have a double problem in that I have stuff on the outside and the inside. The inside is from waaay back when, when I painted the inside of my headlights binfut did not allow enough time for the paint to dry. I got a varnish build up from the evaporating paint. I also have pits and cloudiness on the outside from time sitting in the sun. Ill need to take my lights apart again and buff out the lense on both sides and assemble. While Im in there I will probably install some DRLs and paint red rings around the edge of the headlights and foglights to go with my theme.
__________________
6 speed manual Lots of mods
Check out my ride here: http://www.cardomain.com/ride/760206
Watch the fraud our government is perpetrating on the people - www.zeitgeistmovie.com
...get out of the way you old hag, you're messing up my cornering
DeusExMaxima is offline   Reply With Quote
Old 09-20-2009, 11:33 AM   #10
Quote:
You can do it by hand or buffer. I did it by hand with a clean towel. Works great.
Unfortunately, you can be as meticulous with your car as you want but the plastic may still become dull. This is from the oxidation of the plastic from the sun. In the end, the deciding factor will be the type of plastic that the headlight it made out of, not how much you take care of them.
Anyhoo, this stuff is pretty cheap and works great, so it is pretty low on the PITA scale
Old 09-20-2009, 06:42 PM   #11
Send a message via Yahoo to po8pimp
I used the 3m stuff and it was scarry. I mean the lights looked like complete crap as I was using the kit and I finally got finished and it looked good. I applied the polish and then Plastix. The Plastics cleaned up the lights and showed everything. I have to redue a couple steps because there are scratches like crazy. I do not recommend this kit unless you have major repair needed. Even then I would think twice about it. These lights are plastic not glass. Use the plastix, you will not be disappointed. Use some elbow grease and remove that crap. It will come off and the plastix will protect the lens. Use it when you wax and you should be good. The only reason I used the 3m is because I saw it recommended in the detailing section. Everyone praised it and well I do not. I had tried to wetsand my lights before because that is what was recommended by a local detailing shop, but that left tiny marks on the top of the lights which I eventually got out but left the light hazy looking so that is why I tried the 3m kit. Not a good idea, now both my lights look like crap and need redone, hopefully I will have better things to say about it when I do it again. I mean I did follow the steps but I think I could have sanded a little bit more. To make a long story short use Plastix. If it doesn't work use alcohol with q-tips to remove the yellow and then clean with water. Make sure you don't get the alcohol on your paint. If you do wash away with plenty of water fast. Then add a polish like plastix. Plastix is a polish/cleaner. GL and let us know what works for you.
__________________
po8pimp is offline   Reply With Quote
Old 09-21-2009, 09:34 AM   #12
KCmaxx's Avatar
Clear coat, really..?
lol
__________________
Quote:
Originally Posted by Kryogen View Post
Thanks for the constructive comments and help KC, as usual, your posts are very relevant.
KCmaxx is offline   Reply With Quote
Old 09-21-2009, 09:40 AM   #13
Send a message via AIM to bigpopaj369
i used a turtle wax kit looks like the one stormzusmc posted $8 bucks at autozone worked great, using just the cleaners like plastix does alot of nada most of the time def get a full resto kit
__________________
BIGPOPAJ369
SEXIMA badge,black w polished lip rims,rain guards,SRI,painted spark plug cover,AE'd heads w/luminics bulbs,rewired yellow tinted fogs w/out glare guards,polarg blinkers/reverse/plate lites,tinted n rewired sidemarkers(blinker mod),painted interior trim,all interior lights to led,AB clock mod w/white display,red leds in climate control w/white display
bigpopaj369 is online now   Reply With Quote
Old 09-21-2009, 02:02 PM   #14
Quote:
That's exactly what i'm afraid of happening. Because the surface of the plastic alone is not a machine surface and comes out of a mold. I think i'll try and see a little bit with the 3M stuff if I can find it. I definitely won't go full tilt until I feel comfortable with it on a little spot first.
Old 10-10-2009, 08:29 PM   #15
Send a message via AIM to 6spBaDAsS6ThGeN Send a message via Yahoo to 6spBaDAsS6ThGeN
they need to be wet sanded with something like 2000 grit, then take them to a paint shop have them lay down 2 to 3 wet coates of clear. Give them some time to dry a couple of days you realy want that clear to dry. After they have dried, again lightly wet sand and i mean lightly this will get w.e inperfections are in the clear coat out.. after youve completed all above steps buff them with mothers polish/wax.. you have to use a power buffer to bring the shine out in the clear make sure to move the buffer quickly or you will burn right threw you nice clear coat... if this is done correctly theyl shine like the clear coat on your car.. ... defiantly the best process iv come across...the lights litterally look clear and new. good luck i hope this helps..
__________________
(6sp ELITE),CUSTOM SPUARE TUBEING STRUT BAR,NWP BLOCK PLATE,EBAY CATBACK LOL "SOUNDS NICE" BLACKED OUT FRONT LIGHT HOUSING,KENWOOD KVT-512,K-SPORT COILOVERS
6spBaDAsS6ThGeN is offline   Reply With Quote
Old 10-11-2009, 12:01 AM   #16
Incognito
BigPete's Avatar
Send a message via AIM to BigPete
http://www.mothers.com/02_products/05100-05101.html
Has cleaned every single headlight ive used it on. And Ive done probably 20+ cars with it with no problems. And yes, I know its mag polish, but it works and it lasts along time, one can does over 20 sets.
__________________
MODS: Fujita f5 CAI - BT Freestyle 20's - Falken fk452 - Active Tuning GK - Racingline FSTB - 6k HID - Grille - Burgerless - LED lighting - 5% Comp Cut Tint - JL Audio Wiring - Eyelids - RotorPro Rotos - Hawk HPS - Tinted tails - Tinted heads - Lead Foot
BigPete is offline   Reply With Quote
Old 10-19-2009, 12:45 AM   #17
I found a perfect solution to the problem. Buy the 3m kit, 2000 grit sandpaper, http://www.mothers.com/02_products/06208.html and a bottle of this. About $30 total. Good for fixing alot of headlights. I used the 3m kit by itself and screwed up the headlights, so I bought the 2000 grit sandpaper and the plastic polish from mothers. I went home and used the 2000 grit sandpaper WET and sanded the lights making sure the sandpaper was wet the whole time. wiped them dry with a cloth. Then used the foam attachment from the 3m kit and a drill with the plastic polish to buff things out. They look as good as new and got rid of the huge swirl marks that damned 3m kit left. I realize that was because the kit only comes with 300 and 900 grit sand paper circles. So I recommend wet sand with 2000 grit and use the foam adapter with plastic polish to finish it off. Should take less than 5 minutes a light.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
