Where is our Oil Drain plug?
Its kinda like that question that you ask about a really expensive car - "How much is it?" Cuz if you have to ask, you probably cant afford it. Likewise here, If you have to ask where the drain plug is, u probably shouldnt be working on your car. Just food for thought.
got to start somewhere. go to www.nissanhelp.com and under the knowledge tab there are service manuals. you just have to sign up for free and download the pdf for maintenance. in the search bar type oil change. you should be good from there. GL
lol you need a 14mm socket for the plug, a ratchet to fit the socket, a filter removal tool for your size filter. recommend asking the parts store clerk to help you out. then all you do is put something to catch the oil with a capacity of at least 5 quarts. put it under the drain plug with a little bit of room towards the front bumper because the oil will not go straight down but outwards and down. open the oil fill cap on the top cover of the engine, then get back under the car and remove the oil plug. you should do this when the engine is cool not hot. if it's warm that's ok too. just not after a long drive. once the oil stops coming out then remove the oil filter which should be white or orange and towards the passenger wheel. once all the oil is done coming out clean off the filter seating surface. take the new filter and remove the rubber seal and put oil on it, enough to saturate. put seal back on oil filter and put filter back on hand tight. then make sure there is something to catch oil under the drain plug area and then pour about a half quart of oil through the oil fill cap. the oil should push all the old broken down/contaminated oil out. once it goes through put the oil plug back in and tighten hand tight. Not too tight just tight enough to ensure it does not come out. then add your oil. I believe with a new filter it is about 4and a quarter quarts of oil. I would add 4 quarts and check several times to make sure it was full. then put your oil fill cap back on and your done. start car and check for leaks. if there are any, then you probably didn't tighten tight enough or the oil filter rubber seal was put back in wrong. should take you less than 30 min if you are doing it for the first time. after that 15 at most. GL. Ohh and buy 5 quarts of oil prior to this so you don't have to go back to the store.
you guys are funny!!!
Thanks po8pimp for the "over and beyond" answer.
Just because i want to make sure i remove the correct bolt doesnt mean i am retard and she not work on my own car... lol
I will remember this.... especially from you, KC and Dues!!!!
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
Need help
23
10-02-2015 08:56 AM
