07-08 SE Non-Bose: Pics of harness behind radio
Old 08-12-2009, 10:55 AM
HMAX08's Avatar
Looking for pics of the 07-08 only Non-Bose pics. I need pics of the harness's behind the factory radio. Radio-to inof screen and vice versa.
If any of you are having your factory unistalled for aftermarket can you take pics of the unabused factory harness or if you are in houston, tx and having this done, i can come and take the pics. Need ASAP
thanks guys
HMAX08 is offline
Old 08-13-2009, 04:03 PM
sirphilo's Avatar
Are there RCA outputs for an external AMP?
I was looking for the same pictures.
I want to add an amplifier to the Non Bose stock head unit.
sirphilo is offline
Old 08-13-2009, 04:42 PM
MAXIN' ON
redls1's Avatar
Just use a hi/low converter and tap into the speaker wires and hook up the amp as usual.
redls1 is offline
Old 08-13-2009, 05:34 PM
sirphilo's Avatar
That will be the second choice.
sirphilo is offline
Old 08-13-2009, 09:37 PM
DAlastDON's Avatar
I just happen to have taken the pictures you wanted when i did my install in June.
A/C controls on top, Drivers Info in the middle, Radio on the bottom.
Up close of the radio harness
The one hanging lowest is the antenna, The other two in focus toward the front of the opening are the same two pictured above that go into the radio, and the one out of focus on the right in the back of the opening goes to the A/C display.
Just change the radio out. Just look how sweet that kenwood dnx9140 looks in there.
DAlastDON is offline
Old 08-16-2009, 12:58 PM
1hawaii50's Avatar
Hey DAlastDON ,
I'm guessing you are using the NIRD-01 unit? If so, did you install it yourself? If so, I have a couple questions for you.
1hawaii50 is offline
Old 08-16-2009, 02:36 PM
HMAX08's Avatar
Thanks for the pics, looks hott i like the kenwood. I have the D3 and love it. I got so much wires behind the unite its crazy.
hawaii, thanks for the help today the nird is up and running everything is aokay.
let me know if you got my email with radio schematics
HMAX08 is offline
Old 08-16-2009, 04:38 PM
AscendantMax's Avatar
glad you have everything sorted out
AscendantMax is offline
Old 08-16-2009, 04:51 PM
HMAX08's Avatar
Thanks Ascendant, thats sorted yes but popping noise NO, lol. I will txt you tomorrow i want to go to your boy for the rewire of the entire system. I will have time on wednesday. Let me know.
PS. thanks again on the nismo install, cant wait to get it out on the highway. haha. Wasting a tank of gas, here i come
HMAX08 is offline
Old 08-16-2009, 05:35 PM
i wonder how your nismo sounds compared to my berk. i would assume it'll be similar though.
Old 08-16-2009, 07:31 PM
1hawaii50's Avatar
Hamchan,
Glad you're good to go with that problem, and I hope the re-wire goes well for you. I got the schematic, thanks a lot!
Old 08-17-2009, 03:53 PM
DAlastDON's Avatar
I bet it looked something like this. This is after everything was hooked up and i was testing it to make sure it was right before i mounted it.
Old 08-17-2009, 04:43 PM
HMAX08's Avatar
wow, but i think i got you beat, ask Ascendant. Picture this d3, ipod cable, nird, bluetooth, xm, pacws plus all the extra rcas' running back there. but its a labor of love. i love the bluetooth works soo great. thanks again for the pics. It helped me realize i was not missing anything
HMAX08 is offline
Old 08-21-2009, 10:32 AM
rideordie1000's Avatar
Where did you start when removing all of the console paneling? I can seem to get my (non-navi) factory stereo out. Sorry...Im a newbie
rideordie1000 is offline
Old 08-21-2009, 11:12 AM
1hawaii50's Avatar
The "search" button is your friend. I'm pretty sure there is a sticky here, if not, then I KNOW there is one at:
6thgenmaxima.org
Old 08-21-2009, 03:29 PM
6thgenmaxima.org
Thanks for the recommendation 1hawaii50,
I searched both forums and cant seem to find it for the 07 interior. I've found numerous 06's and earlier, but that doesn't help me.
Old 08-21-2009, 05:07 PM
NiZMo1o1's Avatar
Clusterazzfuuuuu !
NiZMo1o1 is offline
Old 08-21-2009, 05:47 PM
1hawaii50's Avatar
http://www.6thgenmaxima.org/forums/viewtopic.php?t=5715
or
http://forums.maxima.org/6th-generat...08-models.html
or
http://www.6thgenmaxima.org/forums/v...=radio+removal
Not much changed between the 06 and 07. The basics are the same as far as the disassembly goes. Remove the shifter handle, pry up the back of the shifter plate with the trans in D and lift it up. The clips on the top of the trim piece just below the temperature controls pull straight out towards you. So, lift straight up on the back and the middle, and once everything is released except for the top clips, pull straight back towards you and remove it. Shift back to park. There are two screws holding the radio trim piece on. You have to look up and under the radio trim piece, to either side of the airbag light. Once those screws are removed you can pull the radio trim piece out starting from the bottom, it pulls towards you, once you have the bottom free, you swing it up towards the ceiling and lift it off. Then you will see 4 screws, one at each corner of the radio assembly. Remove all 4 screws and the whole radio assembly slides out.
It isn't hard, just take your time so you don't break any clips. If you get stuck let me know.
t6378tp
09-29-2018 04:27 PM
mikeg75
11-30-2015 05:12 PM
knight_yyz
11-06-2015 02:34 PM
Pnjboyzz
09-04-2015 09:04 AM
Quick Reply: 07-08 SE Non-Bose: Pics of harness behind radio
