Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-15-2009, 11:37 AM   #1
Apollos2's Avatar
Send a message via AIM to Apollos2
Headers: the affect on my exhaust.
I’ve had my headers on for a while now and it has increased the volume and changed the tone of my exhaust to a point where I didn’t like it that much. Too much of the engine sound was passing straight out the tail pipe via my Nismo cattack system. . I had a pretty good drone and I didn’t care for the exhaust tone either. It was almost too high pitched too rapid. I’ve tried on a couple of occasions to take some video clips but the weird part is that unless the car is under a load it so sounded fine, not as loud and no drone.
My initial exhaust mods:
1. The combination of the Cattman Y-pipe and Nismo catback sounded really good on the car. I liked it a lot. Got plenty of compliments on that set up. Deeper sound very 350ish
2. When I added a catalytic converter to the Y-pipe it changed the tone and volume level of the exhaust and it was fine, not quite as nice but still good.
3. When I added the headers to that combination it wasn’t what I had anticipated
Initial solution was to try and add a second resonator to the system:
But that is basically identical to the Nismo resonator, would two them be enough to do the job?
__________________
Cardomain = Silver stream
Add yourself to the USA Map = Click Here
Boss Wheels/ AT grounding kit / *Tein* Springs / RSB / Fujita CAI / Cattman Headers & Y pipe / Nismo Catback / ID roof spoiler/ NWP Spacers/ Timing advanced 2 degrees / UR SC pulley / Apexi SAFCII / D-S Rotopro Rotors / SS Brake lines / Eclipse - MTX - 8in Free air subs/
Apollos2 is offline   Reply With Quote
Old 07-15-2009, 11:38 AM   #2
Apollos2's Avatar
So I decided to do something different. I went to the local (not Midas type chain) Lakewood Performance Muffler& Brake talked to the owner and decided to go with a 26in glass pack. It looks like this on the inside.
It’s the same diameter on the inside as the rest of the exhaust but the nice thing about this one is that it can be turned around either direction
Ridges going with the flow of the exhaust: Louder
Ridges going against the flow of the exhaust: Quieter.
Old 07-15-2009, 11:39 AM   #3
Apollos2's Avatar
I went with the direction of ridges going with the exhaust with agreement that he would switch it around, no charge if it was still too loud.
It wasn’t been on there for just a day now and I’m really feelin it. Sounds like my Nismo setup when I first put it on. Those ridge slots seem to be absorbing that higher pitched sounds and I’m back to sounding deeper under load. If I can figure out a way to gets some video of it from the outside while I’m driving I’ll get some. Probably just need to have someone take it for me.
Hope this helps anyone with headers and volume/tone issues.
And I will be putting up both the Magnapak and Nismo resonators for sale in the classifieds
Anyway, some random pics
He had one up on the wall for display:
After Nismo removed took a couple of random pics
Old 07-15-2009, 01:41 PM   #4
DeusExMaxima's Avatar
Id did something similar when I had my custom mandrel bent exhaust built and installed. I had two 14" Magnaflow resonators welded together which is larger than the cattman resonator. I also have a single output exhaust. The combination of single output and larger resonators makes for a better sounding exhaust and no drone.
__________________
6 speed manual Lots of mods
Check out my ride here: http://www.cardomain.com/ride/760206
Watch the fraud our government is perpetrating on the people - www.zeitgeistmovie.com
...get out of the way you old hag, you're messing up my cornering
DeusExMaxima is offline   Reply With Quote
Old 07-15-2009, 11:26 PM   #5
Nice! You will have to try and get a video eventually!
__________________
Oolatec is offline   Reply With Quote
Old 07-16-2009, 12:34 AM   #6
Send a message via AIM to Decimus Meridias
I can't wait to hear it. Thanks for the info.
Decimus Meridias is offline   Reply With Quote
Old 08-04-2009, 07:57 AM   #7
Nice, have you posted the vid with the sound yet?
filipinowise09 is offline   Reply With Quote
Old 08-04-2009, 01:55 PM   #8
Send a message via AIM to slvrmax7 Send a message via Yahoo to slvrmax7
Thx for posting this, I will keep this in mind when my headers are installed.
__________________
[u]'04 Onyx SE 5AT, 6.5 conversion, 7 Gen 19's & LED mirrors, Cattman Y- pipe / Cattman exhaust, Progress / KYG GR2 suspension, Racingline F/R Endlinks, FSTB, Progress RSB, Custom badges, 3M Tinted....ya get the picture
**Cattman Headers waiting to be installed and 6.5 lip orders placed!
"That's a Nissan!?
slvrmax7 is offline   Reply With Quote
Old 08-04-2009, 03:06 PM   #9
Apollos2's Avatar
I still haven't got a decent vid on it yet, been so pre-occupied with getting rid of my CEL lights. Here is a weak vid that I tried to get after we replace my AFR sensor. Garage was pretty loud so it interfered with the sound a bit. You can see my backup lights are nice and bright after I upgraded them.
I'll try to get something better. Keep in mind I've got that new resonator in facing so the ridges go with the flow, I can quiet it down even more if I turn it around.
(See vid in next post.....)
__________________
Old 08-04-2009, 03:49 PM   #10
Sounds nice and deep! I'll have to keep something like this in mind when I decide to actually change things around myself...
__________________
Old 08-05-2009, 02:47 PM   #11
Apollos2's Avatar
Okay got my dyno tune today. My A/F was off. Found something interesting. The AF sensor in Bank2 which I had replaced last week was showing a correction factor of 1%. The AF sensor in Bank1 which is original to the car was correcting 18-21%. We suspect this one is bad as well and I'll be getting it replaced soon. Both of those sensors should be correcting around the 1% range.
I didn't get my 02 simulators in last night. We will get those in when I put the new AF sensor.
Finally got a decent vid while it was on the dyno. I like it but I may have him turn that resonator around anyway to quiet it down. I don't know yet.
You have to scroll forward about half way to hear it pull.
Same thing on this one, about half way thru.
__________________
Old 08-05-2009, 04:16 PM   #12
If you can, take some pics of the o2 sim installation... I know a lot of people will be so glad to see something more than the instructions (incomplete IMO) that come with them.
So bank 1 is really that much off? That's pretty crazy! Hopefully just replacing it will help!
__________________
Old 08-06-2009, 09:11 PM   #13
Apollos2's Avatar
Yeah it better help. At the street tuner Mayhem I pulled off a 15.377ET Last night I dropped a half second down to 15.8. Not good, hopefully it's that other AF sensor.
I know it can be the sensors too, because the tech put in two from a 350z (they fit) that turned out to be bad, the car was much slower before he just extended my OEMs and put them back. Interesting that AF sensor go bad after headers go in. Just a coincidence?
Old 08-07-2009, 03:46 AM   #14
Quote:
How many miles on the car?
1hawaii50 is offline   Reply With Quote
Old 08-07-2009, 07:59 AM   #15
Apollos2's Avatar
I'm at 88,000 right now. The Bosch replacement I bought says it's good for 100,000mil so it may just be time to replace it.
__________________
Old 09-23-2009, 07:00 PM   #16
I may be swapping out the Greddy resonator for a glass pack by the end of the week... Going to give the 28" Thrush a shot...
__________________
Old 09-23-2009, 09:08 PM   #17
I might go ahead and get one of these because sound is a concern for me, anything to tone it down a little I can dig as long as power isn't being noticeably affected.
__________________
"That's a Nissan!?
Old 09-23-2009, 09:22 PM   #18
I'm fine with volume/grunt... it's just the bees I need to get rid of. lol
__________________
Old 09-25-2009, 05:02 PM   #19
Ok, looks like Flowtech and Jones/IMCO (Same as far as I can tell) both have the louvered cores... Thrush only has perforated, which would be craaaazy loud, and probably even raspier.
Flowtech:
http://www.holley.com/types/Red Hots.asp
Nothing over 24" that I could find.
Jones:
http://www.summitracing.com/parts/JEX-A4540S
They have a 40"... I'll do some thinking... this may be the one I need.
__________________
Old 09-25-2009, 05:11 PM   #20
'Trynna' is not a word
mtrai760's Avatar
Louvered cores like that decrease the effective size of your exhaust, and increase backpressure. It's like taking two steps forward, and one step back, running something like that with headers. You should run at least a 1/2" larger core if you are going to use louvered, so if your exhaust is 2 1/2" diameter, you would want to run a 3" louvered muffler.
__________________
98 SE - VQ35
2k SE - Stock... pretty much
Boost, juice, conversions, been there, done that.
mtrai760 is offline   Reply With Quote
Old 09-25-2009, 05:14 PM   #21
Ahh... didn't think about that...
http://www.summitracing.com/parts/JEX-A4330S/
__________________
Old 10-01-2009, 12:50 AM   #22
Also try welding two smaller resonators together to get a long length. I have two 14" Maganflow resonators for total of 28" of resonator.
__________________
Old 10-01-2009, 12:11 PM   #23
Yeah thought about that too. I'm actually going to pass on the glasspack, and try some mufflers... the last few weeks, the Greddy SP2s have gotten significantly louder... or at least I've noticed the damn buzzing...
I was actually considering the Vibrant 1148s:
http://vibrantperformance.com/catalo...products_id=51
or the 1040s:
http://vibrantperformance.com/catalo...oducts_id=1153
Just have to decide if I want the more stealthy look like you have Deus. Plus, the flat blacks are cheaper too...
__________________
Old 10-20-2009, 02:44 PM   #24
As posted at the "other" site... Rasp is totally gone now:
Ok, so Nick at THMotorsports.com (shameless plug) finally got all my stuff in today... they had the Vibrants since Friday but I wanted to pick up everything together.
On my way home I stopped by a local muffler shop and got everything installed. It's PERFECT now!
Forgot to take a pic of the Magnaflow resonator, but everyone has seen those. lol It's huge, but fits, and works great!
I'll get a video sometime soon.
Too lazy to resize, but you all have broadband, so
Vibrant 1148:
Out comes the Greddy resonator... so tiny! You can see the Magnaflow on the ground:
Muffler going on:
Here it is, at home in the garage:
I should have done this years ago. I absolutely love it. lol
Looks hot, and there's no more rasp! The Vibrants give a very deep rich tone coming out the back.
I'll get better pics of the car with an actual camera, and when it's not so overcast out.
__________________
Old 10-20-2009, 03:43 PM   #25
I love my single 3" Vibrant muffler. Its black too so its more stealth and has a great sound. Nice job!!!
__________________
Old 10-20-2009, 03:56 PM   #26
Yeah these Vibrants are great! Not very expensive either!
__________________
Old 10-20-2009, 04:02 PM   #27
nice!
__________________
maxima.713 is offline   Reply With Quote
Old 10-20-2009, 04:14 PM   #28
Thx man very nice!!! My cattman headers should be arriving next week, now all I have to do is install them when I do my manual swap...
__________________
"That's a Nissan!?
Old 10-20-2009, 04:17 PM   #29
pretty sure it will sound good.
ottmar0 is offline   Reply With Quote
Old 10-20-2009, 04:53 PM   #30
Quote:
While you are doing that, get the front and rear motor mount inserts from Racingline!
__________________
Old 10-21-2009, 10:53 AM   #31
Ok here's the new vid:
http://www.youtube.com/watch?v=VE-Xa8tpLc0
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
