Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-03-2009, 08:57 AM   #1
thermostat problems
my a/c works well but if you set the temperature at higher than 61 it blows steam not cold air my outside temp. read is always the same -22f any one what can be done do correct this i would appreciate it i have an 07 max no longer has a warranty thanks
avlk613 is offline   Reply With Quote
Old 07-03-2009, 03:15 PM   #2
The vapor you are seeing is probably excess moisture on the evaporator caused by high humidity. It should dry off in a few minutes after you turn on the AC.
Mrbizness1 is offline   Reply With Quote
Old 07-05-2009, 01:06 PM   #3
i was not clear what i meant i didnt mean that steam comes out i meant that the heat comes even at a low temperature anything above61 the heat comes out of the vents and not cool air a/c
Old 07-05-2009, 04:07 PM   #4
Send a message via Yahoo to po8pimp
Have your A/C recharged and then tested for leaks. Something is wrong.
__________________
po8pimp is offline   Reply With Quote
Old 07-05-2009, 04:45 PM   #5
Quote:
Ok, it sounds like you might have a calibration problem. If the AC compressor is engaging and the lines get cold then the AC should be ok but the air flow behind the dash is not being directed correctly. Generally when you adjust the temperature you are moving the air from the evaporator towards the heater core or the other way depending on the outside temperature. I am not good at explaining this, perhaps someone else can do a better job.
Old 07-05-2009, 07:10 PM   #6
considering this to be the problem how would i fix it also if this is correct that means my outside temp. read is a different problem?
Old 07-05-2009, 08:21 PM   #7
Their is a inside temperature sensor under the dash on the L. side and one behind he front bumper for the outside temp. You might be able to test it with a multimeter. You might be better off paying a little more to have a dealer check this out, they are usually more familiar with this kind of stuff. This is the only photo I could find. I found it on my library website.
http://i142.photobucket.com/albums/r...tempsensor.jpg
Old 07-06-2009, 08:51 AM   #8
thank you for your help
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
