Motor Mount Insert Issue
Old 05-06-2009, 06:05 PM
Where is my shirt?
GrimMax's Avatar
Whats up homies!!
Recently I tried to get the MMI's installed by my shop out here in NY. They said that the MMI's were "slipping and popping" off everytime they tried to place them in. They decided to cancel the mod until I get some feedback from you guys. So for you guys who got the MMI's installed, did you have any issues also? Is there a certain way to get them installed?
I am auto 5-Spd BTW. Thanks fellas!!
GrimMax is offline
Old 05-06-2009, 06:34 PM
Puppetmaster's Avatar
What sort of inserts do you have? Energy Suspension? Regardless, any competent shop with a good machine press should be able to press them into the motor mounts. I don't believe I've heard many issues when taken to shops with a press. When Tilley (TILLEYS99) helped me with mine, he actually used a wall mounted spring compressor, couple 2x4s, and Crisco, and we were able to pop them in.
Puppetmaster is offline
Old 05-06-2009, 07:21 PM
NiZMo1o1's Avatar
You really need to play with them on the 6th gen.. The Racingline MMIs need to be sqeeuze it tightly , We did it by hand but we had to go caveman on it.. its a PITA but onces its in there your good, Didnt have to go thru a press or grease.
mines been on for 2 years
NiZMo1o1 is offline
Old 05-07-2009, 10:42 AM
slvrmax7's Avatar
Hey GrimMax let us know when you get them installed successfully and where, I've been dying to get these installed. Vipervadim might be worth getting a hold of if it's tough finding a shop though, IIRC he said he could def. help with it. Best of Luck.
slvrmax7 is offline
Old 05-07-2009, 10:58 AM
Where is my shirt?
GrimMax's Avatar
Not sure. I do have the racingline ones though.
GrimMax is offline
Old 05-07-2009, 10:59 AM
Where is my shirt?
GrimMax's Avatar
lol caveman huh!? Yeah my shop said that they just kept popping off?? Did you use anything to hold them on?
GrimMax is offline
Old 05-07-2009, 11:00 AM
Where is my shirt?
GrimMax's Avatar
Yeah Viper is trully an expert! I am gonna see him soon to rewire the O2 sim. I will def let you know when they are in and where. Thanks bro!
GrimMax is offline
Old 05-07-2009, 11:11 AM
Oh okay, nevermind then. Those are the ones that just fit into the gap in the stock insert, right? I've no experience with those, only the full insert replacements. Hope you get it worked out.
Old 05-07-2009, 01:42 PM
Oolatec's Avatar
Had no problem with my front one... it just slid right in. *shrugs*
Oolatec is offline
Old 05-07-2009, 01:44 PM
NiZMo1o1's Avatar
I try to sqeeuze them on tightly..they will try to pop out ,, try to get it in the subframe and screw it in asap
Thats all i can remember because its been so long.
good luck
NiZMo1o1 is offline
Old 05-07-2009, 02:12 PM
blaxima06's Avatar
Sorry for my ignorance, but what is a motor mount insert? Whats the purpose for it?
blaxima06 is offline
Old 05-07-2009, 04:07 PM
NiZMo1o1's Avatar
your OEM mounts have some play, by installing the inserts , its strenghs the mounts so your elimanate play.http://www.racinglineperformance.com...a46996ce6d53a2
NiZMo1o1 is offline
Old 05-07-2009, 08:00 PM
blaxima06's Avatar
Thanks bro for the info!
Old 05-07-2009, 08:08 PM
yunior32's Avatar
??? hu chinesse to me lol
yunior32 is offline
Old 05-07-2009, 10:22 PM
NiZMo1o1's Avatar
NiZMo1o1 is offline
Old 05-08-2009, 08:10 AM
Nations 1st 6th Gen Turbo
chernmax's Avatar
PM sent, can be done...
chernmax is offline
Old 05-29-2009, 10:33 PM
hecmaxi's Avatar
Where can i get replacement front motor mounts?
I'm looking to replace my front under the radiator. its has a sensor attached to it.
hecmaxi is offline
Old 05-29-2009, 10:57 PM
DeusExMaxima's Avatar
I have had mine for a long time on the shelf so I need to get crackin and get these in.
DeusExMaxima is offline
Old 05-30-2009, 06:39 AM
cfr94's Avatar
x2. You got the Racingline Performance MMI's also?
cfr94 is offline
Old 05-30-2009, 04:59 PM
NiZMo1o1's Avatar
your local nissan dealership or
http://www.courtesyparts.com/default.php
NiZMo1o1 is offline
matts95max
Yesterday 01:16 AM
The Frye
09-02-2021 11:03 AM
AcuraLegend
10-17-2016 08:47 PM
Maxima30
09-07-2015 06:13 PM
intimidator
09-05-2015 07:23 PM
Quick Reply: Motor Mount Insert Issue
