Rear Suspension
Old 04-22-2009, 01:01 PM
BETO6700's Avatar
Rear Suspension
I look at my car and it looks like the rear is squatting down, I don't know if it is normal. I have seen other maximas and they also look like the rear is squatting, but the newer models 2007-08 don't.
I just wonder if the spring or shocks are weak and it is time to changed them, I will post a picture to show you what I mean exactly.
BETO6700 is offline
Old 04-22-2009, 01:16 PM
BETO6700's Avatar
BETO6700 is offline
Old 04-22-2009, 01:17 PM
Nismo4life07's Avatar
the front wheel well is bigger than the rear wheel well. thats the reason it looks like it is squatting.
Nismo4life07 is offline
Old 04-22-2009, 01:30 PM
MadMax07SL's Avatar
My 07 looks like that too.
MadMax07SL is offline
Old 04-22-2009, 02:05 PM
hey11101's Avatar
Im not sure why nissan did this. I do not notice this on any other car models.
hey11101 is offline
Old 04-22-2009, 02:09 PM
my altima was the same way... its just because the car is a fwd. they make the wheel wells in the front slightly larger than the rear to accomodate the movement of the front tires.
Old 04-23-2009, 03:41 PM
Talon05's Avatar
Glad you posted this thread. I have the same issue and it looks strange when sitting in the parking lot. I also thought the shocks or springs required replacement. However if you look at the 08 with stock equipment it looks like both tires are even. By the way can someone tell me if 4 inches for the front wheel well to tire(245-45-18) is normal.
Talon05 is offline
Old 04-23-2009, 04:25 PM
04LowLife's Avatar
Its the same way on the new chevy trucks too
04LowLife is offline
Old 04-23-2009, 04:57 PM
coolmax05's Avatar
One thing that definetly improves with a higher a wheel-well is road noise levels. Proximity is a big factor in determining the amount of noise.
coolmax05 is offline
Old 04-24-2009, 08:21 AM
ubersl's Avatar
Anyone can tell me where to look for rear shock mounts: in the trunk on under rear parcel shelf? Going to replace the whole setup with KYBs and need a little insight. Is there a write up on the rear replacement? I found one for the front, but not the rear.
How critical is it to use a torque wrench when tightening suspension bolts and nuts? Or as long as I don't overtorque it I'll be fine? Thanks in advance.
ubersl is offline
Old 04-24-2009, 10:38 AM
2LEET4U's Avatar
1. do you have a sub or system in your trunk?
2. remove your spare tire from your trunk. it will remove 20-30 lbs.
3. lower your Max with some after market springs. it will help the front end look much better.
2LEET4U is offline
Old 04-24-2009, 10:44 AM
2LEET4U's Avatar
nissan dealership....
it is always best to use the t-wrench but as long as you dont put a lot of strain tighting the bolts you should be fine.
2LEET4U is offline
Old 04-24-2009, 10:54 AM
MadMax07SL's Avatar
Yeah, cause you almost never use that spare tire, it just sits back there doing nothing...except provide some peace of mind if you should ever lose a tire...
Old 04-24-2009, 10:59 AM
2LEET4U's Avatar
i only use my spare when i go on long road trips. other than that, i have 24/7 tow services. (flat bed tow truck please). Insurance covers cost of tow.
I did notice the back of the car rise a little with no spare.
2LEET4U is offline
Old 04-24-2009, 11:21 AM
MadMax07SL's Avatar
I'll never be stranded because of a single flat tire. And what if you're an hour away from home, and you got someplace to be, or it's late. Do you really want to wait another hour for a tow?
Naa, I'll keep the extra 30 lbs for that added reassurance that I can get out of a sticky situation by myself.
Old 04-24-2009, 01:03 PM
the macedonian's Avatar
on #3
on #2, I am not sure I have the ball$ to remove it because with my luck I'll end up getting stranded where the moose play - if you know what I mean...
the macedonian is offline
matts95max
Today 01:16 AM
doctorpullit
09-10-2015 06:33 PM
ef9
09-05-2015 11:18 PM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: Rear Suspension
