Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-26-2009, 02:10 AM   #1
Nismo 19 on 08 max...
ok... i kinda got tired of searching the forum with this specific concern... i have an 08 maxima with 19 inch nismo rays with 245/45/19 s drives... im currently having rubbing issues with the rear wheels (and probably will have it in the front as well if i drop the car) if someone or anyone at all rides at the back.. my suspension set up, as of now, is all stock... but i am having difficulty moving on with my suspension mods because of this...
>since its a "nismo", should it rub in the first place?? (basically, did i do it right?)
>>how could it be fixed?? (i was told to roll my fenders.. is that my only option?)
i have noticed that alot of you have 19s, 20s, 22s with wider and/or staggered rims and have no problem at all with the rubbing..
any experiences, comments, help, or suggestions will be greatly appreciated.. please..
morteljc is offline   Reply With Quote
Old 03-26-2009, 02:40 AM   #2
Your plus sizing is off my friend. You need a 40 profile tire on that setup. I'm no wheel expert, but from the numerous posts I've seen on this board you either go 40/19 or 35/20 when you plus size on our cars. I have heard of instances where 1 or 2 people on here have fit 40/20 on the max without rub. Maybe they've rolled their fenders somehow. See if you could exchange those tires for 245/40/19 and you will be good to go.
Asav is offline   Reply With Quote
Old 03-26-2009, 05:59 AM   #3
Should have went with a 245/40/19
SpooledVQ35 is offline   Reply With Quote
Old 03-26-2009, 07:00 AM   #4
FTR - I have and '07 with the 19" Nismo and 245/40/19 and my rear passenger wheel rubs when people are in the back (including just 2 light kids).
I've actually loaded up the trunk with weights one time and had people sit in the back so I can see the clearance while the car was still and it seems to be clearing the fender by an RCH. And I would imagine that as bad as the rubbing can be sometimes that there would be some noticable damage to the fender or the tire, which there isn't.
There is also a bolt with a plastic cap that at the top center of the wheel that holds the wheel well liner in place. It's possible that the offset is enough that the stock narrower tires just clears it but the wider 245s just contact it enough. I've removed the plastic cap, but the leaving the exposed bolt worries me more with making tire contact than the plastic cap.
I see all these Maximas with much larger tires and wheels than the 245/40/19 without issues and it baffles me.
I've actually brought this to the dealer one time and they were useless. So useless that they actually tried to compare the offset and wheel gap to an Altima coupe with the Nismo's in the showroom. And of course, they couldn't reproduce the noise.
Maxima TL is offline   Reply With Quote
Old 03-26-2009, 08:04 AM   #5
Do you have stock springs...are they SL springs or SE springs. I ride on progress with GR2 shocks and no rubbing issues even with people in the back.
__________________
Dan formally coitaltie
Nismo CAI- Nismo Ray's Engineering 19's- Nismo full catback exhaust-Nissan 300zx TT aluminum calipers- Progress RSB- Racingline V2 endlinks rear- Progress lowering springs- KYB GR2 struts and shocks- Racingline FTSB OEM look- Active Tuning custom grounding kit- Active Tuning S4.1 grill- Custom Enterprise Y pipe- Unorthodox Racing Underdrive Pulley- Optima Red Top- JL W3V3- JL 500/1 v2 amp
VigilanteMax is offline   Reply With Quote
Old 03-26-2009, 08:36 AM   #6
Not to hijack, but mine is an SL with stock suspension. And it's only the right rear.
Old 03-26-2009, 08:40 AM   #7
Someone needs some new shocks... Stock rear shocks suck! Get some GR2's.
__________________
CarDomain Page: http://www.cardomain.com/ride/3122927
2LEET4U is offline   Reply With Quote
Old 03-26-2009, 08:57 AM   #8
What he said.
The one shock on that side is probably bad. However, if you are going to get that one done, you might as well do them all. It's only a matter of time before they blow. I have 51k on an SE and I need struts and shocks NOW so I'm doing the suspension Sunday.
Old 03-26-2009, 10:02 AM   #9
Quote:
Quote:
lets say i'll go with 40s or 35s.. once i put passengers in the back will make it rub.. right?
Quote:
its an SE..
how is the GR2 different from stock?
Old 03-26-2009, 11:27 AM   #10
KCmaxx's Avatar
It's been said, tires are too tall...
__________________
Quote:
Originally Posted by Kryogen View Post
Thanks for the constructive comments and help KC, as usual, your posts are very relevant.
KCmaxx is offline   Reply With Quote
Old 03-26-2009, 11:51 AM   #11
Quote:
Actually, that's not true at all for me.
The recommended tire size for the Nismo wheels is 245/40/19, when compared to the SL stock 17's of 225/55/17 they are almost the identical height and circumference
The 17's have an overall diameter (including tire) of 26.74"
The 19's have an overall diameter (including tire) of 26.72"
Old 03-26-2009, 03:15 PM   #12
I'm running 245/45/19 with no rubbing issues what so ever. Stock suspension and got a ton a crap in my trunk and two small kids everyday, like I said not one rub ever.
__________________
AfterBurn!!!
Gianniali is offline   Reply With Quote
Old 03-26-2009, 07:52 PM   #13
probably (or definitely??) its the offset that killed me... is there any fix?
Old 03-29-2009, 12:51 PM   #14
recommended is 245/40/19 is what I ride on my Nismo's and car is dropped never had rubbin issue with or without passengers...
__________________
2theMaX05 is offline   Reply With Quote
Old 06-29-2009, 06:24 PM   #15
Anyone have an pic of these nismo rims?
06maximabadwaddle is offline   Reply With Quote
Old 06-29-2009, 07:45 PM   #16
Send a message via AIM to MaxJ04
not an 08 but 04??? lol ... 245/40/19's recommended by tirerack.com
__________________
MaxJ04 is offline   Reply With Quote
Old 06-30-2009, 10:25 AM   #17
That looks so sweet! how much u drop on them ?
ahhbeemo is offline   Reply With Quote
Old 06-30-2009, 02:35 PM   #18
Sweet rims
Old 06-30-2009, 04:19 PM   #19
Quote:
clean as max bro. for u. lol
__________________
If NISMO stands for Nissan Motorsports, does HOMO stand for Honda Motorsports?
Quote:
Originally Posted by mymaxi41691 View Post
Because this isn't a honda forum?
maxed_out_saloon is offline   Reply With Quote
Old 06-30-2009, 07:47 PM   #20
.org extraordinaire
kamski's Avatar
Send a message via MSN to kamski
HOT!!!!!!!!!!!!!!!
I ran 255/40/19 and no rubbing. Mine was lowered on Progress springs
Kamski
__________________
2005 SE 6SP, Fujita CAI, Progress Springs and Swaybar, Redlinegoods Leather Boots, HID 6K FOGS, Nismo Rims, Toyo Proxes T1R, Wilwood BBK 13.6" slotted fr, slotted rear, racingline endlinks, racingline motormount inserts, racingline strutbrace, UDP, Koni F, AGX R
PLEASE BUY MY STUFF, Will miss you guys.[/font][/color]
kamski is offline   Reply With Quote
Old 06-30-2009, 10:59 PM   #21
weird... i'm still rubbing at 245/40/19..... stealership said that it was indeed rubbing and it was due to the offset... what if i go 235 and or 35? will that work?
Old 07-01-2009, 04:00 PM   #22
Quote:
Stay 40's, 35's would ride like crap. stealership dont know what whey are talkin about maybe roll that side abit
__________________
Old 07-01-2009, 09:23 PM   #23
its both sides that rub tho... and rolling really looks like is my last option... any other comments?
Old 07-01-2009, 11:48 PM   #24
Send a message via AIM to 6spBaDAsS6ThGeN Send a message via Yahoo to 6spBaDAsS6ThGeN
i have 235-35-20 my wheels ofset is +38 and its slammed like three inches on ksports with not ever a single rub front or rear and the front are also almost tucked the back is tucked to the point were u dnt see much tire... a little to low in my opinion probably gunna raise it some this weekend basically i was just stateing that its not just the tire the offset of the wheels comes into play when your trying to cram it up there lol
P.S.- in regard to the comment 35's ride like i crap??? i have them with k-sports and its amazing... not a stock ride anymore but i look at it as i can feel the road lol
__________________
(6sp ELITE),CUSTOM SPUARE TUBEING STRUT BAR,NWP BLOCK PLATE,EBAY CATBACK LOL "SOUNDS NICE" BLACKED OUT FRONT LIGHT HOUSING,KENWOOD KVT-512,K-SPORT COILOVERS
6spBaDAsS6ThGeN is offline   Reply With Quote
Old 07-03-2009, 12:09 AM   #25
Send a message via AIM to carlosr
You have the correct tire size but whats the offset and width of the rear rims. If they rub on inside (brake/suspension side) you can get spacers rather cheap, the outside you'll have to roll the fenders
__________________
Common sense is anything but common!
carlosr is offline   Reply With Quote
Old 07-03-2009, 12:30 AM   #26
Those rims look sick on the car...
Anyways i have a question that has nothing to do with this post..but
I am trying to start a thread but i don't know how to post stuff how do i do it?
I already posted more than 15 posts..
joer_561 is offline   Reply With Quote
Old 07-03-2009, 12:34 AM   #27
offset is +35.. the fenders are slightly rubbing on the sidewall of my tires.. but what i dont understand is why some people have the same set up i have but they dont rub.. again its an 08 maxima.. i dont know if something is different with the 6.5 gens vs the 6th gens...
how about going for 235/40/19?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
