I'm stumped on this, hoping you guys can help me out.
I have a bone stock 2007 Maxima SE, just under 20k miles. Starting today, I've noticed a problem with the driver's side door request switch (the button on the handle to unlock the door). When I first walk up to the car and press the button, nothing will happen. I can press it 100 times, nothing happens. Passenger side request switch works great. Trunk request switch works great. Once I hit either of those, THEN the driver's side button works fine. If I hit Lock or Unlock on the keyfob first, that works, and then the driver's side request switch works fine again. But something's happened where that switch is "asleep" until something else is triggered first. This behavior also applies when I'm driving, park the car and attempt to lock it with the switch.
A weird side observation: Let's say I walk up and hit the button -- nothing happens. I hit the keyfob Lock button, the car locks and honks, THEN it beeps and unlocks -- like the button received the request to unlock but got stuck somewhere...then once I hit the keyfob, everything cleared up and it carried out the request to unlock.
I've dug through the manual, didn't find anything that could point to a solution. Power is obviously coming to the switch and the door. Could it be something like low battery voltage? Battery's not low on the keyfob (no warning when I start up the car and I can lock/unlock from 50 feet away). Something tells me voltage or a circuit board, but it could be very expensive to find out and it's not broken, just...ornery. I did find this online, but it sounds like the guy didn't try to troubleshoot like I did:
http://www.justanswer.com/questions/...handle-request
Any suggestions folks? Thanks in advance!
