How do you bleed your brakes?
Old 03-11-2009, 06:36 PM
Kryogen's Avatar
How do you bleed your brakes? Do you guys use a 1 person bleeder bottle? Or just a can of coke with fluid in the bottom?
Have you ever noticed a difference after bleeding?
Kryogen is offline
Old 03-11-2009, 06:59 PM
mynameispee's Avatar
bleed your brakes if you believe your brake pedal is spongy. easiest way but definitely not the fastest would to gravity bleed your calipers. just crack them open a bit and the air bubbles within the system should purge on their own. just make sure you don't let the master cylinder empty, keep the fluid level in check.
mynameispee is offline
Old 03-11-2009, 07:28 PM
Kryogen's Avatar
I believe it's spongy. I feel like it doesnt brake well. Ill prolly change pads and rotors this summer, and I bet, bleed.
Kryogen is offline
Old 03-11-2009, 09:59 PM
Playa_FL's Avatar
You will need two people. Have a guy sit in the car and you can be at the caliper with a bleeder wrench on the screw. Have the guy inside pump the brakes about 10 times, and on the 10 tell him to hold it. You crack open the bleeder screw until its all squirted out, then close the screw, and have the guy repeat the process. Do this about 2-3 times per wheel and see how it feels.
Playa_FL is offline
Old 03-12-2009, 09:36 AM
MAXIN' ON
redls1's Avatar
Also go
lr
rr
rf
lf
redls1 is offline
Old 03-12-2009, 05:06 PM
MikAus's Avatar
Not for sure, but I thought it was in order of farthest from the master cylinder.
ie right rear, left rear, right front, left front
MikAus is offline
Old 03-12-2009, 05:24 PM
KC's FINEST
KCMAXX's Avatar
Great thread...
KCMAXX is offline
Old 03-14-2009, 06:58 AM
Kryogen's Avatar
The manual says to disconnect the abs actuator. where is it and do you just unplug it? anyone has done it?
Kryogen is offline
Old 03-19-2009, 06:11 PM
texoma's Avatar
just got my maxima back from the dealership, and they said i need new brake fluid as mine is black. My stepdad calls b.s. on the dealer because "i've driven cars for 50 ***** years and never had to replace brake fluid". I think it's not a bad idea, so I'm gonna attempt this soon.
texoma is offline
Old 03-19-2009, 08:04 PM
Kryogen's Avatar
I've heard the "never replaced brake fluid thing", but I think its a good maintenance idea (to replace it every 2 years).
Kryogen is offline
Old 03-19-2009, 08:55 PM
.org extraordinaire
kamski's Avatar
Originally Posted by Kryogen
I've heard the "never replaced brake fluid thing", but I think its a good maintenance idea.
Yes especially if you live in cold climates and the stock stuff boils over easily also.
Kamski
kamski is offline
Old 03-25-2009, 11:20 PM
1993-VG30E-GXE's Avatar
I agree - it really is a good idea to do it, the corrosion inhibitors will break down over time and the rustiness will appear in the fluid close to the caliper. Notice when you bleed it you'll see dirty fluid come out initially. I don't believe that dealer guy though saying it's black - unless they are using some space age fluid - I can't see how it goes black. Maybe rusty nasty green or brown....but black seems far fetched.
1993-VG30E-GXE is offline
Old 04-03-2009, 05:17 PM
maxman7's Avatar
The Dual proportioning valve is on the firewall on passenger side it is down in there enuff to where ya really have to hover over area to see. It looks like this. a alluminum color about 3 or 4 inches log with all four brake lines coming out of ,I cant remember which is what wheel but anyway if ya let enuff air up into the system thru caliper it has a flap inside that will close off that line. So you cannot get any fluid thru that line once the flap shuts and therfore ya have to go to the proportioning valve and purge it there first to get fluid srarted back down thru line again. It is a safety device it keeps all other lines air free and funtional in case of a catastrophic failure like a bursted line. The other three lines wont fill with air and fail. I learned this the hard way when changing a caliper dumba-- me took the caliper off let the line sit and drip while I went and got a new caliper ( I was saving myself a trip back to parts house to get core charge back) What an Idiot oh well ya learn from these screw ups at least I didnt overpay some dealer to fix it. Lesson learned always have the new caliper right ther and ready to go also leave bleeder loose on new one while installing and wait for it to start dripping thru ya wont have hardly any bleeding left to do thus way I learned that from my Dad. Hope this helps someone someday cause that is a tricky little issue, Ya pump and pump and have a full master cylinder but never get a drop thru the line,also the ABS light will come on over this but will go back off after ya bleed the actuator. any questions or advice I may have left out would be great to add to this thred it may help someone out. maxman7.PS. I had to call four brake mechanics to solve this.
maxman7 is offline
04-16-2020 05:15 AM
06-06-2017 02:01 PM
leatherneck
09-30-2015 09:16 PM
HerpDerp1919
09-29-2015 02:02 PM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: How do you bleed your brakes?
