As many of you may or may not know our cars are prone to Catalytic Converter Failure.
Our cars have three catalytic converters. One in the Y-Pipe, I've never heard of this one failing. Your can WILL pass emissions test with out it. (It may not pass a visual though, depending on how you may have eliminated it). I know a guy
who bored his out even though I've heard we have very efficient cats in the Y-Pipe, it didn't make his car faster but he was still able to pass emissions. Visual and exhaust. Lesson: don't waste your time eliminating that cat.
We also have two catalytic converters at the back of the engine compartment. I believe they mount to the bottom of the exhaust manifolds. These are the ones that can fail. They can melt, restricting flow, and/or eventually start to break apart. If they start to break apart, the particals can potentially get sucked back into the engine: failure.
If one of the two pre-cats start to fail you should get a
Service Engine Soon light. You can always go to Autozone and they will pull the code for free.
Pre-cat failure codes:
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
P0430 - Catalyst System Efficiency Below Threshold (Bank 2)
I believe these pre-cats are covered under the emissions warranty which goes until 80,000miles. All of the failures I know about occured before 80k.
My Service Engine Soon light came on yesterday. I went to Autozone and pulled code: P0420 - Catalyst System Efficiency Below Threshold (Bank 1).
I'm at 80,200 miles.
I could go back and ask Nissan them to cover it under good will or something like that. Not sure if it would work to well. They already fixed my AC that way.
MSRP on the right cat = $757
MSRP on the left cat = $550
Headers = under $700
So I have opted to go the header route and not have to worry about it. I called Brian (Cattman) placed my order. 1 set headers, 1 cat to weld into my existing Cattman Y-pipe. ETA 4 weeks
I'm not to sure what I will do with the car until then. I hate to drive it around and risk jacking the engine.
Here are a couple of other threads on the topic:
http://www.6thgenmaxima.org/forums/v...hlight=clogged
