Problem with odometer
Old 01-30-2009, 05:46 PM
trackstarz04's Avatar
Ok guys heres my problem. One day my odometer and gear selector started flickering, and now they totally went out. They come on and off every once in a while, so I'm thinking it may be a loose wire? Let me know what you think. I will post pics a little later of what I'm talking about.
trackstarz04 is offline
Old 01-30-2009, 05:52 PM
NiZMo1o1's Avatar
check your battery , may be low voltage unless its a wiring issue..
PM WinterFraust
NiZMo1o1 is offline
Old 01-30-2009, 05:56 PM
PM WinterFraust
I think it may be a wiring issue, because i just had the gauge cluster replaced last summer.
Old 01-30-2009, 05:59 PM
-Sin-'s Avatar
Now you can drive it without racking up the miles
-Sin- is offline
Old 01-30-2009, 06:01 PM
Haha i wish but every once in a while it will flicker back on to remind me
Old 01-30-2009, 07:20 PM
Shoey1's Avatar
odometer runs from the computer...your still getting the mileage recorded you just cant see it...there is probably a plug in the back that might have come loose. there is some one on here doing LED conversions for different colored gauges and stereo buttons and what not. he would be the guy to talk to about taking it apart properly
Shoey1 is offline
Old 02-02-2009, 04:53 PM
Max2000SE's Avatar
dimmer switch? when you say odometer flickering do you mean the light, or the digital numbers themselves?
i had a similar odometer problem a few months back and they had to replace the internal circuit board and have the mileage reprogrammed. took 4 days to get it back.
good luck
Max2000SE is offline
Old 02-02-2009, 04:56 PM
good luck
The light works fine, its the numbers themselves. They flicker on and off when they feel like it.
Old 02-03-2009, 02:27 PM
Max2000SE's Avatar
it sounds like the connection to the gauges or the board. my mileage disapeared, then would come back every once in awhile, but sometimes it said crazy $hit like (sort of like when a digital watch dies, you see 888888). in my case the computer board was replaced, but for you it sounds more of a connection issue.
Old 02-04-2009, 05:28 PM
I believe it is the connection. I'm gonna take a look at it this weekend and find out.
hcarter1112
42
07-18-2022 03:35 PM
06-06-2017 02:01 PM
Unclejunebug
04-02-2016 05:42 AM
Noela
09-26-2015 08:22 AM
Quick Reply: Problem with odometer
