egr valve and catalytic converter
Old 02-26-2007, 07:59 PM
EdRomo86's Avatar
so my service engine soon light comes on the other day so i take it the shop to get the code pulled. i think it was p1402 which said it was the egr system. turns out the egr valve and my catalytic converter are bad due to carbon build up in the egr valve that made the catalytic go bad. i have an injen intake and was wondering if maybe this was the cause of the egr and catalytic going bad. what do you guys think? before i took it to the shop i put tmy stock air box back on but now that it is going to get fixed i am debating on whether i am going to put my injen back on. the good thing is that under federal emmision laws the catalytic converter is covered up to 80,000 miles by nissan. the only thing that is not covered is the egr valve which is like 160. it just made me mad that nissan will cover the catalytic converter but not the part that made the cat go bad (egr valve). the cat is like $800 just for your guys information, plus install and reprogramming your looking at over a grand. good thing it it covered. i am currently at 58,000 miles. you guys think the injen intake is to blame?
EdRomo86 is offline
Old 02-27-2007, 05:42 PM
madmik's Avatar
P1402- EGR stuck open, bad EGR temp sensor is keeping EGR open, or loose connection/broken wire. Cannot see how Injen CAI is a contributor.
In my humble opinion, if the EGR is stuck open because of carbon build up, you are either running way rich or burning oil. Are you burning oil?
Do a bit of research on the EGR valve warranty. Since this is an emission component, why not covered until 80K also? Especially in Cali.
madmik is offline
Old 02-28-2007, 04:56 AM
edjose17's Avatar
There is a TSB about this code. Print the following and talk to your Nissan dealer about it. They may do the repair at no charge.
http://www.nissanhelp.com/Ownership/.../NTB05-037.htm
edjose17 is offline
Old 02-28-2007, 06:00 AM
Nations 1st 6th Gen Turbo
chernmax's Avatar
Great Info
chernmax is offline
Old 03-01-2007, 12:55 PM
EdRomo86's Avatar
thanks guys. madmik i sent you a pm.
EdRomo86 is offline
Old 03-01-2007, 04:53 PM
madmik's Avatar
The TSB is about debris keeping the EGR open. His is carbon buildup. NISSAN may not cover. I suspect they could clean up the EGR instead of replacing it.
On other forums, they mention the EGR problem on higher mileage engine 80K +. I am surprised at 58K. Some say it can be the result of using 'cheaper' gas, not enough cleaning agents. Are you using regular instead of premium?
madmik is offline
Old 03-01-2007, 06:05 PM
I Donate! Why Don't You?
xoomer.com's Avatar
Where would these metallic pieces come from??? CC???
xoomer.com is offline
Old 03-01-2007, 06:11 PM
EdRomo86's Avatar
they said the egr was not covered. only the cat but at least they are covering that because that it the most expensive part. i have always used 91 octane.
EdRomo86 is offline
Old 03-02-2007, 07:55 AM
edjose17's Avatar
Yes, the catalitic converter. But the important thing they do not say is what causes the CC to breakup like that. ??
edjose17 is offline
Old 01-15-2013, 03:00 AM
MiaRaider81's Avatar
I have a 2004 maxima and I had to replace the three way catalytic convertor at 74,000 miles but dealer did not cover cause the 8 year warranty had expired in January and we were in November. they got me........
MiaRaider81 is offline
TKHanson
11-24-2018 01:39 AM
tseng1023
10-15-2015 08:30 AM
hayne
10-05-2015 11:53 AM
09maxshawn11
09-30-2015 10:28 AM
sliptap
09-30-2015 05:57 AM
Quick Reply: egr valve and catalytic converter
