Catalytic Converter causes Mass Air Flow Sensor to go bad
Old 12-31-2009, 07:30 AM
uavscrappy's Avatar
Happy New Year to everyone. So I had a SES Light on for the longest because I was told it was my O2 Sensors by Autozone. So I let it be. However under my parents request I took it to Nissan to have them look at it. They told me that the Catalytic Converter is eating itself up from the inside. Good News is that it is still under warranty. Bad news is he tells me that "IT" caused the Mass Airflow Sensor to go bad and that is not covered under warranty. He is trying to get it covered under the warranty but not sure if Nissan will do it. So my question to yall is should I fight this and how so? Do I go in guns a blazin'? Or do I try the adage "You catch more flies with honey......"? Any help with this would be greatly appreciated.
Thanks again
Scrappy
uavscrappy is offline
Old 12-31-2009, 07:47 AM
po8pimp's Avatar
wait and see what they say. If they give you the run around let the bullets fly. I mean personally I don't see how the MAF could go bad because of the Cat. The MAF is just a sensor that measures airflow and nothing else. It doesn't correct for anything nor does it recieve any inputs. It basically sends data not receive. I would wait it out maybe Nissan will fall for their own crap and think the Cat caused it. I would go with it and argue that if Nissan knows thier cats are bad and are "destroying" themselves while breaking other parts in the process than everything effected should be covered by their faulty product. GL hopefully it works out. If they don't cover the MAF I recommend you buy the JET MAF for our car.
po8pimp is offline
Old 12-31-2009, 08:21 AM
uavscrappy's Avatar
Good call I will do that. If **** gets deep I will have them break out books and prove it to me that this caused the Mass Airflow Sensor and why change it when I never specifically said to do so. I wanted to pick my car up but the guy told me it was dangerous to drive because it could break apart at any moment and ingest itself in to the engine. Now I am not a car mechanic but I am an aircraft mechanic, how does a Catalytic Converter that is downstream from the engine and part of the exhaust system hurt my engine? I ask this because when I talked to them yesterday I was told that my car wasn't safe to drive. Didn't make sense then and still doesn't.
Old 12-31-2009, 01:21 PM
uavscrappy's Avatar
Good News. They changed the Catalytic Converter, the MAF Sensor and the EGR Valve all for zero balance and with me not having to say a word. And no more SES light staring me in the face every time I started the car.
Old 01-01-2010, 03:34 PM
po8pimp's Avatar
awesome news
po8pimp is offline
Old 01-01-2010, 04:59 PM
Terrentius's Avatar
Congrats.
Terrentius is offline
Old 01-01-2010, 10:39 PM
STARR's Avatar
The car has 3 cats, the one they are replacing is the pre-cat right on/in the exhaust manifold, during the 4 stroke process of: intake, compression, power, exhaust, during the exhaust cycle and start of the next intake cycle, some exhaust gases will get sucked back into the cylinders.
So as the pre-cats break down, kinda like sand particles, search and you can find members who put aftermarket headers on, and show the cat particles that pour out, those particles score the cylinder walls and eventually lead to oil burning.
STARR is offline
Old 01-02-2010, 07:52 AM
This Space for Rent
Domestic Violence's Avatar
you took the car in on your 'parents' request?
i replaced my MAF sensor for about $15 and 3 minutes of my time. i found a new OEM sensor on ebay and installed it.
Domestic Violence is offline
Old 01-05-2010, 05:37 AM
sclose4's Avatar
Cat code
My "07 max has 37,500 miles on it. Bought it used in March '09 from a Nissan dealer. Found out yesterday the catalytic converter needs to be replace for about $1000.
Question: is 37,000 miles about the right time for this expensive repari to be made? Of course, I'm 1500 miles past warranty. Any suggetions would be much appreciated.
sclose4 is offline
Old 01-05-2010, 09:35 AM
STARR's Avatar
Catalytic converters are covered for 8 years 80000 miles, take it to a different dealer, you should not have to pay a $1000 for this repair.
STARR is offline
Old 01-05-2010, 05:01 PM
1hawaii50's Avatar
+1 emissions equipment has longer coverage than 3/36K
1hawaii50 is offline
Old 01-15-2013, 03:17 AM
MiaRaider81's Avatar
I wish my catalytic would have gone out earlier, instead it went out at 74,000 miles which was still under the 80,000 that's covered but it was 8 years and 11 months old so they said warranty ended at 8 years! if this is really happening to so many people why hasn't it been recalled?
MiaRaider81 is offline
vingodine
45
05-21-2016 12:46 PM
Maxima_Joe
11-25-2015 08:19 AM
iflexsteel
09-15-2015 03:37 AM
FlaMark
25
08-28-2015 10:15 AM
bc992164
08-26-2015 12:19 PM
Quick Reply: Catalytic Converter causes Mass Air Flow Sensor to go bad
