Thumping noise when turning?
Old 01-10-2009, 07:40 AM
jman7777's Avatar
I've recently noticed while I'm making a turn there is a thumping noise coming from the right front strut area. It happens more often when I have a passenger or two in the car. It only happens when the wheel is turned (while in motion), and going over bumps accentuates the problem. What could it be? CV boot?
jman7777 is offline
Old 01-10-2009, 08:27 AM
90max's Avatar
i think that might be the front endlink bc it happens on turns if it was a thump when u hit a bump i woulda said shocks
90max is offline
Old 01-10-2009, 08:55 AM
2LEET4U's Avatar
1. check your endlink. its a long pole that connects your strut to the front sway bar.
2. check the both bolt that holds your endlink.
3. look at your inner fender for missing plastic push pins. mabe your inner fender cover is hitting against your tire when you turn? it may be lose...
that is all i can think of........
2LEET4U is offline
Old 01-10-2009, 12:39 PM
slick101's Avatar
I feel like I have that 2.... When I am turning right I feel it on the right side not soo much on the left
slick101 is offline
Old 01-11-2009, 09:50 AM
ope2k4's Avatar
I can remember there was a thread with similar issue. Searching might be a good idea. I'll be nice this time lol...
2 possible issues:
1.) If you hear a thumping noise while driving straight going over bumps, it might be your endlink.
2.) If you hear the thumping noise (sounds like a knocking metal) while turning the car in motion), it is an early sign of a bad HUB bearing. Pretty soon you will begin to hear the noise even when youre driving straight as it gets worse.
For easy testing to prove you might have a bad HUB bearing, Jack up the fron end of your car, try pushing the wheel (on the side that the noise is coming from) towards the car. A bad HUB bearing will make the wheel shake side to side.
Hope this helps.
ope2k4 is offline
Old 01-11-2009, 10:48 AM
Shoey1's Avatar
strut mounts?
Shoey1 is offline
Old 01-11-2009, 03:26 PM
jman7777's Avatar
Thank you for sparing me....
2 possible issues:
Hope this helps.
I'll check this out, thanks for the tip.
jman7777 is offline
pears
09-18-2015 05:25 AM
lrb6805
09-17-2015 04:49 PM
LtLeary
09-14-2015 12:33 PM
thenewguyy
09-12-2015 11:12 AM
ballerchris510
09-11-2015 05:29 PM
Quick Reply: Thumping noise when turning?
