Rack and pinion
Rack and pinion
Wow!!! What a day...I took my 05 Max to the dealer for an inspection right.. well they had specials going on so I decided to let them change my oil, oil filter, and get my transmission flushed....I get a call from nissan about 30 mins later telling me that my steering wheel has internal problems (loose) and estimated replacement is $1250. Ok good enough....I picked the car an hour later and they discovered that my rack and pinion is bad estimated replacement is $1500. Have any of you replaced any of these things yet? I only have 78k miles on it and drive my baby with the outmost care so I shouldn't be replacing this yet correct? Has someone tried replacing the steering column or the rack and pinion? Any suggestions on how to do it? Other things they recommended doing is battery maintenance and clamp cleaning, coolant flush, and replace a leaking Upper AC hose......NICE...... my a** got beat today....
I've had my rack and pinion replaced, there was a problem was a squeeking sound that occuried about 20k miles, and it was a pain in the butt to take it to dealership, because it only happened only when I turned right with a slight squeek noise, dealership rule is they cannot repeat it they won't fix it. It was covered under warrenty but I must of taken into the dealership at least 4 times trying to resolve that problem.
I have DPP package and I have always had a little play in the steering wheel that I have always written off to the power adjustable steering column. Do people with the manual adjustable steering column get the shimmy? I am also interested in trying to tighten the steering rack adjustment bolt per the instructions in the TSB without taking it to the stealership; it doesn't seem to be hard to do. Has anyone else tried this at home? I still can get a slight shimmy when the road is not perfectly smooth so I have theorized that if I tighten up the steering rack that it will eliminate the shimmy on imperfect roads.
I always thought the only way to check if the column assembly has problems is to completely take it apart...and would they do that while they do a flush?
I just had a flush and I am having steering column noise and I think they wont want to bother with it unless you know you will pay up
rack and pinion and other things that could be visually detected with out any labor... maybe
get a second opinion
i've replaced one rack in an altima (same part) and that was for play in the rack at the wheels. If the column or shaft has an issue than its something else probably. I'd look at it closely by shaking the wheel and checking resistance vs free play then get a second opinion.
What do you mean by a "loose" steering wheel and what is "bad" with the rack and pinion? Can you give us some symptoms of your problems?
I had my rack & pinion replaced on my 07 Max at 32K miles..... So, yes it could happen at any time.
Do you hear a clicking noise when turning or driving slow???
I had to take mine to the dealership about 4-5 times before they finally diagnosed the right area (at first they said it was the suspension)
1500 for a rack is rather expensive. i'd buy one from a yard and take it to a shop...should be under 1k...if there is honestly anything wrong with it in the 1st place...if you don't notice anything i wouldn't be worried about it myself...
130 is good for a flush from a stealership but expensive for a garage imo...my last one i think was $90 bucks...then again that was 4 years ago...
mikeg75
11-30-2015 05:12 PM
fastcarny
10-12-2015 07:06 AM
Serotta33
09-17-2015 12:14 PM
