Help please!!
Old 01-09-2009, 11:07 PM
jorgep03's Avatar
Help please!!
Hello there, today my battery died and had to buy a new one, after the battery was replaced the ENTRY/EXIT FUNCTION stopworking, (this function is when you turn off the car and the driver's sit and steering column moves to get in and out of the car more easily.
The first thing I checked was the personal setting menu and this option is ON.
Another thing I notice is the BEEP SET on the menu is set to ON, but there is no beep when I press any button.
Any ideas????? after replacing the battery do I need to reset the computer or any other procedure??? Please let me know what to do because taking the car to the dealer is a pain in the..
Thanks.
jorgep03 is offline
Old 01-09-2009, 11:25 PM
2LEET4U's Avatar
you may have to re-do the settings and save them.
just like your car radio. if your battery dies and you replace with a new battery. you have to re-do all of your radio channels + clock settings.
2LEET4U is offline
Old 01-09-2009, 11:49 PM
jorgep03's Avatar
Allready tried re doing all settings a couple of times with no success. but you are right about the clock and radio stations, I had to re program all of the again.
jorgep03 is offline
Old 01-10-2009, 12:31 AM
Incognito
BigPete's Avatar
try to reset the ecu. then change the settings.
BigPete is offline
Old 01-10-2009, 05:15 AM
04MAX_ILLIN's Avatar
From my experience just give it some time, those functions will come back.
04MAX_ILLIN is offline
Old 01-10-2009, 07:14 AM
Nations 1st 6th Gen Turbo
chernmax's Avatar
I gets temperamental at times but it does come back, try on the setting to disable it (so it doesn't move), then turn off the car, turn the car back on then set it (so it does move), turn off the car, and when you restart and turn off normally it should work. Also make sure the drivers seat is adjusted to your normal driving position first before adjusting the above settings. If all else fails, disconnect the Neg battery terminal, let the ECU reset and start over.
chernmax is offline
Old 01-10-2009, 07:31 AM
jorgep03's Avatar
temperamental indead, sometimes I loose it too, I'm very picky with my car. I will try your sujestions right away, and can anyone tell me how to reset the ecu??? is this done by disconnecting JUST the battery neg pole???
thanks.
jorgep03 is offline
Old 01-10-2009, 08:50 AM
2LEET4U's Avatar
Agree.....
Let the car sit for 15-20 min when you disconnect the neg battery.
2LEET4U is offline
Old 01-10-2009, 08:07 PM
chernmax's Avatar
thanks.
YES!!!
chernmax is offline
Old 01-10-2009, 09:22 PM
*moderator*
jsmithsole's Avatar
I just replaced my battery as well, and had to rest it. Are you sure you are trying to set it correctly?
jsmithsole is offline
Old 01-11-2009, 12:32 PM
one5ikmax's Avatar
just re-do the setting. something similar happened with me but i took it straight to nissan.
one5ikmax is offline
Old 01-11-2009, 12:38 PM
KC's FINEST
KCMAXX's Avatar
The settings are fine, just turn the key on and off a few times.
It will work again...
KCMAXX is offline
