Nissan Navigation DVD 6.6
#86
The navi DVD is located in the push-open compartment right under the radio -- you'll see a small slot on the inside right side, put a flat screwdriver in there and then pull out the cover which will expose the navi DVD
#87
No one has posted a reply to CAn a copy dvd work in the navigation system. I have a 2007 and I am curious does anyone know for sure if copys work. If copys work you can get a copy for 25 dollars. Check the link below.
http://cgi.ebay.com/ebaymotors/Infin...spagenameZWDVW
#88
#90
Disc
Eject the old Navigation DVD from the DVD drive located behind the lower stowage compartment just in front of the stick shift. There is a small cover that is removable inside that you have to pull out to see the DVD drive. Eject the old Map DVD, Insert the new and follow the onscreen instructions!!!
