Replacing passenger side fog light...
Old 10-29-2008, 08:45 AM
Oolatec's Avatar
Stupid dealer wanted $75 because they said the bumper would have to be removed... I know there's got to be a better way... anyone?
Oolatec is offline
Old 10-29-2008, 08:49 AM
MaxJ04's Avatar
actually its simple.. just gotta do a lot of wiggling around.. you can actually reach it on the passenger side. if you have a CAI then its easy too on the driver side. my passenger side was blown and my friend help me replaced it. he had skinny hands so he could fit .. hope this helps. but if you don't know then the bumper has to come down... it is easier .. .but more work just try to wiggle the bulb out and in .. remember the positions ..
MaxJ04 is offline
Old 10-29-2008, 08:37 PM
Oolatec's Avatar
Yeah that's the problem... no small hands here...
Oolatec is offline
Old 10-30-2008, 12:22 AM
*moderator*
jsmithsole's Avatar
You can do it, $75 amazing....
For the driver's side you need to remove the intake or the stock air filter. This will give you access to the bulb. For the passenger's side, remove the fluid reservoir (there's 2 10mm bolts holding it in place). After that you'll need to remove the fill tube for the windshield washer fluid. You can do this by twisting it counter clockwise. After that you should have access to the bulbs.
It is a tight fit and a pain in the butt, but it can be done.
jsmithsole is offline
Old 10-30-2008, 04:20 AM
Kryogen's Avatar
I dit a FULL write up for this, just use search.
But yeah, really a pain, ok to change a bulb, but nightmare to install HIDs
Kryogen is offline
Old 10-30-2008, 05:41 AM
carlosr's Avatar
Remove the push pins, then the plastic engine cover, twist and pull out fluid refill neck... if your hands still don't fit you can remove the actual fluid reservoir with 2 bolts. The bulb has a cab that twist off then a clip that holds it in place. Takes a few minutes, if your confused do a search Krygen's write-up was very helpful when I did my install last week... I may post up pics later id I have time/energy.
carlosr is offline
Old 10-30-2008, 06:31 AM
Oolatec's Avatar
Awesome... thanks everyone!
Oolatec is offline
Old 10-30-2008, 09:46 AM
STARR's Avatar
just be patient, 1st time will take the longest
STARR is offline
Old 10-30-2008, 02:45 PM
*moderator*
jsmithsole's Avatar
True true...
I have learned alot about my car over the past 5 years, I can drop my front bumper in about 7 minutes.
Remove the tails in about 5.
Center console out in under 10.
Change the bulbs in the front, while in my bed sleeping!!!!
Old 10-30-2008, 07:31 PM
ryan188's Avatar
hmmm
ryan188 is offline
Old 10-30-2008, 08:26 PM
osc006's Avatar
it is easy but does anyone have any idea how to keep it from burning out. I have replaced my passenger fog light twice.
osc006 is offline
03VQMAX
12-07-2015 04:59 PM
lux97Max
09-14-2015 03:54 PM
rtirbany
09-08-2015 11:46 AM
KGMtech
08-18-2015 09:21 AM
jchronis2552
08-13-2015 07:48 AM
Quick Reply: Replacing passenger side fog light...
