09-07-2008, 04:59 PM
Painting Engine Pieces...
I did a search and really didnt find any useful info so I thought Id ask.
I want to paint the plastic pieces in my engine compartment,but Im not quite sure how to go about doing this.Can someone steer me in the right direction??
09-07-2008, 05:10 PM
Well you want the plastic pieces painted? Your best bet would be to get them painted at a shop...they would have to be cleaned..sanded and cleaned again, if you want them nice and smooth. A spray paint would work but it would come out sort of lousy and would probably start peeling.
__________________
00 Sterling Mist SE 5MT (14.9 1/4) --- Sold @ 118K
02 Sterling Mist SE Meridian ed. 4AT (14.76 1/4) --- Traded @ 88K
04 Liq Silver SE 6MT --- LOVIN IT
Berk Intake, Progress springs+KYB GR2's, tints, tail tints, 6K HIDs, Mobil1 syn., painted calipers, debadged, 6MT , driver preferred package, new rebuilt trans
09-07-2008, 05:21 PM
Quote:
Yeah I would like to paint them all.Im not sure I want to go to that expensive of a route.I thought if I could do it myself I would.I dont want it to look crappy though.So I guess I wont be doing this.
09-07-2008, 05:37 PM
Go ahead... try me
Quote:
I painted all mine pearl white with clear coat... cost me about $200 for everything. If you wanna get it done then get it done right... have a shop do it and make sure you tell them to clear coat them once they're painted... otherwise the paint will peel off after a while.
09-07-2008, 05:39 PM
well if you took the time to sand it throughly and finely enough and clean it very well with the right cleaners you could use a high temp spray paint and a clear coat and make it look pretty damn decent.. i do body work for a living... if you need more info feel free to pm me or im me on aim
__________________
maxxxfreak your engine bay looks sweet
__________________
09-07-2008, 05:45 PM
use primer, sand it smooth, add 2 or 3 coats of high temp paint. i used caliper paint and finally add 2 to 3 coats of clear coat.
__________________
09-07-2008, 05:46 PM
Go ahead... try me
Thanks bro... it does get attention when I go to mechanic shops LOL. my mechanic always wears gloves before he touches anything becuz he's afraid he might get it dirty. I always just bust out laughing at him for that
09-07-2008, 05:47 PM
Go ahead... try me
Quote:
You're tellin him how to do it when you don't even have yours done LMAO
09-07-2008, 05:50 PM
shut up freak. ima do it soon.
__________________
09-07-2008, 05:56 PM
Go ahead... try me
Then wat the hell you waitin for... Pep Boys and Home Depo are open sucka... get to it.
09-07-2008, 05:58 PM
lol. i will soon.
__________________
09-07-2008, 06:27 PM
Damn MaxxFreak,that your Max is sweet!!!The engine pieces look amazing!!
What part of SD are you in?? Im in the San Diego area as well.
So it sounds to me like this is a job best left for the professionals.
im just afraid to do too much to my max...got 118000 miles...dono when ill randomly go to the dealership again and get another car (aka 7th gen) this happened last time i had just did some nice stuff and wiring to the inside of my 2k2..and a week later ended up buying my 2k4..somehow.....:/
__________________
09-07-2008, 06:28 PM
Do you have some pics?? Are you happy with it?
09-07-2008, 06:30 PM
LOL!! Nevermind I must have missed the others posts.Maybe if you get it done soon you can post some pics.
09-07-2008, 06:46 PM
Go ahead... try me
I'm glad to come across another SD Max owner... so far I met 2 other SD people on CarDomain.com... and now you  . I'm in Clairemont... off 805 and balboa ave.
you should start comin to our Nissan local meets every other week... and sometimes every week. It'd be cool if we can get the SD Maxima people to do a mini meet... just hang out or eat out or something... take pics etc. Where you at in SD?
09-07-2008, 07:37 PM
I got mine done for $50 total, my guy from nissan did it for me~!
09-07-2008, 07:45 PM
Materials: $25 to $40
1) 1 Can Red Opulence spray paint [to match the color of my car, you may use a different brand spray paint, I see Krylon has a spray for plastics called "Fusion" thats very good. and I believe primer is not needed]
2) 1 can spray primer [I used red primer, but black would be ok, or grey if your painting it a light color]
3) 1 Can spray clearcoat
4) 1 tack cloth
5) 400 or 600 wet sandpaper [I had this plus I used fine steel wool]
all of the above was purchased from the link below
http://www.automotivetouchup.com/spray_paint.asp
1) After removing the cover I removed the Nissan hamburger & the silver top center section [these are very easy to remove] and masked off the "V6 3.5"
2) A light sanding was next, followed by a cleaning [hosed off] & wipe down with the tack cloth
3) 1st primer coat, let dry
4) very light sanding, [I used fine steel wool] then a cleaning & wipe down with tack cloth
5) 2nd primer coat, let dry
6) repeat step 4
7) 3 color coats, 15 to 25 mins between coats, let dry over 24 hours, do not sand color coats
8) 2 clearcoats, let dry 24 hours,
9) Remove masking tape & reinstall Nissan burger & silver section
10) Reinstall engine cover, pat self on back
__________________
__________________
09-07-2008, 07:49 PM
Here are simple steps to get the look you want.
1) Wash the parts with mild soap (car wash soap). No mit or sponge. Use your hand.
2) Go to Autozone or any automotive paint supply shop and buy a paint prep cleaner ($5-$10) and spay on piece being painted. Wipe clean with microfiber cloth or any lint free cloth.
3) Time to sand. Get a cup and add 2-3 drops of soap and cold water. Make sure you also buy 400, 600, 800 grit sand paper. Start with the 400 grit sand paper and dip it in the cup of water with soap. Make sure its nice and wet  .
4) Sand the entire area in a back and forth motion. Make sure you keep the paper wet. Once you're done sanding with 400 grit move on to the 600 and finish off with the 800 grit. This will pre the surface and leave it smooth.
5) Buy some high temp primer and add a coat. Try to add light coats to have a smooth finish. Let it dry and wet sand with 1500-2000 grit paper. Make sure you dont remove any primer. You are only sanding to keep a smooth finish for the base coat. If you see that you removed some primer, just spray some more. When you sand make sure you clean the area before you add another coat of primer. Wash the area with soap by hand and let air dry. Once dry use a tach cloth to go over the piece.
6) Once you are satisfied with your primer the next step is to add the paint. Buy any spray paint and add light coats. Once fully covered let it dry.
7) Once its dry move you're hand accross the surface and see if its smooth. If its not you can wet sand with 2000 grit. Make sure you sand without adding preassure on the paper.
8) The last step is to add clear coat.
If done right it will look clean.
I'm currently working on my plastic pieces as well, but I'm using a compressor and gun. I went to a body shop and bought PPG paint that matches my car and clear coat. If you are interested in knowing how to go this route hit me up and I will be more than happy to show you how.
__________________
 05 Smoke 6MT
Interior: Blue neon, Blue L.E.D's, Pioneer Avic Z2, Phoenix Gold Xenon 12" subs, Xenon 1200 watt mono amp, Stinger wiring, cap, custom box, and amp rack.
Performance: Nismo short ram, NWP spacers, and home made grounding kit.
Stoppers: RPT cross dimpled/slotted rotors, PBR Ultimate pads, RPT SS brake lines.
Exterior Mods: Black headlights, Tinted tails, and Nismo gunmetal rims (need tires  )
Under construction http://www.cardomain.com/ride/2222452[/list]
09-07-2008, 07:50 PM
very nice work
__________________
09-07-2008, 07:51 PM
i went the same route as machinist when i painted my stuff red. but i used fusion
09-07-2008, 07:55 PM
you can get very good results doing it yourself. its a nice feeling too knowing and seeing your work and the finished product. but if you're unsure of yourself, go to a body shop.
__________________
Theses are my cars.
09-07-2008, 08:08 PM
WOW!!Those are a couple of great write ups,thanks guys.
But,what about the clear coat?Can it handle the engine heat?
