Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Thread Tools Display Modes
Old 09-07-2008, 01:16 PM   #1
04 SL cranks but won't start
When I spray starting fluid into the intake, it starts normally and runs for about 2 seconds, then stops upon using up the spray. Obviously, the engine's not getting fuel (half full tank). Background: it has done this before--always after the car hasn't been used for 2-3 weeks. However, eventually, the car has started. This time, no firing, nothing but cranking at pretty good speed (new battery last spring), despite several prolonged attempts spread over two days (with and without pumping of gas pedal). What do you think? Fuel pump? Fuel pump fuse?
__________________
04 SL Majestic Blue/Black
lobewiper is offline   Reply With Quote
Old 09-07-2008, 01:24 PM   #2
Try to listen for the fuel pump when you turn the key switch (without starting the car,), best way to find out if the pump is working,
__________________
MAX2DAMAX is offline   Reply With Quote
Old 09-07-2008, 04:27 PM   #3
Quote:
Thanks--will check that out.
__________________
Old 09-07-2008, 06:03 PM   #4
Send a message via AIM to Shoey1 Send a message via MSN to Shoey1
sometimes if the pump wont go you can hit the bottom of the tank with a hammer while some one cranks it. sometimes it will kick start the pump and help you get to the closest service station. this only works for a short time though. i use this method at work on cars all the time and it works about 60 percent of the time
__________________
Signature pictures are to be no larger than the allowed size of 550 x 325 pixels
2004 SL 4 Speed
KY2 "Polished Pewter"
MODS:
Fujita Intake---Racingline FSTB---Eibach Pro Kit Springs---20% Tint---6.5 Gen Spoiler
http://www.cardomain.com/ride/3122802
Shoey1 is offline   Reply With Quote
Old 09-07-2008, 07:05 PM   #5
ignition sensor?
Anand.Patel is offline   Reply With Quote
Old 09-07-2008, 07:45 PM   #6
Quote:
Fuel pump is NOT working, or working very sporadically. I'm a little reluctant to tap the fuel tank to kick start the pump, because with my luck, it won't do it again for a while, and the mechanic will say the pump is working. Thinking about letting the AAA tow it to the dealer so they can see for themselves what the problem is...
__________________
Old 09-07-2008, 10:14 PM   #7
one other thing, our cars are fuel injected so pumping the pedal wont work. only carbureted cars benefit from pumping the gas to let a bit extra flow from the bowls to the floor of the intake to get them running in the cold or wet. there is no deirect cable link like a traditional throttle plate. a sensor is on the gas pedal that tells the computer how much your pushing it, then teh computer tells a little motor in the throttle body to open the plate a corresponding amount. over complicated i know
__________________
2004 SL 4 Speed
MODS:
Old 09-08-2008, 07:45 AM   #8
CanadianMoFo's Avatar
I had a bad crank position sensor cause similar infrequent start issues.
CM
CanadianMoFo is offline   Reply With Quote
Old 09-08-2008, 09:03 AM   #9
I am not familiar with the 6th gen security system but on the 5th gens there is a chip built into the key and if that chip isn't present or functioning the car wont start and the symptoms are the same as what you are describing.
Feldman is offline   Reply With Quote
Old 09-08-2008, 09:22 AM   #10
Quote:
But, it started with starting fluid. And, I tried the spare key earlier for the same reason you mention, but it didn't help.
__________________
Old 09-08-2008, 09:31 AM   #11
I think the security system works by shutting off the injectors so there is still a spark but no fuel, once you introduce fuel or starter fluid in your case it fired up.
Like i said i'm not familiar with the 6th gen security system but on my 5th gen there is a security light on the dash that goes out if the correct code from the key is being received but goes solid if the wrong or no code is received.
Old 09-08-2008, 09:36 AM   #12
[quote=Feldman;6607176]I think the security system works by shutting off the injectors so there is still a spark but no fuel, once you introduce fuel or starter fluid in your case it fired up.
Interesting! It's at the dealer's now with their best technician. Will advise on findings...
__________________
Old 09-08-2008, 10:13 AM   #13
let us know what it ends up being. If it isn't a security issue i would guess it is a fuel delivery system issue.
Good Luck!
Old 09-08-2008, 04:22 PM   #14
should add a poll to this thread...
im betting its a fuel pump/sending unit
__________________
2004 SL 4 Speed
MODS:
Old 09-08-2008, 05:39 PM   #15
It was the fuel pump--only putting out about 20 pounds of pressure. Covered under the power train warranty!
__________________
Old 09-09-2008, 10:07 AM   #16
That is weird that it would work but not be at full pressure, must have been a bad seal or something like that.
Anyway, good to hear the problem is solved and it didn't cost you anything!
Old 09-09-2008, 06:54 PM   #17
It was especially nice because the car was about one week out of warranty and they fixed it as a "courtesy."
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
