Quote:
Originally Posted by carlosr
From what you have explained it is NOT the caliper seized/frozen, but does sound like the sliding pins weren't properly installed and/or lubricated. I would unbolt the pin and check that its not dry, bent/scratched and for any foreign materials (ie. dirt/grime etc) check the rubber boot that it slides into for cracks/rips and that there is no debris in it. After inspecting everything you will need to clean, re-lube and install... also, sounds like your going to need to replace those rotors (do the set if one needs replacement) and new pads. If you don't know how to do this find someone that does, if you took it to a place and this is what happened I would make them pay to replace everything. BTW don't think I have to say this but I would not drive the car until this has been fixed. Good luck.
Thanks for the responses.
I have replaced the brakes myself, and as always I re-lubed the pins when I installed the new pads. I am not sure what you mean when you say the sliding pins may be installed incorrectly, as I lubed and torqued them (not sure what else needs to be done). Again, all my other pads/rotors are fine it is just this one that is giving me problems.
The real question that I am having trouble figuring out is why the sliding pins work perfectly when they are semi tight by hand, but as soon as I tighten them with any strength the caliper/pins don't move at all.
I'm thinking it may be a pre-existing condition when I got the car, cause I had severe uneven brake wear when I was changing the rear brakes.
I'm going to replace the rotors and pads again, but I'm trying to get to the root of the problem.
