Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Thread Tools Display Modes
Old 08-30-2008, 05:48 PM   #1
Electrical problems... Please help!
So I took off the instrument cluster to clean the glass/plastic pieces. There were streaks on the inside probably from the dealership. I followed the instructions in the LED interior mod in the 6th gen forum to remove it. I disconnected the neg battery cable, removed the cluster, did not unplug it because i only needed to take off the face to clean the glass. Finished, put it back together and then reconnected the neg battery post.
Heres the issue... my sunroof will not retract, it goes up and down but will not open up. My bose cd changer wont read any disks, doesnt even sound like its doing anything, just loads, ejects, and reads check disk. My steering wheel heater doesnt seem to be working.
I checked the fuses under the steering wheel and by the engine, they all look good...
Any ideas? Did i short something out? The neg post was disconnected and i didnt plug/unplug anything. What happened?
__________________
"Never underestimate the predictability of stupidity"
gianic1 is offline   Reply With Quote
Old 08-30-2008, 07:08 PM   #2
MAXIN' ON
Send a message via AIM to redls1
Dont know about the stereo but once you disconnected the battery you have to manually run the sunroof back and forth before it goes back to auto mode.
__________________
2007 Maxima 3.5 SE
! 20" CHROME Katana Desire ! MTX MONO AMP !
! MTX 10" SUB ! BILLET GRILL !
redls1 is offline   Reply With Quote
Old 08-30-2008, 07:25 PM   #3
Quote:
What? How do I go about doing that? Its closed right now.
update:
ok, unplugged neg post again, reconnected, checked fuses, came back 2 hours later and now sunroof and steering wheel heater work but bose cd changer still wont read disks. Also noticed when i started it up it seemed to idle high in park, at 1.25, usually at .75-1. took it around the block and it seems to idle back at .75 or so...
is it a coincidence the bose hu crapped out when all this was going on? Is there a deeper problem here?
update:
Everything works fine now. Went for a drive and I was messing with the 6 disk changer, wouldnt read anything, tried 1-6 and nothing. So I loaded all the disks and 1, 2, 3 still wouldnt work but then 4 did, so did 5 and 6. Thought it may be the cd's themselves so took em all out and put them back in a different order. They all played. Dunno what the problem was but now steering wheel heater, sunroof, and bose hu all work and rpm in park an neutral are back to normal.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
