08-26-2008, 05:11 PM
Where is my shirt?
A/M UDP Belts already wearing out???
Whats up guys!!
Sorry ive been in and out of the forums here. Thanks to Ramberg... Ive been on the NYCMax a lot!! LOL!!!
But anyway I need you guys help.... recently I noticed after starting my beast of a family sedan... that the famous belt sound we all are familiar with has shown up.
But sometimes I can hear it, and sometimes I cannot??
Before I go any further... I was just wondering if any of you guys have ever had any issues with your A/M belts for the Unorthodox UDP. If not then I can start looking for the only OEM belt still down there. Thanks homies!!
__________________
08-26-2008, 08:56 PM
A/M belts? I'm also not familiar with the belt sound, what is that?
__________________
Cardomain = Silver stream
 _
Boss Wheels/ MTX amp/ Progress Springs & RSB/ Fujita CAI/ AT grounding kit/ ID roof spoiler/ NWP Spacers/ Timing advanced 2 degrees/ UR SC pulley/ Apexi SAFCII/ 8in DLS Free air subs/ Cattman Y pipe/ Nismo Exhaust
08-26-2008, 10:19 PM
Where is my shirt?
Quote:
My Bad... lol
A/M= After Market
It is sort of a whistle/ squeaking sound....
__________________
08-27-2008, 05:47 AM
GrandPa
I have that problem and as soon as I have a chance I will change them. You cannot use the OEM belts. Don't change them yet because I was told it could be the AC compresser. I will change the belts and see if the problem is solved.
__________________
08-27-2008, 07:15 AM
Interesting, I do have more of a whistle/squeaking when the A/C kicks on. I am using the UR S/C pulley with stock belts.
__________________
 _
08-27-2008, 09:33 AM
I have had a belt squeal from day one. I tried tightening but nothing seems to help.
08-27-2008, 09:49 AM
I had attributed it to the NWP spacers but it really only kicks in (as far I can tell) once the AC comes on and I'm idling.
__________________
 _
08-27-2008, 05:11 PM
Clutch on the A/C compressor or just need to use specified Gates belts
08-27-2008, 06:41 PM
Was the correct torque applied to the bolt holding the UDP? Not enough torque may keep the pulley out a bit. I have no belt noise from my Cosmoracing pulley.
__________________
NISMO CAI, Progress RSB & Racingline endlinks, Koni Yellow front, KYB/AGX rear, Stillen FSTB, Eibach Pro-kit, SS brake lines, Edead inside, Beltronics STI & LaserPro 905, CE Y-pipe, Technosquare flashed ECU, grounding kit, Cosmoracing underdrive pulley, Phenolic spacers, ported LUM/UIM, NGK Iridium.
08-27-2008, 07:04 PM
GrandPa
Quote:
I was told it might be the clutch. It only makes the noise when I turn the ac on than it goes away in a couple of minutes. I have the Gates belts installed.
08-27-2008, 07:06 PM
Where is my shirt?
Quote:
Whats up brother.
Yeah I do recall that last time we saw eachother know that I think of it. Ok great I am going to wait and talk to you about this one. Thanks brotha!
__________________
08-27-2008, 07:07 PM
Where is my shirt?
Roger that. Then maybe its common after a while?
__________________
08-27-2008, 07:09 PM
Where is my shirt?
Quote:
Roger that Mark....
I was just worried that one day I drive and then... snap!
Do you think that could happen?
Which UDP are you running? And which belts?
__________________
08-28-2008, 07:28 AM
It's frustrating
I too have this noise hen the a/c is on. I used a smaller gates belt not one they recommended as they were too big.
__________________
Dan  formally coitaltie
Nismo CAI- Nismo Ray's Engineering 19's- Nismo full catback exhaust-Nissan 300zx TT aluminum calipers- Progress RSB- Racingline V2 endlinks rear- Progress lowering springs- KYB GR2 struts and shocks- Racingline FTSB OEM look- Active Tuning custom grounding kit- Active Tuning S4.1 grill- Custom Enterprise Y pipe- Unorthodox Racing Underdrive Pulley- Optima Red Top- JL W3V3- JL 500/1 v2 amp
08-28-2008, 10:12 AM
I was getting squeaking on start up and no other time so the dealer informed me I needed new belt so I got them, have not yet started the car today so I'll see what it sounds like on start up
__________________
2006 SE Maxima, Onyx
OEM All-Weather Mats
15% TINT
FUJITA CAI
Stillen FSTB
Nismo Sway Bars
Yokohama Avid W4s
RTP Cross drilled/Slotted, F&R
Hawk HPS pads
AT Grounding Kit
08-28-2008, 11:17 AM
So I went down to my car and started it up, no more whistling/whinnying/squeaking noise after Nissan replaced my belts
__________________
15% TINT
FUJITA CAI
Stillen FSTB
Nismo Sway Bars
Yokohama Avid W4s
Hawk HPS pads
AT Grounding Kit
08-28-2008, 12:43 PM
Nations 1st 6th Gen Turbo
No noise as of yet but on my UPD I used gates belts:
NEW RECOMMENDED BELT SIZE / BRAND ARE:
ALTERNATOR & A/C BELT:
GATES, Part# K060408
(41.5" or 1055mm)
OR
GATES, Part# K060410
(41" 5/8 or 1066mm)
POWER STEERING BELT:
GATES, Part# K040300
(30.75" or 780mm)
08-28-2008, 03:33 PM
Where is my shirt?
I am not even sure what belts I have?? lol
I know that they came with the UDP when bought from Stillen???
Thanks for the info STARR and Chern!!
__________________
Where is my shirt?
Quote:
The same sizes Chern stated above?
__________________
08-28-2008, 06:18 PM
It's frustrating
Quote:
used gates 403 instead of 407 on a/c. Worked out great and nice firm fit.
__________________
08-28-2008, 07:12 PM
Quote:
How much was it?
08-28-2008, 09:10 PM
Quote:
Originally Posted by Terrentius
How much was it?
$168 total
__________________
15% TINT
FUJITA CAI
Stillen FSTB
Nismo Sway Bars
Yokohama Avid W4s
Hawk HPS pads
AT Grounding Kit
08-29-2008, 11:42 AM
Thanks, STARR. :>)
09-02-2008, 09:49 PM
Where is my shirt?
So dealer changed out the after market belts also? Sorry I am a bit confused lol
__________________
09-03-2008, 07:53 AM
I don't have any aftermarket pulley, just regular OEM Nissan belts, changed after 50k cause they dry out and squeak
__________________
15% TINT
FUJITA CAI
Stillen FSTB
Nismo Sway Bars
Yokohama Avid W4s
Hawk HPS pads
AT Grounding Kit
09-03-2008, 12:01 PM
