I did the rear door first and the rear doors are alot easier than the front doors are to do. The rear doors will take aroound 45 minutes to an hour and the front doors about two hours each, so probably allow a good day for the install. On a scale of 1 to 10 for a mod like this I would say it would be about a 4 for difficulty.
Do not post reply to this thread until I have all my posts uploaded, I have approximately 19 pictures with the details. I will have to post four times to get all information up.
Materials:
1. 4- 5mm 13,000mcd LED's (purchased mine from Ebay seller Ivehk for 3.99 plus 6.00 shipping for 50 pieces and resistors)
2. 3/32" or 1/8" polyolefin heat shrink tubing
3. 2 wires per door, approximately 2 1/2' per wire per door
4. Solder
5. Electrical tape
6. 2 part epoxy glue
7. Butyl tape(get at glass store) or silicone sealant
Tools:
1. Ratchet, 10mm socket and extension
2. T-27 torx bit or 5/32" allen wrench
3. Small flat blade srewdriver
Start with front doors and rear will be same process but easier. Pictures are all of the front door. With small screwdriver pry at marked locations below to remove cap at inside door handle, chrome strip on door panel starting at front and working to the back, window controls starting at rear edge. Lift window controls up, unplug connections and set aside all pieces.
Remove the three 10mm bolts at marked locations on door panel below. At the bottom of the door panel there is a lip, grab panel at bottom and give a quick jerk toward you and all door panel clips will release.
Now lift the door panel upward and off of door, lean panel to you to remove the latch cables behind the panel and disconnect all wiring to the door panel. Pull cables away from panel to unclip them and then seperate from the handle. Set panel aside.
Before removing bolts to the inner panel, apply tape onto the outside of window over top of door and then to inside of window to make sure the window does not drop(do this at least at two locations). Remove all bolts marked below and the four nuts. Disconnect clips holding wiring to inner panel. Wiring running through the panel, push grommet through towards the door side and remove panel and set aside.
Look behind the outer door lock inside of door cavity and you will see a yellow clip on the lock rod, roll the clip towards the front of the door and it will unclip the rod from connection.
