Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 04-04-2008, 02:21 PM   #1
HELP HELP HELPP!!! check engine soon light onnn code p1402
hi my check engine soon light is on so i went to get the code and it is p1402 supposely the EGR system pleasee helpp and let me if this is extreme thanks and also my car idled bad today when i turned it on like hittin 1 den hopin to 2 den one so i reved the engine and it stopped could this have anything to do with it
drzcrazychulo4u is offline   Reply With Quote
Old 04-04-2008, 04:55 PM   #2
Learning English...
Hope this helps
MIL “ON” WITH DTC P1402 (EGR OPEN) CODE STORED NTB05-037.pdf
__________________
brio_max is offline   Reply With Quote
Old 10-10-2008, 02:11 PM   #3
"Ok,Whats next?!?!"
Fastmax05's Avatar
Points: 11,783, Level: 71
Points: 11,783, Level: 71 Points: 11,783, Level: 71 Points: 11,783, Level: 71
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
BUmp
__________________
MODS
Injen C.A.I. / Magnaflow Mufflers / Nissan Work I.M.S Kit / Nissan Work VIAS Block Plate / Cattman Y-Pipe (First 6th gen App) / Cattman B-Pipe / Cosmo Racing UDP / Timing Advanced to 17* / Grounding Kit / Roto Pro's Rotors / E.B.C. Pads / Blackd out Billet Grille / Racingline Tower Brace / Racingline Batter Tie Down / Carbon Fiber Hood by EZ Koncepts / Stillen Roof Wing(First 6th Gen App) / Carbon Fiber Engine Cover by IONICDYNAMICS / Fujita Oil Cap / 20in VOLK GT-c's / 245/40/20 Nitto555's / H&R Springs / KYB Gr2's / Blacked Out Windows / Blacked Out Headlamps / 800k HID's / Hyper White license Plate LED's / Piaa Plasma Yellow Fog Bulbs / LED Switchback Turn Sigs / Painted Eye Lids / EzKoncepts LED Tails / Painted Engine Bay Pieces / Rear Deck Lid / Blacked Out Signal Indicator / 12in Fosgate Sub / Pioneer 800Watt Amp / Relocated Info Screen /
Quote:
Originally Posted by NiZMo1o1 View Post
Umm yea OK buddy... , save gas go buy a hybrid
http://blog.stillen.com/2009/02/stil...-wing/#more-99 <<< INFO ON MY CAR!!!
Fastmax05 is offline   Reply With Quote
Old 02-18-2009, 03:11 PM   #4
Points: 6,136, Level: 50
Points: 6,136, Level: 50 Points: 6,136, Level: 50 Points: 6,136, Level: 50
Activity: 2.9%
Activity: 2.9% Activity: 2.9% Activity: 2.9%
Quote:
Originally Posted by brio_max View Post
Anyone know where to locate this, seems the link isn't good anymore.
Rainman1 is offline   Reply With Quote
Old 02-18-2009, 04:43 PM   #5
How many miles you have on your car? I had that code this past summer. My local dealership asked me the same question. At the time I had around 89,000 miles. I was told that my egr valve was getting clogged up with carbon. They usually remove it and clean it. I was quoted around $350. I try to do all of my maintenance on my car. Since I had already changed my spark plugs on my max this past summer I figued I can do this also and save me $350. From my experience if you are willing and able to change the spark plugs on a 6 gen max you can clean the egr valve. The valve does not need to be removed to be cleaned. I just removed the egr tube from the intake manafold to the valve. I would also replace the gaskets when you do this. You do not have to do this but the gaskets might get messed up when you remove the tube. Then I sprayed some carb cleaner in the valve and used a small pipe cleaner to scrape out the carbon. If you have access to compressed air use that instead of the pipe cleaner. After I did this and cleared the code from the computer I have not had and egr problem since. I currently have 99,000 miles on my max. By the way I was quoted a $450 to have my spark plugs changed.
sallymax is offline   Reply With Quote
Old 02-18-2009, 08:14 PM   #6
Activity: 2.9%
Sorry, should have listed all that.
06, 40K miles, factory stock.
I plan on pulling the EGR valve tomorrow, and go from there. I hope it's only carbon buid up, and I have been using 87 octane while gas was outrageous so... maybe it is carbon.
How do you clear the code from the computer?
Thanks for the info!
Old 02-19-2009, 07:16 AM   #7
I have a code reader. It cost me about $150. It has more than paid for itself. Also I could not take out egr valve myself - not enough room and my hands were to big. But you can take of the egr tube from the intake manafold to the valve and clean it as I described above.
Old 02-19-2009, 10:57 AM   #8
Activity: 2.9%
Yeah I quickly found out that it wasn't gonna be easy to get to, so I changed that plan.
I may try removing just the tube like you spoke of. (Gaskets on both ends correct?)
Should have mentioned also, I had Auto Zone put it on the readed and it spit out on a P1402 code, nothing else. I'm just concearned about it possibly being the cats breaking to peaces and not carbon, I have only used 87 octane gas in it.
Old 12-17-2009, 09:36 AM   #9
Points: 5,051, Level: 45
Points: 5,051, Level: 45 Points: 5,051, Level: 45 Points: 5,051, Level: 45
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
SALLYMAX/Anyone:
Am considering undertaking this project this weekend.
- Any cleaning done to the actual "Tube" after removal?
- after spraying carb cleaner into valve, what next for the unscraped carbon?... just let it drain down below?
- spray and scarpe, or let sit???? more detail?
- what else is missing from your thread?
sorry, am detailed-oriented and will follow instructions step by step to get it right. if you can expand more, that will be helpful.
thanks, and i too did my own spark-plugs 2 months ago.
[quote=sallymax;6878435]........From my experience if you are willing and able to change the spark plugs on a 6 gen max you can clean the egr valve. The valve does not need to be removed to be cleaned. I just removed the egr tube from the intake manafold to the valve. I would also replace the gaskets when you do this. You do not have to do this but the gaskets might get messed up when you remove the tube. Then I sprayed some carb cleaner in the valve and used a small pipe cleaner to scrape out the carbon. If you have access to compressed air use that instead of the pipe cleaner. After I did this and cleared the code from the computer I have not had and egr problem since. quote]
Les7311 is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
