Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-22-2008, 03:23 PM   #1
Door lock sticking (or not consitently working)?
Hello,
I have a 2004 Maxima, and lately I've noticed that the passenger side rear door doesn't lock or unlock consistently with the key fob. I can manually lock or unlock it with the door lever, but using the keyfob doesn't always work. When it doesn't work, sometimes I can see the door lever 'twitch' a little bit, but usually the second time locking or unlocking it doesn't move at all. Rarely does it work, actually.
Any thoughts? It kind of sounds like maybe the locking mechanism needs to be lubricated, but I'm not sure. Anyone have any good instructions on taking apart the door interior?
Thanks!
Monotaur is offline   Reply With Quote
Old 03-22-2008, 04:24 PM   #2
Hello,
I had the exact same problem that you are describing, but with the driver side rear door. The twitching of the door lever would happen also when you tried to lock/unlock with the driver's lock/unlock switch. The problem was the actuator needed to be replaced. It was fixed under warranty, so I don't know how to take apart the door. Hope this helps.
esmooth is offline   Reply With Quote
Old 03-22-2008, 05:54 PM   #3
KCmaxx's Avatar
Just use WD40.
Mine used to do it too.
Make sure and not get any on the fake suede (fabric).
__________________
Quote:
Originally Posted by Kryogen View Post
Thanks for the constructive comments and help KC, as usual, your posts are very relevant.
KCmaxx is online now   Reply With Quote
Old 03-22-2008, 11:15 PM   #4
3MTA3
jsmithsole's Avatar
I've had 2 of mine replaced under warranty. My car is at the stealership right now for the other 2...
__________________
More pics here...and click sig for Car Domain site!
~~~LED GROUP DEAL CLICK HERE~~~
jsmithsole is offline   Reply With Quote
Old 03-23-2008, 06:35 PM   #5
I have the same problem on the front passengers side door. Maybe a recall is needed.
__________________
04 Maxima 3.5 SE (Built 03/04)
Majestic Blue/5AT
Leather/Moonroof/Bose
(Bought 08/07 with 27,700 miles)
37,000 miles currently
Mods - (07-08) Spoiler/Cover Plate
Previous Vehicle - 94 Firebird Formula (5.7/LT1)
(Sold 08/07 with 104,000 miles)
LandsEnd is offline   Reply With Quote
Old 03-24-2008, 04:43 PM   #6
Does the door need to be taken apart to use the WD-40? How you take door apart?
__________________
Majestic Blue/5AT
Old 03-24-2008, 06:35 PM   #7
3MTA3
jsmithsole's Avatar
The dealer is blaming the place that installed the alarm now. They also said they tapped into the BCM which they should not have done...any insight??
__________________
Old 03-24-2008, 06:39 PM   #8
SuPeRmOd
NismoMax80's Avatar
Quote:
what's the safety concern that would warrant a recall?
also WaterDisplacement-40 does not lubricate. it repels water.
__________________
NismoMax80 is offline   Reply With Quote
Old 03-24-2008, 07:16 PM   #9
Does lubrication fix the problem? Again if so, how you access the area?
__________________
Majestic Blue/5AT
Old 03-24-2008, 08:04 PM   #10
I was just about to come into this thread and ask that question.
I fooled around with my door lock tonight trying to figure out how to best lubricate it (or use WD40...), but it looks like we'll need to disassemble the door. Is this correct? If so, for those that have done this, how do we go about doing it?
Thanks!
Old 03-25-2008, 12:30 AM   #11
I don't think WD40 is gonna fix your problem if the cause is the actuator. I think it is just a matter of it failing prematurely. Me thinks you're gonna have to see the dealership.
Old 03-25-2008, 02:50 PM   #12
Send a message via AIM to ReficuLiu
Crap . ..i just realized mine is getting stuck as well. . ..
I dun wanna go back to the dealership .. . .again .. . .
ReficuLiu is offline   Reply With Quote
Old 03-25-2008, 03:42 PM   #13
Send a message via Yahoo to po8pimp
don't use wd40 like stated above it is not a lubricant. there are other lubricants you can buy. I recommend trying the lubricant then if that doesn't work get the part and install it yourself. don't put the door back together till you see if it works though. they aren't hard to take apart. the parts that hold them in place sometimes break because they are plastic. to take the door off you just need to pull on the bottom of the door till the plastic retainers pop off don't worry you won't damage anything other that those retainers if anything. they are cheap if you break them check autozone or schucks/checkers. then once the bottom pops off you have to pull up on the whole inside piece because it slides into a groove along the top. very easy. hope that helps
__________________
po8pimp is offline   Reply With Quote
Old 03-26-2008, 02:25 AM   #14
3MTA3
jsmithsole's Avatar
Mine still work, they lock fine but don't unlock. It's like they have lost current when unlocking. I am going to check with my installer...
__________________
Old 03-27-2008, 05:40 PM   #15
It must be a problem with the 2004's because mine just started having the same problem
postman370 is offline   Reply With Quote
Old 03-27-2008, 08:11 PM   #16
I have a 2005 and I've had the same issue as well...
Old 05-16-2008, 06:09 AM   #17
Door lock maintenance Keep locks from sticking so you won't be outside, knocking and kicking . Swinging doors are for saloons! Put your doorin its place!.
__________________
Cross-referenced news and research resources about Gary Winnick.
Lisa-Adam is offline   Reply With Quote
Old 05-31-2009, 12:46 AM   #18
How much did it cost u guys to get it fixed at the dealership?
archit105 is offline   Reply With Quote
Old 06-12-2009, 07:01 AM   #19
mine started doing this today. any updateS?
ss1995rip is offline   Reply With Quote
Old 06-12-2009, 10:57 PM   #20
I had my driver's side window stop working at points and it was due to the car alarm not functioning properly. Had to have alarm reset. My battery had been disconnected while in the bodyshop which reset my alarm due to it being disconnected for such a long time. This could be the same situation? Maybe take it to the place you had your alarm installed, if you have one, and tell them your locks and windows are acting funny and you want them to reset your alarm. Tell them your battery died and you had to get it jumped and the alarm was acting funny and this was a result. Should work and should be done for free if you work it right. If it is a factory alarm then I don't have any suggestions except take the lock out of the rear and install in the front to see if that fixes it. If so buy a new lock for the rear/front.
__________________
Old 06-21-2009, 08:02 AM   #21
mine started a few weeks ago... does anyone know about how much satan (dealership) will charge?
TIA
__________________
eclipticrider is offline   Reply With Quote
Old 06-24-2009, 03:22 PM   #22
bump... about how much does nissan charge to repair this problem, my drivers dore lock wont open/lock every so often
tia
__________________
Old 06-25-2009, 09:39 AM   #23
Quote:
tia
And for us do-it-yourselfers, has anyone found a place that sells the actuator aside from the stealership?
addicted2pain is offline   Reply With Quote
Old 08-23-2009, 02:54 PM   #24
I've searched and only found this thread, no true answer. I have a problem with my 07 drivers door switch (pushbutton). It works for a while then after it rains it stops working. I can hit unlock on the keyfob and it works. I can even open the doors via the passenger door switch but the drivers side, no dice.
My guess is that some moisture got into the switch either it or the ground is corroded. Has anyone had this problem and actually fixed it themselves? Could it just be that the button is worn out?
papasuede is offline   Reply With Quote
Old 10-07-2009, 10:26 AM   #25
Mine driver and passenger doors are doing that. Passenger for quite some time know, driver started after recent car wash. It does feel like moisture gets inside somewhere and prevents them from operating. Happened already before, but they both became operational again. Doesn't feel like a complete failure of actuators, but is there a fix for it, other than replacing them?
ubersl is offline   Reply With Quote
Old 10-07-2009, 10:48 AM   #26
Quote:
Well, if it's the actuator that's bad/going bad... seems like the only fix will be a replacement.
If you are brave enough to take your door apart, you can see if the moisture has caused any rust/corrosion inside.
__________________
Oolatec is offline   Reply With Quote
Old 10-07-2009, 11:47 AM   #27
haha, it's an actuator for sure, i've replaced it myself, and tore my tint up, had a lot of fun though
Old 10-30-2009, 03:28 PM   #28
Same issue with my car (maxima 05). Driver door first (as year ago), now the door behind that.
I guess it wont be a recall since safety is not an issue.
Anyone know where to buy the actuator? I think the dealer ship charges 300$ for part?!
rroepsto is offline   Reply With Quote
Old 10-31-2009, 11:43 AM   #29
Get the part number and look online. $300 is ridiculous.
__________________
Old 11-04-2009, 11:10 AM   #30
I have similar problem with the back left door
for some reason I can not open it from inside or outside ...
it is locked ..
any one can help ?
amansour14 is offline   Reply With Quote
Old 11-06-2009, 03:01 PM   #31
I just got mine out of the shop yesterday for the front passanger door lock. All I have to say is TGF extended warranty!!! I see from others it seems to come in a domino effect....hopefully the other doors won't have the same problem.
CLK04MAX is offline   Reply With Quote
Old 11-06-2009, 04:03 PM   #32
Yeah
Quote:
Originally Posted by esmooth View Post
Hello,
Same thing for me...
rutlean is offline   Reply With Quote
Old 11-06-2009, 05:15 PM   #33
Live with the issue. Not a big deal. Its just a manual old fashioned door lock now. A little exercise doesn't hurt.
__________________
Majestic Blue/5AT
Old 11-07-2009, 09:00 PM   #34
EBAY is your friend for these situations. I would start there for part searching. 300 is way too much for that part. Also try taking the lock apart as a last resort. You never know what kind of problems you could fix just by fiddling with it. Could be something loose or even gunked up.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
