Will these rims/rubber work for my Maxima?
Old 10-19-2009, 07:10 AM
Nameth's Avatar
I have a stock 2004 Maxima SE.. I need some winter tires for this bad boy.
I recently came across an ad for some winter tires and was wondering if they would work for my car.
These are the specs:
2-Rear Tires: 245/45/R18
2-Front Tires: 225/45/R18
Make: ASA
Model JH9
BackSpacing 5.90"
Bolt Pattern 5-114
Offset 35mm
I believe these are coming off a 350Z..
Thanks for your help.
Nameth is offline
Old 10-19-2009, 07:52 AM
KC's FINEST
KCMAXX's Avatar
Should work fine.
It's best to run a narrower tire for snow conditions though...
KCMAXX is offline
Old 10-19-2009, 08:02 AM
Nameth's Avatar
Aye
When it comes to tires, I am clueless.
So when you say smaller width for snow tires, then the fronts are more ideal (225) than the rears (245)?
I was concerned about the tires due TO the smaller size on the fronts. I didnt know if they should be the same size or not. Right now my car has 245/45/R18 all around.
I am being offered the rims and virtually new rubber for $1000 total.. sounds like a decent deal.. but like I say I really don't know much about tires/rims
Also, since reading from of the forums this morning, I read about a "shimmy" problem.. my car does not currently have that. Will putting new rims/tires on the car maybe GIVE it the shimmy's? Or has that problem sinec been deduced?
Thanks in advance.
Nameth is offline
Old 10-19-2009, 08:07 AM
nalc's Avatar
narrower is usually better for snow tires, because they'll cut deeper through the snow and hopefully find the road down there. Instead of a wide tire that just sits on top of the snow
nalc is offline
Old 10-20-2009, 07:35 AM
KC's FINEST
KCMAXX's Avatar
It also depends on the tires.
If they're the Bridgestone RE040's I'd pass...
KCMAXX is offline
Old 10-20-2009, 09:36 AM
urbandreams's Avatar
i got 245 45 R 18 Blizzak directionals ...............amazing
urbandreams is offline
Old 10-20-2009, 12:29 PM
KC's FINEST
KCMAXX's Avatar
My 350Z winter setup. (225/55/17 Blizzaks)
KCMAXX is offline
Old 11-08-2009, 01:17 PM
g max04's Avatar
thats the stock specs so they will work. i have all seasons with the same specs
g max04 is offline
trasmadean
02-01-2017 08:20 PM
ah2002
03-09-2016 01:42 PM
kenc15
08-05-2015 08:29 AM
kjm900r
08-05-2015 07:14 AM
Tanvirkamal
08-05-2015 01:32 AM
Quick Reply: Will these rims/rubber work for my Maxima?
