Shopping List......Y-Pipe or ECU Next????
What up Peeps!!
Ok I finally got some money in and ready for the next performance mod . But I am stuck between either the Technosquare ECU reflash or the Cattman Y-Pipe. I currently have the following mods:
- CAI, Kinetix, Spacers, SPII, UDP
I was just wondering what you guys would recommend next for me out of these 2 mods and why. Help me out homies.
Well, there is several ways to think about this. Its better to do all your mods and then to TS reflash. Or, you can buy a piggy back (UTEC or SAFCII) and modify your maps as you make mods to your car. Im not sure the benefits of TS reflash over UTEC or SAFCII. Anyone?>
Why is it better to do bolt-on's first?
Get the TS L-Spec version if you plan on hooking up another AFC later on. L-Spec is the "limited spec" that removes the speed limiter, raises the rev limiter, and enables you to hook up a AFC without the ECU "over-taking" it within a couple of days. L-spec is also cheaper than F-spec
For now, I say Cattman y-pipe
Also, I would do a piggy back system such as the SAFC II instead of doing the TS reflash. I think a tuner is going to be able to dial in more pony's than a TS flash.
The Y-Pipe doesn't take more than 30 minutes to put on. So doing them both at the same time really doesn't save you much time. I would say get the Y-Pipe now and the headers later.
I thought the the headers come with the Ypipe.. so if he buys a ypipe now , wouldnt he have an extra ypipe if he buys the headers ???
Extra work ? extra part to sell again ? why not save time and wait?
Technically yes, but the EXHAUST MANIFOLDS of the "headers" have not been developed yet, so for those of us that already have the y-pipe will only need the exhaust manifolds when they come out.
Exactly. Buying the Y-Pipe now vs later will be no different. Cattman will sell the Header + Y-Pipe together or separately when both parts are available.
I wasnt aware they would just sell the manifolds without the Ypipe... Ive done and sold some headers and None of the other companys that Ive dealt with has done that , nor was I aware Catts would do that..
I guess thats what makes him differnt from other companys
I hade the CE y pipe before and it kills your low end torque, and my gas mileage was horrible, i would go for a s-afc2 are the reflash for better fuel curve since you already have good breathing mods
I have pre ypipe and cattman catback dyno number and post number. the torque is most likely what you feel. Reality is about 5 whp increase. same Dynojet and same temps, barometric pressure and all that other bull malarky. IE wait for headers
Which one?
See thats what I am thinking. I mean get the TS now and wait for the Y-pipe when the headers come out
Do you have the L-Spec version?
Ok I am surely leaning toward the TS now.
Does anyone have this mod though? Any gains actually scene?
The TS site states 20HP gain. I dont believe that but maybe 10HP?
Members from knowledge , Prjctmax, Chern , Kevin007 , Few others But doesnt come to mind.. I will be sending my ECU out as soon as I get my car back
Yes, that's confirmed longz ago
I have the F-Spec and after having it and going through many different possibilities of altering AFR, I'm regretting I got the F-Spec, but w/e
"freeing" up some parameters in the ECU itself will aid in power increase, but getting more mods and THEN reflashing your ECU would be the best route because you can dyno with AFR before sending your ECU, and then send the ECU with your run-files, so that they can adjust accordingly
Thanks for all the feedback homies.
Ive decided to go with the Y-Pipe for now. I agree with what Prjctmax and will hold off on the TS until the headers are also installed.
Thanks a bunch homies for the support.
Case is officially closed. lol
Hey,
Any one can help me install an ECU, in 2004 max.The ECU, shorted out in the dealer, want 3k to fix.Has any one experienced an ecu problem. If so how difficult would it be to install my self.Im also looking on ebay having trouble finding 5spd AT, with traction control .Im also not to sure about the adaptive crusie control system the parts stores keep asking about.Do We even have that? any help will be greatly appreciated.
Mdollazs05
Mdollazs05
Hey,
Mdollazs05
Mdollazs05
www.car-part.com, then have your dealer prgram the key for the new ECU, done.
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
RealityCheck
10-02-2015 06:34 PM
