Some "friendly" advise from the service station
Old 12-21-2007, 01:33 PM
SickSE
The car is due for an oil change but the tech relays some other information to me about other things he thinks needs to be done...
Brake Fluid
Alternator Belt
Fuel Injector Cleaning
Rear Shocks leaking? (never heard of that)
Power Steering Fluid
All at astronomical prices totaling up to 600 something dollars which I do not have. What are the things I absolutely need to have done. I will probobly have the car another 2 years and 50K miles. It is an 04 with 72K on it now.
Thanks guys,
Alex
Old 12-21-2007, 01:38 PM
'Trynna' is not a word
mtrai760's Avatar
Brake fluid - Change it yourself for the cost of the fluid, no need to pay someone, it's easy.
Belt - Check it out yourself with a flashlight, are there cracks in it? If so, change it yourself for the cost of the belt, usually under $30
Fuel Injector Cleaning - At your milage it's a WASTE of money and an easy way for the shop to make a buck on a sucker. Run of bottle of Techron.
Rear Shock Leaking - Jack up the rear of the car and verify it yourself. If you see oily substance comeing out from the boot, then yes, your shock is leaking.
Power steering fluid - Change it yourself.
Short of the shock, there is less than $100 worth of work there.
mtrai760 is offline
Old 12-21-2007, 02:00 PM
DeusExMaxima's Avatar
He's right, plus $30 for oil change.
DeusExMaxima is offline
Old 12-21-2007, 02:36 PM
S_Klass's Avatar
Just a schmuck who's been told to upsell all customers who come in to the store doing his job.
Nothing he asked you to do is bad, but just over-priced.
S_Klass is offline
Old 12-21-2007, 03:51 PM
SickSE
When I went to pick it up, I noticed the taillight which had "burnt out" says the guy on the phone decided to start working again.
Tire Kingdom. As far as I'm concerned they can suck a fat one.
Thanks for the suggestions.
Old 12-21-2007, 03:52 PM
Nations 1st 6th Gen Turbo
chernmax's Avatar
^^^^^ What they said and what a a$$ raping the stealership is trying to give you and last, If your shock is leaking (if) buy a set of KYB GR2 (better than stock and won't brake the bank) and install it yourself in about 20 minutes (3 bolts each side and unlike a 5th gen removable from inside the wheel well)...
Note the 2 bolts at the top and 1 on the bottom, piece of cake...(old pictures )
And since we have an independent rear suspension, no springs to worry about...
chernmax is offline
Old 01-20-2008, 11:08 AM
ridersoftoob's Avatar
nice
ridersoftoob is offline
Old 01-20-2008, 12:27 PM
SHIFT_matt's Avatar
If you still have your original manual it lists a recommended schedule for when this stuff should be done (3750, 7500, 15000, 30000, etc). All if it is good if not entirely necessary and much of it can be done yourself. If you get your stuff done at the dealership they should perform regular inspections of belts and fluids on each oil change. But I do think much if it is overpriced and can be done yourself if you know how.
mtrai760 is right on, verify and do it yourself. But the manual should have a complete list of recommended things to do if you are unsure.
SHIFT_matt is offline
Old 01-21-2008, 01:48 PM
SuperMario's Avatar
Sorry, but no Tire Kingdom in my vocabulary, they're ridiculously priced, not worth it at all. I've been using The Tire Rack for a long time, but I don't take my tires to be installed there either, they don't deserve my business.
SuperMario is offline
Old 01-21-2008, 01:50 PM
SuperMario's Avatar
Wow, that's it?
Hmmm, even easier than the front ones, sounds good to me.
I'm in all honesty not mechanically inclined, but after spending some time on the forum, these seem easier & easier. I'll start doing a lot of stuff on my own.
Old 01-23-2008, 10:50 AM
DRopinski's Avatar
How much brake fluid...
How much brake fluid is required to completely flush the system?
Thx.
DRopinski is offline
Old 01-23-2008, 11:03 AM
stcktnkid's Avatar
I am a new nissan owner, and am pretty suprised to see how easy it is to uninstall and reinstall the rear shocks. Does the car need to be jacked up or on the ground to remove the shocks in the rear? I didnt know if the suspension had to be loaded or not to remove it. So basically just unbolt the three bolts and replace with the KYB rears?
stcktnkid is offline
my03maxima
04-29-2020 12:48 AM
chisam14
11-06-2018 08:56 PM
RealityCheck
10-02-2015 06:34 PM
NERDJUSTBNME
09-30-2015 03:20 PM
Noela
09-26-2015 08:22 AM
Quick Reply: Some "friendly" advise from the service station
