6th Generation Maxima (2004-2008)Discussion of the 6th generation Maxima. Come see what others are saying.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
According to the pics, at start up probably not at all because it's a little radiator. No movement, no cooling I think. In the winter
If I can figure out a cooler that will work, I will take some before and after temps off the dipstick and see if the temp actually drops. Check out that pic on the Stillen site (you gotta click on the little wrench) and you will see what I mean. I was kinda thinking it might not be affective, not that it would over cool.
Heck, does someone know what the operating temp on the tranny is anyway?
Well, I've got the car back. They replaced my broken tranny with a remanufactured one. Totally charge on my ticket was like $3,500. Much lower than I expected, I wonder if it would be higher if I was paying for it.
The tranny felt kind of "tight" (if that makes any sense) when I drove it home. I drove it to work and back a couple of times, it's starting to feel like normal again. I haven't really romped on it yet though, I'm just giving it some time settle in. Dealer recommended changing the fluid at 30k instead of 60k. I'll be doing that.
As far as the tranny cooler is concerned, it looks like it's a no go as we don't have tranny fluid lines to connect to.
Quote:
Originally Posted by SouthFlMaxTech
yeah.. there are no cooler lines so you cant add a cooler michael!! sorry to say that....
knoc on the wood so far so good and no tranny issues with my 04 mt max
__________________
2004 Maxima, 18" rims, tinted windows, 6 spd, Pioneer Avic D2, DVD player, Spoiler, 2x12" Rocksford, 6K HID's, and more to come soon
My transmission shifts fine under normal driving conditions, and even under hard acceleration but at times when it down shifts upon acceleration it will really hit hard into the lower gear. it doesn't slam or make any noises, but it does hit pretty hard, not very smooth at all. It's like if you are driving a manual, rev the engine in neutral and then slam it into second at 35-40. Anybody have input on this?
I had a 2004 Maxima SL with the gated shift...it was such a lemon that they bought back my car after only barely 81/2 months! They put me in a 2005 SE and gave me all sorts of extras...The transmission failed after 10K Miles! Anyway so far so good on the 2005 SE hope it stays that way...knock on wood!
I have a 2004 SE with a 5 speed auto. When shifting into reverse it hits pretty hard (going from park or from drive to reverse) . Has anyone had a similar issue with this problem and if so do you know what to do for it?
I've been changing (3 quarts) my trans fluid every 30k miles and its been nasty. Its dark and it stinks. I haven't had any trans problems yet, but I'm increasing the frequency of changes to 15k miles. Part of the problem too is that you can only drain 3 out of a total of, I think, 14 quarts. Not cheap either at $13 a quart.
I have the exact same problem. It makes terrible clunking noises and shakes the car whenever i shift from park to reverse or reverse to drive. It also has late shifts between 1st, 2nd, and 3rd. A replacement (remanufactured) through the dealer was about $3400 (average cost, i called 4 different dealerships) and only came with a 12 mo./12k warranty. I am having AAMCO rebuild it for $3800 and they incldue a 3yr/36000k warranty. I wish i had gotten the extended warranty now. who would have guessed a 6th Gen car would have a tranny go out at 70k miles???
I just had my second transmission replaced in my 04 Max. The first was at 24,000 (had terrible slippage) (under warranty) and now at 74,000 (cost 4k). I've had quite the experience with this Max. I'm actually thinking about trading it in for somethin else.
You 2nd tranny? And it only lasted 50k. Wow, I guess when they have bad trannys they have bad trannys. I'm hoping my rebuilt lasts more the 50k. The only thing I am really going to do different is have the fluid changed well before the mfg recommendation.
I have a 04 auto with 91k on it and i just wanted to know if this was normal to you guys. When I leave and the temp is on C for cold the transmission jumps from 1st to 2nd, is that normal b/c the fluid or tranny is cold?
my 05 has been jumping from 1st to 2nd since I bought it new but not every day. I brought it to the dealership and of course, the car worked perfectly. I have 79,000 miles on it now. it still does it from time to time especially if I am going 20-25 mph the shifting up and down is very jerky. I hate it and I am waiting for it to just die then I will spend a fortune getting it fixed.
Mine is starting slip more under acceleration and now under normal driving, also the groan when I first start out and slowing to a stop is getting worse just made an app for the 18th at the dealer. I will let you guys know how it goes.
The last one I don't think is a problem but just the way the CVT behaves, at least partially. For example, when cruising, releasing the gas pedal and then getting back on the gas (not aggresively) there is sometimes a sort of "kick" sensation. I think this is normal for the CVT and found it in all the three 07 Maximas I have driven.
__________________
2009 Maxima SV with Premium Package
2007 Maxima SL with Platinum Edition Package, Vehicle Dynamic Control and Full-size Spare, Power Glass Moonroof, Moonroof Wind Deflector. Precision grey exterior, charcoal interior. 100% stock, 35% FormulaOne Pinnacle tint. (Traded)
ON MY 05 TRANI WENT AT 14K I WAS LIKE WTF.. .DEALER AT FIRST TRY TO GIVE ME A HARD TIME AND REFUSE BECUASE OF MY EXHAUST MOD. THEY WRE TRYIN TO BS ME SAYIN EXHAUST GIVES MORE POWER TO THE WHEELS SO MY TRANI WENT. I LAUGHED SO I ACLLED NISSAN HEADQUARTERS THEY TOLD ME THEY SHOULD WARRANTY IT. ITS JUST EXHAUST WHICH HAD NO EFFECT ON TRANI .SO I WAS CALLIN FLATBED TO TAKE IT SOMEWHERE ELSE THEN THEY CHANGED THEIR MINDS AND DECIDED TO FIX IT IT WAS REAL FUUNY. SOMETIMES YOU HAVE TO BE FIRM ON YOUR WARRANTY OTHERWISE YOU GET THE BS REFUSAL.
ok.. so I can't post new topics since I'm the 'new guy' but here's my story... bought my 04 se like a few months ago w/ 1k warranty and thats it- got it for a steal because of the high mileage (95K miles) and I only paid like $11000 for it.. Now I'm at 99K miles and I noticed in the last thousand miles like maybe 2 or 3 times the transmission SLAMMEd into 3rd gear.. and freaked me out so I drove her real nice. Well today I may have f'd it up since I was in a rush to work and someone decided to make a right turn in the middle of the road and I went to pass around by punching the gas. Well nothing happened for a second and then BAMMM and CHIRP the car takes off.. I was like oh crap.. and then after that it went straight to 5th gear I think at 35 mph.. so I was freaked.. the next few miles it would not come out of 5th gear- I ended up pulling over and turning the car off completely- restarting and then the check engine light came on and it was in 1st gear. Drove away and it had a rough shift into 2nd and then into 3rd and then went straight to 5th. From there on out, it only went to 3rd and wouldn't go any further down.. Now i'm here at work buggin out! What do i do? I heard something about a TCM?? Any Input is appreciated!!
did it feel like you hit a piece of ice and the car accelerated but did not go, thats a slipping trans
__________________
2009 SV Sport&Tech, Dark Slate
2006 SE Maxima, Onyx (traded)
the transmission didn't slip- it just slammed and then got stuck in 5th gear ... and it only would go back down to third gear.. there was no slipping noise or grinding or anything
ughh- the error code that came up was PO744D and basically the conclusion is I need a rebuild- so its sitting in the shop till tomorrow where my guy is gonna drop it and open it up-- SUCKS.. and I just got this car like 2 months ago..
Had mine replaced on 2004 about 2 weeks ago. The slipage was so bad that the car was just going places I didn't want it to go. Coming to a stop the 2nd gear was so hard that I practicaly got a whiplash. Last nissan for me, you bet your @ss it is.
Did you replace or rebuild? Mines just as bad with the slamming and it def slips in 2nd and 3rd gear which sucks @ss..
The dealer replaced it with a rebuild/refurbished one. From outside it looks brand new. According to a friend they rebuild them from scratch and only re-use the shell.
I spoke to another friend who owns tranny parts wholesaler business and he said that valve bodies are to blame. He said that they have been getting a lot of phone calls for this tranny within past year.
Another thing he said that I found interesting....change the fluid every 10K or don't change it at all, ever.
so the tranny is out-- took some pics with the cell as you can see below.. also- the guy showed me the fluid from the tranny was dark and had metal flakes in it ... not good he said... he said i might just need a replacement... not sure-- he's going to open it up monday... tell me what you think..
You did not provide an option for 6-speed manual trannie owners to reply. I have 66 K miles on my Max. I changed my OEM trannie fluid at about 30 K miles and went to synthetic. No trannie problems. Don't expect any.
Which Synthenic and type did you go to and is it recommended for the Auto?
__________________
Mods07 Max CVT F5CAI,SP2Exhaust.1/4Mile NA13.91@98MPH.
Mods04 Max Stock Timing,5 Spd Auto,SP2Catback,F5CAI,Stock Manifold w/BO Plate,CattmanYPipe,Stock tires, NGK one step colder plugs.1/4Mile NA 13.97@102.81MPH.1/4Mile with a 75shot 12.80@110MPH.
12 Second 1/4 Mile Video: http://www.youtube.com/watch?v=8kKGBjoJLskhttp://www.cardomain.com/ride/2550587
The fluid in a manual trannie is much different from (and heavier than) the fluid in an auto trannie -- the two are not compatible.
I used Redline MT-90 because, at the time, Amsoil had quit making the proper fluid. Amsoil now (again) makes a GL-4 (single grade) gear oil, and I will be using that when I change the fluid again at about 90 K miles.
