Rear Endlinks - Installation???
Because there are multiple suspension setups there really isn't a wrong way in terms of in or outboard. Just as long as they are put in a straight (vertically as possible).
Thanks for the credit, but those aren't my pictures. I have a stillen RSB, and I installed my endlinks inside (to the rear of) the swaybar. That top picture makes me nervous with the endlink being so close to the brake line. Probably won't touch, but I am kind of a freak about brakes....
I installed today. Not as easy as it would see (for me). Couldn't get the bolts to get the stock endlinks off of the frame, so I had to unbolt the piece that bolts to the frame off to get off the stock sway bar. Then had to burn out the bearing and use vice grips to hold it while I took off the nut. Almost put the new RSB on backwards.
Luckily, after screaming "NOOB" under the car for about an hour, I got it done. Car handles phenomenal. Progress RSB and rear endlinks are certainly the way to go.
Thank you Taz.
Joshua
Thank you Taz.
Joshua
Thank you Taz.
Joshua
Thank you Taz.
Joshua
Guys, I'm putting on my links now. However I was curious, in this shot it shows the washer going between the rubber element and the swaybar. However I put my washer on the outside of the swaybar (that way the rubber element is between the endlink and the swaybar). Does this matter much? I haven't taken it for a drive yet but that just seemed the most logical to me. Taz, any comments here?
Nations 1st 6th Gen Turbo
Thanks Chern. Just before I came up to read this I actually went looking for some extra washers in order to have them on both sides as well. Thanks man!
Hmm, ok I couldn't find any extra washers. I put the endlinks on as in the picture of them with the red bushings. It feels as if there should've been an extra set of washers to put between the swaybar (bottom) and the mount (top) as well instead of mounting the nut flush against them. I may pick some up at some point to put on there.
Otherwise these babies are certainly MUCHO higher quality than stock. Fronts next!
One last question. I'm assuming the bushings will expand and contract a bit. Should I go back in, in a week or two to re-tighten everything?
Damn, I wish you would have mentioned that an hour ago. So I guess my initial instincts to have the bushing sit softly against the swaybar was correct. Man, I shoulda just went with that. Thanks Taz....
Joshua
-spacers leave the hiem bearing exposed, meaning it'll wear alot faster, especially for northern regions where snow exists.
-the bushing, while adding longevity also add a little extra stiffness to the hiem allowing it to respond even faster.
When I first initiated the ES upgrade and posted the results, I thought my troubles were over. Either Im taking turns at 90 degrees at 90 MPH or Im just unlucky. Ive got V2s on order and am re doing the whole back with my progress. The washer is not needed on the bar itself Mack as directed.
I had that same problem when I had the V1 endlinks - I couldn't tighten them down enough. I bet you just don't have it snugged down enough... My noise went away when I upgraded to the v2 endlinks... The bolts I had with the v1 endlinks weren't threaded all the way, so I couldn't get the bushings compressed enough (at least that is my theory). Have you tried tightening them down some?
I still have this unresolved and am currently on OEM endlinks. Couldn't stand the noise anymore. I had V1 setup and its just laying in the basement. TAZ whats is the fix for this and can you provide support?
kingw323
20
10-21-2015 08:36 AM
Huttig2009
09-25-2015 03:31 PM
