Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-14-2007, 08:51 AM   #1
rotors and pads
well i talked to rotorpros yesterday and he told me 300 for dirlled and slotted rotors and performance pads. Is that a good deal and how hard is it to install your self. Do you have to bleed the brakes or what.
anthny2040 is offline   Reply With Quote
Old 10-14-2007, 09:00 AM   #2
Quote:
Good deal.
Not hard to install yourself, but it might be hard for you to loosen the bolts that hold on the calipers with hand tools. That was hard for me.
No need to bleed the brakes, but this is an excellent time to do a brake flush and upgrade your fluid, if not to buy the SS lines and have them installed as well.
What kind of pads did he offer you?
Joshua
philoforlife is offline   Reply With Quote
Old 10-14-2007, 09:09 AM   #3
He did not tell me what kind of pads, but do you think you can give me a quick install write up or some pointers.
Old 10-14-2007, 09:12 AM   #4
Not very hard at all.
Jack up the car, take off the wheels, take off bolts holding caliper on, take off pads, use clamp to back up the hydraulic press, new pads on, take off rotor, slap new one on, replace caliper, tighten bolts, put on the wheel.
I would suggest also this is a good time to paint the calipers...
Joshua
Old 10-14-2007, 09:16 AM   #5
Use clamps to back up hydraulic press??
Old 10-14-2007, 09:37 AM   #6
Send a message via ICQ to NIKV69 Send a message via AIM to NIKV69 Send a message via Yahoo to NIKV69
Just did mine. First off $300 for everything is ballpark. I paid $200 for the rotors which I got off ebay and rougly $70 for geniune Nissan pads. As for the job itself it went smooth. One good word of advice is to use a torque wrench to break the bolts that hold the caliper brackets on. I did that first and it made everything go well. Then remove the caliper bolts. I bought a big sryinge to take some brake fluid out of the master when I was pushing the pistons back into the caliper. If you don't the brake fliud will come out the top. Clean all the backing plates and new rotors thoroughly with brake cleaner. Spray the back of the pads and plates with disc brake quiet and you will be fine.
__________________
"Live free or Die"
NIKV69 is offline   Reply With Quote
Old 10-14-2007, 09:51 AM   #7
C clamp. When you take the pads off, the part of the caliper that compresses the pad onto the rotor will move all of the way out. You use a C clamp to compress it back into position so you can put the caliper back on the rotor.
Joshua
Old 10-14-2007, 10:02 AM   #8
so you compress the caliper piston while your changing the rotors and everything, and do the pads just snap in.
Old 10-14-2007, 10:37 AM   #9
yes.
Dont use a torque wrench to unbolt, use a breaker bar, or you will screw your torque wrench.
Kryogen is offline   Reply With Quote
Old 10-14-2007, 10:44 AM   #10
now how would i put the new pads in with the c clamp there and how do you put them on the rotors?
Thank you to everyone who is replying
Old 10-14-2007, 11:56 AM   #11
i wonder with the deal you're looking at includes hawk hps pads? you should find out. mine are about dead so i am looking for a complete set.
eK9aT10pSi is offline   Reply With Quote
Old 10-14-2007, 12:10 PM   #12
Quote:
Originally Posted by Kryogen View Post
yes.
Yep lolol Though I use my tourqe wrench cause it's wasted already. That's craftsman for you.
You use the clamp to push the piston back in the caliper not to put on the pads. Once the new rotor is in place and the bracket is secured you place the pads on, the ends of the pads have tabs that slip right in. Then put the caliper on.
__________________
"Live free or Die"
Old 10-14-2007, 12:13 PM   #13
alright, well once i push the piston back in will it stay in or try to come out.
Old 10-14-2007, 01:44 PM   #14
it will stay in.
as for the rotors, you just take the old ones out and put the new ones in.
It will be easy to understand when you do it.
Old 10-14-2007, 02:02 PM   #15
allright thanks i looked more on line and now confident in doing my brakes. i will post pics of the process when started.
Old 10-14-2007, 03:04 PM   #16
Hardest part will be getting those bolts holding the caliper off. I abandoned the project last time because I couldn't get ONE bolt off. I need a bigger man or a break bar...
Old 10-14-2007, 03:18 PM   #17
so should i spray them with something first.
Old 10-14-2007, 03:29 PM   #18
Quote:
You sure you didn't mean the bolts holding the bracket on? The caliper bolts were easy when I did it. It was the two bigger ones that required a little patience but they finally broke and came off.
I don't think that helps. I didn't and besides I wouldn't want to spray anything near that boot that keeps dust and stuff away from the floating caliper bolt.
__________________
"Live free or Die"
Old 10-14-2007, 04:09 PM   #19
Holding the bracket on...hmm...I only recall the two bigger bolts holding the caliper on...didn't know there were two more on top of that. But yes, I meant the bigger bolts. Did you just use a ratchet or did you use a break bar? Mine were quite rusted.
Joshua
Old 10-14-2007, 04:10 PM   #20
Tried liquid wrench - did nothing.
Joshua
Old 10-14-2007, 04:32 PM   #21
Send a message via ICQ to Hilbe Send a message via AIM to Hilbe Send a message via Yahoo to Hilbe
I slipped an aluminum pipe over the end of my wrench and used that for leverage to get mine off.
__________________
Hilbe
2004 Liquid Silver Maxima SE
Fujita CAI | NE Spacers | Cattman Y-Pipe | Nismo Exhaust | Cosmo UDP | VIAS Block | AT Grounding Kit | KYB GR2 | RacingLine FSTB / Endlinks | Drilled/Slotted Rotors | PBR Ultimate Pads | 2007 Rear Bumper | Black LED Tails | LED Switchbacks | 350z 35th Anniversary Rims | FormulaONE Tint | Sidemarker Overlays | Lund Grill | Viper 5900 | Pioneer AVIC-D3/BT/12 Disc Changer/iPod/SWI-PS | NESA NRM-7002 | SE-R Pedals | Clear Doors | LED Interior | AMSOIL 5W30
Hilbe is offline   Reply With Quote
Old 10-14-2007, 08:18 PM   #22
hey quick question do you think its safe if i just get a set of front rotors and pads because i get stearing wheel shimmying when i break it can be intermittent some times but i figure i need new pads and rotors in the front.
thanks guys
__________________
2k6 Majestik Max.
sinnistar is offline   Reply With Quote
Old 10-15-2007, 02:28 PM   #23
I think you should. I just had the same deal going on with the shimmy (really bad when I would start to brake at speeds over 50 mph) I took it to the dealership this weekend and they re-surfaced both my front rotors. It solved the problem of the shimmy when braking but I am still going to replace my pads/rotors with some good after market products. Just choosing the right pads/rotors is my delimma
aogburn is offline   Reply With Quote
Old 10-15-2007, 03:59 PM   #24
and all so i will be installing progress springs, do they come with instructions on how to install.
Old 10-17-2007, 07:22 PM   #25
any one?
Old 10-17-2007, 07:29 PM   #26
I Rev to 9k
Send a message via AIM to welery
Never ordered that brand but the springs i have ordered in the past came with instructions.
Also, Drilled and slotted rotors will crack under high temperatures.
Here is a pic of my Brembo rotors after 1 session of tracking
welery is offline   Reply With Quote
Old 10-17-2007, 08:40 PM   #27
oo ok well what should i get then i mostly do city driving and some hard braking all the time.
Old 10-20-2007, 11:52 AM   #28
OEM rotors cracked
History: OEM rotors warped @19Kmiles. Replaced with drilled/slotted rotos, warped big time after 2Kmiles. Put the OEMs back and started to warp after another 32Kmiles.
Today I checked the OEM rotors and found vertical hairline cracked in a few places, both front and back - all rotors. I'm a normal driver, so I suggest you to take a look at your OEM rotors.
Time for me to shop for some rotors/pads.
MaxFan is offline   Reply With Quote
Old 11-18-2007, 08:38 PM   #29
...NYG...
No bleeding in necessary. but you will have to get a import tool for the rear cailapers. the fronts can be compressed with some force. BUT BLEEDING IS ALWAYS GOOD.. just to get some of the old fulid out that tends to heat up and get dirty. just always top off the resvour. or you will get air in the lines..
__________________
JET,INJEN -K&N,JIC STAGE 2,ZENNITE 19'S,BREMBO CROSS AND SLOTTED,STILLEN FRONT AND REAR STB,PIONEER NAV AND DVD REAR LCD'S,GREDDY CAT BACK,HIGH FLOW CAT,JL 10'S,JWT CAMS,STILLEN REAR SWAY BAR,BERMBO ROTORS, EBC GREENSTUFF PADS. ENERGY SUSPENSION MOTOR MOUNTS, SHIFT KIT BUSHINGS, CONTROLL ARM BUSHINS, SWAY BAR BUSHINGS.
antonello104 is offline   Reply With Quote
Old 11-19-2007, 01:22 AM   #30
I just ordered this setup,
__________________
2009 SV Sport&Tech, Dark Slate
2006 SE Maxima, Onyx (traded)
only FS by sponsors in sigs.
STARR is offline   Reply With Quote
Old 11-19-2007, 08:54 AM   #31
Some other simple pointers are to consider a different brake fluid such as ATE's Super Blue. It's superior to stock fluids in characteristics and its blue color lets you easily tell when you've finished draining the old fluid out.
Brake fluid should be flushed regularly. In its pure form, brake fluid has a high boiling point but once introduced into a brake system, impurities and moisture (water) mixed into it and lowers the boiling point giving you the sensation of spongy brakes. Don't just bleed, flush!
If you are going to paint your calipers, DO NOT spill brake fluid on them. That stuff eats away paint!
On completion, remember to bed your new pads to your rotors!
S_Klass is offline   Reply With Quote
Old 11-19-2007, 11:17 AM   #32
right on S_Klass, when I put my new setup on I will replace the OEM fluid, BMW recommends replacing the brake fluid every 2 years cause of the moisture it absorbs
__________________
Old 11-24-2007, 10:16 AM   #33
Send a message via AIM to Propa Teknique Send a message via MSN to Propa Teknique Send a message via Yahoo to Propa Teknique
This might be off subject but I got my brakes changed and rotors resurfaced @ Firestone... they charged me 300... seems like a good deal right?? But they told me I need to change both my fanbelts for power steering and a/c because they were cracked and that is would cost me 200.... I'm not paying 200 bucks to do that... any recommended places to get that done for cheaper? Also what kind of fanbelts do our cars use?? I have 04 and I found two on Ebay but they were Serpentine and I dont know if that was good.... Part #'s are: 1/ Alt & A/C drive belt # 430K6
1/ Power Steer belt # 305K4
http://cgi.ebay.com/ebaymotors/2002-...QQcmdZViewItem
__________________
__________________________________________________ ____
.::Everything Good & Accomplished In the World Takes Work... Everything Else is JIVE::.
Propa Teknique is offline   Reply With Quote
Old 11-24-2007, 10:57 AM   #34
Quote:
Part #'s are:
I Kinda answered my own question just now... I referred to the work order and it shows they are the same with the exception of the poly rib belt... the one they recommend is part # 420K6 (poly rib belt) and the one on Ebay is part # 430K6 (poly rib belt)... that doesnt really matter does it?
__________________
Old 11-24-2007, 11:00 AM   #35
ShiftVQ35
open the fsm and look at it if you dont know what you are doing
Old 11-05-2009, 05:20 PM   #36
Guys I am replacing my rotors and pads on saturday
Could someone tell me the torque spec for the main bolts.
Also how tight do i need to do the caliper bridge in the back there.
Thanks in advance.
Didnt know where to ask this
hmr1979 is offline   Reply With Quote
Old 11-06-2009, 03:51 PM   #37
Tight Bolts
Get ready to put everything you've got into getting caliper bolts off. I think I strained my neck getting mine off with a cheaper bar. BIG NOTE: Turn the steering wheel to assist each side.
rutlean is offline   Reply With Quote
Old 11-07-2009, 03:55 PM   #38
Quote:
Did you have an air wrench? I do. I am wondering if it's that hard with an air wrench?
And good point about turning the wheel.
Since i don't have a hoist, I am a bit worried about having access in the back to take caliper bridge off...I mean enough space even for the small air wrench gun.
Old 11-16-2009, 03:14 PM   #39
Send a message via AIM to LucKie1nE
Removing and replacing rear disc brake rotors and brake pads..
__________________
TEAM STREET WANDERERZ
LucKie1nE is offline   Reply With Quote
Old 11-16-2009, 07:06 PM   #40
Guys, DO NOT TAKE THE CAR TO FIRESTONE/GOODYEAR/MIDAS for brakes. This member said he paid $300 for pads and having the rotors RESURFACED. I'm sure you did not get a high quality pad. You could have had BRAND NEW QUALITY pads AND NEW ROTORS for that $300. If you don't have the know-how to change the brakes, hit up a member here...there's got to be somebody fairly close to you that will lend a hand. I can go to my local Autozone and get decent pads and brand new rotors for $100 in parts. I would never pay anything more than that unless I'm getting brand new rotors. I hate to see people getting ripped off for simple car repairs.
__________________
Pioneer Premier DEH-P980BT
Morel Dotech Ovation 6/Arc KS300.4 bridged
Arc FD6025/Arc KS125.2Mini
2 Hertz EBX200R 8" subs/ARC KS300.4 bridged
Dynamat in front doors/rear deck/trunk lid
Full LED interior conversion, switchbacks, taillights
1hawaii50 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
