Anyone running a 350Z Boomslang Emanage Ultimate harness?
Old 06-15-2007, 03:36 PM
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
http://www.boomslang.us/ultimate.htm
You 6Gs are really lucky to share similar ECU connectors even wiring with the 350Z.
A buddy with a 6G wants an ECU, so I'm trying to talk him into a EU+Vmanage.
IceY2K1 is offline
Old 06-15-2007, 03:43 PM
IceY2K1's Avatar
Damn...looks like Greddy even makes one:
http://greddy.com/products/display/?...SubCategory=47
NIS 350Z (Z33) VQ35DE
02-+ N-13 Plug and Play Harness for the E-manage Ultimate.
Ignition Adapter 1 include, Diodes included on Ignition Harness. 15921505 190.00
IceY2K1 is offline
Old 06-15-2007, 03:49 PM
I'm needing a caw
Jeff92se's Avatar
I don't know how similar the newer maxima ecus are to the Z. I know the EARLY 2003 Gs had more in common to the maxima vs the 2003.5+ Gs and Zs.
I have an early version so if I want to run one, I have to be careful. I'm liking the UTEC but the EU can be had much cheaper
Jeff92se is offline
Old 06-15-2007, 03:53 PM
VQ Wizard
SR20DEN's Avatar
I would now consider this
http://www.uprev.com/products/osiris_NI.html
SR20DEN is offline
Old 06-15-2007, 03:58 PM
I'm needing a caw
Jeff92se's Avatar
I saw that too Matt. It's reflash type. Not sure if it suits your DIY tuner needs. But at least reflashes are no charge according to them. Nice not to have to send in the ecu everytime though. Cobb Tuning was supposed to offer something like this also. But I don't believe a releash date is soon. Also it only covers basic Nissan obdII vs Cipher's Nissan specific obdII diagnostics.
Jeff92se is offline
Old 06-15-2007, 04:07 PM
IceY2K1's Avatar
Comparing 2003 350Z and 2005 Maxima FSMs, they are virtually the same as far as ECU pins.
IceY2K1 is offline
Old 06-15-2007, 04:08 PM
IceY2K1's Avatar
WOW...thanks.
Originally Posted by SR20DEN
IceY2K1 is offline
Old 06-15-2007, 04:14 PM
I'm needing a caw
Jeff92se's Avatar
I know for a fact that at least the early G ecu is diff than the rest. But I don't know if the early Z ecus are diff
Jeff92se is offline
Old 06-15-2007, 04:16 PM
IceY2K1's Avatar
I know, but if the BS harness works on 03-06 350Z, it should work or be very very close for my buddies 2005 Maxima.
Guess I'm missing the point...
IceY2K1 is offline
Old 06-15-2007, 04:18 PM
IceY2K1's Avatar
Man we need someone to hack this, so we can modify maps ourselves.
IceY2K1 is offline
Old 06-15-2007, 04:34 PM
VQ Wizard
SR20DEN's Avatar
I haven't read enough into it but I was under the impression that was the point.
I would rather have access to program a Nissan ECU than to have a EU and a VM. I suppose $700 doesn't get you that ability.
SR20DEN is offline
Old 06-15-2007, 04:37 PM
I'm needing a caw
Jeff92se's Avatar
Well they DO email the program to upload. So I guess there must be a way to look at it / maybe alter it.
Jeff92se is offline
Old 06-15-2007, 04:39 PM
IceY2K1's Avatar
Exactly........
IceY2K1 is offline
Old 06-15-2007, 04:41 PM
IceY2K1's Avatar
If it did, it would cost $5K or more easy.
Technosquare has a programmer they sell. Al Friedman uses something somewhat similar at Dynoflash.com for EVOs.
IceY2K1 is offline
Old 06-15-2007, 04:46 PM
IceY2K1's Avatar
http://technosquareinc.com/mitelite.htm
http://technosquareinc.com/flashecu.htm
Just not worth the cost unless you start up something like Dynoflash.com.
IceY2K1 is offline
Old 06-15-2007, 04:51 PM
VQ Wizard
SR20DEN's Avatar
Anything can be edited with a Hex Editor. However if the bins are encrypted or compressed somehow, that would be useless and dangerous to the ECU.
You guys be on the lookout on the G forums for people getting these things. I want to take a peak at one of their bins.
SR20DEN is offline
Old 06-15-2007, 04:57 PM
VQ Wizard
SR20DEN's Avatar
I also assume you've seen these too.
http://www.autosportwiring.com/
SR20DEN is offline
Old 06-15-2007, 04:59 PM
I'm needing a caw
Jeff92se's Avatar
Personally, I'd search the Z forums. I think those guys move alot faster than the G forums I frequent
Jeff92se is offline
Old 07-26-2007, 10:37 AM
I'm needing a caw
Jeff92se's Avatar
Ugh.............
Jeff,
Thank you for your inquiry.
You are correct about the early 03 G35 sedans having a different set of
ecu
connectors. We do not carry those connector parts.
If you would like to email a picture of your ecu connector, I can take
a
look to verify which parts you have on your car.
Regards,
Richard Welch
AutoSport Wiring
P.O. Box 93141
Southlake, Texas 76092
817-707-9371 Phone
Jeff92se is offline
Old 07-26-2007, 11:03 AM
Puppetmaster's Avatar
Ugh.............
I hope you won't have to do it the hard way, like I have to on my 2002. Still haven't found the motivation to start the soldering....
Puppetmaster is offline
Old 07-26-2007, 11:07 AM
I'm needing a caw
Jeff92se's Avatar
You have a pic of the ecu connector straight on? Because from what I see, the gray connector is what I "think" I have. Pic from the G forum:
Gray is G35 early sedan ecu.
Black is for the Unichip that didn't fit. But looks like all the other harness adaptors I've seen for Emanage/UTEC etc...
Jeff92se is offline
Old 07-26-2007, 11:29 AM
The gray one in your picture looks about right, ie. it at least looks close to what I have unlike the black one, but I'll take a straight on picture when I get home this evening.
You're trying to get your own patch harness?
Old 07-26-2007, 11:32 AM
I'm needing a caw
Jeff92se's Avatar
Well idealy, I'd like to find out if a straight patch harness is available. Plug and play.
Did you buy an extra ecu connector from a bone yard? and you are taking those wires and soldering them into a back of an emanage harness connector?
I'd imagine I would have to buy another G35 ecu connector and a patch harness. Then hack the harness to ecu connector off and splice the harnes wires into the G35 connector?
Jeff92se is offline
Old 07-26-2007, 12:01 PM
VQ Wizard
SR20DEN's Avatar
I still need the motivation to get the connector off the PCB which I have had for over a year.
SR20DEN is offline
Old 07-26-2007, 12:31 PM
I got the ECU harness from a yard for the female side (right piece, with the wires), and a fried ECU from another Org member for the male side (left piece).
The problem is the male side because it is on the circuit board, so I had to hack apart the ECU to get that part, the left piece in my picture. You can also do it the right way with a solder sucker, but a tapered head wire cutter is as advanced a tool as I have.
I'm trying to do what Ice did here:
http://forums.maxima.org/showpost.ph...6&postcount=78
That is, create an intermediate patch harness to wire the Emanage harness into, so that I can (1) not mess with my stock harness (2) easily pull the unit on and off and go back to stock if necessary.
It doesn't seem like you can even use a prefabbed patch harness because the connectors on either side will not match anything on your car.
If the piggyback is already attached to the patch, you'll have to chop off both connectors of the patch harness and reattach the correct G35 male and female connector to be able to connect the patch to the car. You'd have to match the pins to the wires, so this would actually be a nightmare on an existing patch harness.
Unless I misunderstood the question....
Old 07-26-2007, 12:43 PM
You need to forego one of your Charlotte Maxima dinners and get this done then. It took me less than an hour to cut the connector off the PCB, but then, I was pretty reckless with it.
At least you already have the Emanage on the car. I want to finish the harness first.
Old 07-26-2007, 12:55 PM
I'm needing a caw
Jeff92se's Avatar
Yeah it's me, not you. I don't understand.
OEM ecu -> (ok)your patch ->(ok) emanage ->(confused) oem harness? Wouldn't the emange existing harness be incorrect?
Jeff92se is offline
Old 07-26-2007, 02:06 PM
Okay, I see where the confusion is. The Emanage harness is spliced into the patch itself. The patch just creates a "bridge" between the ECU and OEM wire harness that you can tap into. The Emanage harness doesn't touch either connector on the car, but is only connected via the patch harness.
The order is:
OEM ECU -> Patch Harness -> OEM Harness
With the Greddy harness tapped into the patch.
Here's a crude diagram I drew that might help:
Let me know if this makes sense, or if someone else can explain it a different way, please go ahead.
Old 07-26-2007, 02:10 PM
I'm needing a caw
Jeff92se's Avatar
Ah I got it. So once you make that harness, you aren't done. You have to tap the emanage harness into the harness you just made. Yikes!
Jeff92se is offline
Old 07-26-2007, 02:39 PM
VQ Wizard
SR20DEN's Avatar
I've spent over an hour or so on it trying to desolder everything. That is a complete waste of time. Cutting seems to be the way to go.
SR20DEN is offline
Old 07-26-2007, 02:43 PM
I'm needing a caw
Jeff92se's Avatar
Matt, how did you do yours? Happen to have a pic?
Jeff92se is offline
Old 07-26-2007, 02:54 PM
VQ Wizard
SR20DEN's Avatar
I haven't done it. I just tried to desolder it when I got it. But I am going to use a cutoff wheel which should cut through everything cleanly and quickly.
And I still have no main harness to connect to it.
SR20DEN is offline
Old 07-26-2007, 03:01 PM
I'm needing a caw
Jeff92se's Avatar
Oh. Puppet alluded to you already having the EU hooked up to your ecu. If that's true, I was just curious as how you did that w/o this harness.
Jeff92se is offline
Old 07-26-2007, 04:02 PM
VQ Wizard
SR20DEN's Avatar
I have a EB installed already which replaced my SAFC2. What I was was tap into the main harness (solder and heat shrink). I used 12 pin and a 9 pin harnesses I got from Radio Shack so I can remove the EB main harness a any time.
http://www.radioshack.com/family/ind...032058.2032231
A good alternative to that is what Dandymax did and use some DB25 connectors which are easy to get, just be sure to double pin most of those because of current draw.
SR20DEN is offline
Old 07-26-2007, 04:26 PM
IceY2K1's Avatar
Que?
2003 G35 ECU is similar to 2000-2003 Maxima ECU, therefore YOU must make your own like I did.
2005(2004?) Maxima is similar to 2003-2004 350Z, so my buddy could use the BoomSlang/AutoSport/etc..
Ugh.............
IceY2K1 is offline
Old 07-26-2007, 04:28 PM
IceY2K1's Avatar
One piece of advice to anyone making their own...
Make sure you test the extension harness FIRST, THEN solder on the EU wires.
IceY2K1 is offline
Old 07-26-2007, 05:39 PM
I'm needing a caw
Jeff92se's Avatar
Pics? As I understand it. Only the later Gs and Zs have harness kits available. Maxima guys and early Gs are out.
Unless the newer maximas (maybe 04+) went to the later G/Z type ecu connector (ie.. black)
Que?
Jeff92se is offline
Old 07-26-2007, 05:49 PM
VQ Wizard
SR20DEN's Avatar
All A33s and your early V35 have the same connector, as you originally brought to our attention Jeff. But the A34s do have the same connector as the Z33 and later V35s.
However the pinouts for the A33, A33B and early V35 are all different as far as I know. But I haven't exactly confirmed the latter (between A33B and V35).
SR20DEN is offline
Old 07-26-2007, 06:31 PM
IceY2K1's Avatar
I'm not sure what you'd like pics of Jeff.
In short, you're in the same boat as 5/5.5 Gens that have to make their own vs. 6Gs that can buy a 350Z boomslang or similar extension or P-N-P EU harness.
IceY2K1 is offline
Old 07-27-2007, 06:55 AM
Here you go Jeffy... looks a lot like yours (its just flipped).
Quick Reply: Anyone running a 350Z Boomslang Emanage Ultimate harness?
