Electric Motor Noise
Old 09-28-2006, 01:52 PM
LenBum's Avatar
My 2005 with 45,000 miles has developed an interesting noise. When I turn the car off I hear some kind of electric motor seconds after the motor shuts off. Sounds like it's retracting something. I thought this was the only time I heard it but the other day when I started the car I heard the same motor in the background. My mechanic doesn't know what it is. He tried to isolate the sound but was unable to. He thinks it might be coming from the transmission. "Better call Nissan" is what he told me. Anyone know what I'm dealing with? I'm leaving for Florida in less than a month.
LenBum is offline
Old 09-28-2006, 02:36 PM
HADA 11's Avatar
My car does that same thing, always has. I believe it's the car playing with the throttle valve position. I'll check my service manual later and give you some solid tech.
HADA 11 is offline
Old 09-28-2006, 02:42 PM
LenBum's Avatar
Mine never used to do this until very recently.
LenBum is offline
Old 09-28-2006, 08:11 PM
I Donate! Why Don't You?
xoomer.com's Avatar
weird problem. I've had many things wrong with my max but never this. Thank god. I hope my bad years are over.
xoomer.com is offline
Old 09-28-2006, 08:26 PM
SmokeNismo's Avatar
mine does that too. sounds like it comes from near the air box, i dont hear it unless the hood is open. o well its probably something normal.
SmokeNismo is offline
Old 09-29-2006, 03:13 PM
madmik's Avatar
Mine too. Windows must be down to notice it.
madmik is offline
Old 10-16-2006, 06:26 PM
mpictou's Avatar
I have the same sound. I had it all summer....hadn't noticed it last winter and now that fall is here it seems to be gone now....very strange!
mpictou is offline
Old 10-17-2006, 06:28 AM
Maxima TL's Avatar
it's your motor mount
http://forums.maxima.org/showthread.php?t=495619
Maxima TL is offline
Old 10-17-2006, 09:51 AM
.org extraordinaire
kamski's Avatar
Yeah, the front hydraulic fluid motor mount is realising pressure.
Kamski
kamski is offline
Old 04-01-2007, 07:53 PM
Ekology's Avatar
Do you guys know if I can make the dealer replace this for free? My car just hit 39k and is now out of warranty but this problem seems way too common.
How much does this repair cost anyway?
How urgent is it to get this fixed?
Ekology is offline
Old 04-01-2007, 08:09 PM
M&M
M&M's Avatar
I get that noise every time I start the car and start driving...
M&M is offline
Old 04-01-2007, 08:11 PM
Machinist's Avatar
Are you sure it's not the fan?
Machinist is offline
Old 04-02-2007, 02:49 AM
DRU1's Avatar
I get that noise too...but it sounds like its comming more from the rear center console...but its only when i start the car and it doesnt do it everytime...HMMMMMMMMMMM
DRU1 is offline
Old 04-02-2007, 03:01 AM
Nietzsche's Avatar
For those that aren't aware the electronic engine mounts make noise. It is normal, look in the FSM. When you start and shut off the car it does a self check and makes noise. Also under load/acceleration it makes noise, and when you let off it makes noise. Remember it's electronic and goes on and off, ie... it makes noise.
Nietzsche is offline
Old 04-02-2007, 05:33 AM
VinneousMaximus's Avatar
That sounds more logical Nietzsche, I have a brand new 07 and have noticed this electric motor sound since day one. I'll turn off sometimes and hear this faint sound for like one sec. Sometimes it's when I turn on, sometimes randomly while running. Sounds like a small little server motor moving is all. I didn't know we had electronic motor mounts? Interesting. Anyone have anything further on them. I never thought anything was wrong, but was curious as to what it was.
VinneousMaximus is offline
Old 04-02-2007, 08:23 AM
CanadianMoFo's Avatar
Were the hydraulic mounts only in the auto transmissions or in the manual's as well? My front mount is saggy.
CM
CanadianMoFo is offline
Old 04-02-2007, 10:40 AM
Nietzsche's Avatar
Both have fluid filled mounts, however only the auto's are electronic.
Old 04-02-2007, 01:40 PM
I noticed my Injen rubber mount has been pulled forward about an inch. As the motor has sagged with the bad mount its pulled everything forward a bit.
Got quoted $396CDN for the front mount (just the insert). Thank god I bought an extended warranty. Thats a big chunk of change for the mount.
CM
pears
09-18-2015 05:25 AM
lrb6805
09-17-2015 04:49 PM
thenewguyy
09-12-2015 11:12 AM
ballerchris510
09-11-2015 05:29 PM
Quick Reply: Electric Motor Noise
