Phenolic Spacer Development for VQ35s
#81
I don't think making the runners a few mm's longer would do anything for the performance. The Kinetix has a huge plenum and smoother designed runners. I believe the spacer is more of an insulator to the heat of the engine going to the runners and plenum. As long as the lower ports are the same size as the holes in the spacer I don't see porting doing anything. If they were smaller then opening them up would be good for smooth flow. If you were to have your heads ported then sure, port match everything and have the lower manifold extrude honed.
#83
Nations 1st 6th Gen Turbo
Originally Posted by eK9aT10pSi
chernmax, got some details on how do to that to the stock IM? i remember back on my civic, i just used a grinder to shine it up and then paint it. yours turned out very nicely.
#84
Originally Posted by chernmax
The polished IM you see in the picture was stock at first until I broke out my Dremel, Sand Paper, and polishing solution. After 100 hrs+ of hand labor produced the results you see above. My bro Ramberg helped me because he purchased a new IM, had it polished (he was the first), mailed me his unpolished one and that's the one I ported and polished and then I sent him back mine after the swap. The hook up he gave me allowed me to keep my car in service and gave me the time to do a quality job...
#87
Here's a picture of my 04Max Manifold EGR when I took my manifold off for polishing...
Originally Posted by DeusExMaxima
I have a number of questions (sorry if they were answered in other posts):
1. I guess the basic reason that hp is increased is due to reduction of intake temperature, correct?
2. Is there any gain due to the slight increases in volume from the added space?
3. Isn't a large problem of intake temperature due to the fact that the intake body sits right above the firewall exhaust manifold? Would exterior insulation assist in this problem?
4. Would porting the lower intake manifold be helpful, especially in my case where I have the Kinetix intake manifold?
2) Yes, I believe there is also a slight gain due to the increase in intake runner length.
3) The location of the manifold has little to do with how hot it gets. The main reason it gets hot is b/c it's connected straight to the heads of the motor, which get VERY hot. If you isolate this, then you get cooler temps. Exterior insulation would help VERY little. It's always a good thing to prevent ambient heat from heating other components within the engine bay. Take the turbine of a turbocharger for instance, having a heat shield around that will prevent wires, hoses, and other components from overheating. That's why most stock exhaust manifolds have some sort of heat shielding around them.
4) The only way that porting the LIM would be beneficial in your case is if the ports on the Kinetix UIM are larger and the LIM ports needs to be matched. But if your ports are already matched, then doing port work on the LIM will not yield any gains.
Originally Posted by CanadianMoFo
Off topic...has anyone discussed bypassing the coolant hose at the throttle body?
#88
Originally Posted by NiZMo1o1
Holy crap , I never knew that !!
#89
Originally Posted by Aaron92SE
I've seen that picture. I am only concerned about what the tube looks like. We've already determined that it's a solid tube.
#90
I actually posted that for other members so they get a better perspective of what you are really describing. I'm actually going to hold off one my Dyno tuning until I get my spacer. I'm pretty excited about your work and the quality you're putting into it. Been waiting 3+ years for someone to do this for the 6th Gen, Thanks bro...
I really appreciate everyone's support and patience. You will not be disappointed with the quality of my product or my customer service. That is something I can guarantee!
#92
Aaron, any idea when the non EGR spacers will be available? Ill be in for one.
The 6th gen spacers are going to be a little while longer. I first need to get a 6th gen test vehicle. That search process will start within the next week since the 5.5 gen spacers are about ready for sale.
Also, why are you in for the non EGR spacers? Doesn't your car have an EGR system?
#93
The non EGR spacers for the 5.5 gen MIGHT be available this weekend. Please refer to the large 5th gen thread for more details.
I belive Deus has the Kinetix manifold and it came with a flex tubing already ?
I dunno thats just my guess but
SOMEONE with a 6th Gen meet up with Aaron ASAP. I need these like ASAP !
#94
But, don't worry. I will get these rolling as soon as humanly possible.
#96
I assume the 5.5 gen spacer will fit my car since EGR isnt a factor. If thats the case, then I can be ur test car.
#97
#102
Yeap, me and Ritz are meeting to design the 6th gen spacer kit. I will come up with an EGR tube design so that you will be able to install the same kit the 5.5 gen guys have. I also plan to test fit the 5.5 gen spacers on the 6th gen to confirm that everything matches up perfectly and make sure there aren't any clearance or other fitment issues. Other than that, it should be a speedy release since the 5.5 gen spacers are already designed and should bolt right up to the 6th gen.
In fact, I have a 6th gen vehicle right now that will install the 5.5 gen spacers soon. He doesn't have the EGR problem that you guys do since he has the Kinetix IM. So, I should have some butt dyno real world results before I even get a chance to test the spacers myself.
#104
Originally Posted by RHMax
Ritz, do you have FSTB?
#105
when the FSTB came out, some were worried it will hit the intake manifold, putting washers was one of my suggestions to those members, but they basicly sworn that theres not enough room for that.
I dunno how true that is.
#106
#108
So hows the 6th Gen spacer coming???
#109
I know it's hard to read sometimes when there is so much discussion. But me and Ritz are meeting tomorrow in order to design the 6th gen kit entirely. I'll keep you guys posted.
#111
first steps of testing went extremely well... it appears the EGR hose will NOT need modification, so the setup that Aaron has for the 5.5gen max will work for ours as well. I'll probably be putting the whole thing in this weekend and posting final results before he starts selling them for the 6th gen.
although, it's only 3 in the afternoon now.... I'm getting antsy... it might be in before nightfall.
#114
I'm just curious about the clearance issue.
it raises it 3/16" if that helps... if you have an STB, go ahead and see how much room is under there.
#115
Stealership installed mods!
Sorry for the delayed response. I've been out of town this past weekend.
I don't think the Nissan dealership will install this modification. I don't think they will install ANY aftermarket mod not made and approved by them.
I can't comment on the warranty. That is something you will have to contact Nissan about. Hopefully, others can chime in about how their Nissan warranty has treated them in the past.
I guess we're lucky up here in Montreal, Canada...
My stealership installed the following items: AEM CAI, Front Strut bar, Underdrive pulley, aftermarket rotors and pads, 4 Eibach Prokit 1 lowering springs and even my grille and they give us 10% off all aftermarket installations!
#117
Originally Posted by xorbitman
By the way will car run lean with this spacer mod and will it require a SAFC and tuning to run properly?
So, you do not need to do a retune or get a SAFC when installing these spacers. It's a simple bolt on mod.
#118
What this means is the 6th gen community gets a spacer kit for the same exact price as the 5th gens! I was expecting the price to be upwards of $300. But right now, it's expected to be only $225.
#119
i am so ready to buy this! make the GB already, lol!! i wish taz's ftsb was done so ritz and aaron couldve tested it completely. but for the ones that got taz's mmi kit [i did as well] i dont think that there would be too much play in the motor
