Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-03-2007, 10:38 AM   #1
Send a message via Yahoo to ThunderMaxi
Tire Pressuring Monitoring
Hola,
I just got an 07 SL with the Tire Pressure Monitoring System, and the light keeps flashing on it. I have taken it to the dealership twice and it still keeps lighting up. Anyone else have a problem with this? The light is off when I get in the car, but it comes back on after a while. I think they just reset the light and after I start the car a couple of times the problem shows back up...
Anyone else have this problem?
__________________
ThunderMaxi is offline   Reply With Quote
Old 01-03-2007, 12:35 PM   #2
SEVEN-time Maxima Owner
jcalabria's Avatar
Quote:
Originally Posted by ThunderMaxi
Hola,
Mine has been on since July - it flashes for a minute at startup then stays on steady, which is a malfunction indication.
I've been running 60-70 hours a week at work and haven't had time to go back to the dealer with it. I know the tires are properly inflated so I haven't lost any sleep over it. I just got my recall notice for the ignition/steering interlock, so I'll probably get 'em both taken care of soon.
__________________
Current Maximas:
  • '07 SE - Dark Slate / CVT
  • '01 SE Anniversary Edition - Icelandic Pearl / 4AT
Previous Maximas:
  • '03 SE Titanium Edition - Polished Titanium / 4AT
  • '00 SE - Gray Lustre / 4AT
  • '96 SE - Pearl White / 4AT
  • '95 SE - Super Black / 4AT
  • '87 SE - Super Black / 5MT
Other Notables:
'67 'Vette L71 4MT / '53 Chevy Pickup 283 2(!)AT / '78 Challenger ES 5MT / '80 Capri Turbo RS 4MT / '82 ES2800 4MT / '82 Supra P-Type 5MT / '87 Lancer ES Turbo 5MT / '96 ES300 4AT / '01 S60T5 5AT / '07 MKZ 6AT
jcalabria is offline   Reply With Quote
Old 01-03-2007, 01:34 PM   #3
Lovely... it really irritates me since it's yellow and all... the first time it came on was in the middle of the night when I was on my way to Houston... I was like AAAAHHHH!!! I got the manual out and kept on going...
__________________
Old 04-13-2009, 09:58 PM   #4
MAJOR BUMP.
Wow, im glad i am not the only one with this problem.
My 2008 Max's TPMS light comes on and blinks for a minute then stays steady, until some point it decides to go off. This happens at random times, for random lengths of time, usually when I've been driving for over 15 miles. Only one tire shows a problem, and it shows ** instead of a pressure, the other three show proper pressure readings.
I have had it into the dealership twice now. The first time they cleared a bunch of codes and said that should fix it. Sorry. The second time, i actually showed a photo of the condition to my SA. It didn't matter. The tech even took it for a 20 mile ride, and they couldn't duplicate the condition. My SA believed me, after all i had a photo; they just never saw it happen.
He told me i am supposed to swing by when the TPMS is malfunctioning, but the problem is that i am usually miles away, or it is at night when they are closed, or it's just not convenient.
It bothers me because it is distracting. I know that my tires are properly inflated, especially since the sensor regains proper function after a minute or two anyway.
Has anyone else had this problem, had it fixed, ignored it, junked car, etc?
ZachPA is offline   Reply With Quote
Old 04-14-2009, 11:31 AM   #5
I use to work for a tire wholesaler and was required to take classes on such situations. Tire Pressure Monitoring systems are designed to alert the driver when ever their is a slight variation in tire pressure ranging from 3-5 psi. As you may already know as you drive your car, the air in the tire begins to heat up causing it to expand which will indicate a increase in tire pressure. At night the road conditions are less severe and may not heat up the air in the tire as much as during the day. What I would try is, If your TPMS goes off mainly at night add/subtract a few Lbs until you notice a difference. If you live in houston as I do this happens alot, We have days where we have to use the ac during the day and the heater at night!
__________________
2004 SE 6spd-20" Defy Slivers, 8000K HIDs, 2" front .8" rear Eibach lowering Kit, Billet Grille, 7" JVC Head Unit, Custom Audio Enclosure with 1 L7, 900W Planet Audio monoblock Amp, Compustar Alarm w/ Remote Start, 5% tint
check out my ride
http://www.cardomain.com/ride/2315109
J. Cook is offline   Reply With Quote
Old 10-14-2009, 10:21 AM   #6
Quote:
Originally Posted by ZachPA View Post
MAJOR BUMP.
Hey check out my hectic week with my 2008 maxima. I seen my TPMS light flashing and on my navigation screen it wasn't registering any information about the TPMS. It just showed ***, so i took it to the dealer and one of the sensor read low battery and needed to be changed. Now 2 days later the same problem occured in another tire. So now i am off to the dealer to get another sensor replaced. Thats going to be 2 sensor replaced in a matter of 3 days. If these sensor run off battery when we get out of warranty we are going to be in trouble because its about 200 dollars a sensor with labor. Anyone else having sensor problems. Any one else with a low battery reading from the sensor.
tallblazer124 is offline   Reply With Quote
Old 10-14-2009, 11:05 PM   #7
Mine is fine during the summer but when the temps begin to drop in the fall i have to adjust the tire pressure to compensate for the lower temperatures at least every other week.
__________________
Often Imitated.....Never Duplicated
DAlastDON is offline   Reply With Quote
Old 10-15-2009, 02:18 AM   #8
Send a message via AIM to turbizzy
Low tire pressure warning lights on Nissans come on when tire pressure reaches 29psi and low. We always set tire pressures to 35psi with the tires COLD. If your light keeps comming on then easiest thing to do is check all your tire pressures manually with a gauge. If its anywhere near 29psi especially if its been sitting overnight then you need to add some air. Its normal for tires to go down a few psi overnight in the cold.
But yes i have seen some sensors not responding, there is a procedure for us to "wake up" the sensor as they are turned off from the factory and get turned on prior to shipping, or at least are supposed to be turned on. We have a special tool that we use to turn them on and register them along with the consult scanner. But there have been a few times where the sensor is faulty and gets replaced.
Tire pressure sensors have batteries in them that are supposed to last the car's lifetime but im very skeptical of that. They only send a reading to the BCM every few mins with the car standing still and update at a rate of once per min with the car moving over 25mph so this is supposed to prolong battery life.
__________________
turbizzy is offline   Reply With Quote
Old 10-15-2009, 10:34 AM   #9
Well as i posted earliar. Two of my sensor went bad with a low battery reading. So u beign skeptical is correct its confirmed those batteries dont last the life of the car and when your out of warranty 200 bucks for each tire with labor.
Old 10-15-2009, 11:05 AM   #10
My TPMS light came on again two days ago because i probably have a nail stuck in one of the tires. It seems like these cheap RSA tires always attract nails.
__________________
Ryaliu is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
