corner lights not working
Old 08-03-2006, 02:08 PM
KRZYRACER's Avatar
just bought my 04 6speed and the lights were not working neither were the fogs and i replaced both lights and the fogs are working but the corner lights are not. any help would be great
KRZYRACER is offline
Old 08-03-2006, 02:55 PM
* THIS SPACE FOR RENT *
MAXDOUT04's Avatar
maybe there is a wire loose or a bad ground but if your talking about the cornering lights then the headlights have to be on to make them work
MAXDOUT04 is offline
Old 08-03-2006, 05:06 PM
RichA's Avatar
There is also a fuse in the box under the hood that effects the corners and the tail-lights. Don't remember the number off hand but it is near the top.
RichA is offline
Old 08-03-2006, 07:17 PM
KRZYRACER's Avatar
yeah i know they work with the headlights but I replaced both lights on each side and also checked the fuses but the tail lights are working fine so I dont know wht it could be
Old 08-04-2006, 12:24 AM
kroyo_MAX's Avatar
have you checked to see if there are any loose connecters?
kroyo_MAX is offline
Old 08-05-2006, 04:20 PM
metdav's Avatar
They only work if your signal is on. I'm sure you know this, but just in case.
metdav is offline
jerrod99_se-l
08-27-2015 08:27 PM
KristyKarina
08-23-2015 09:53 AM
kenc15
08-05-2015 08:29 AM
kjm900r
08-05-2015 07:14 AM
Quick Reply: corner lights not working
